lct Posted December 24, 2023 Share #101 Posted December 24, 2023 (edited) Advertisement (gone after registration) • Edited December 24, 2023 by lct Link to post Share on other sites More sharing options...
Advertisement Posted December 24, 2023 Posted December 24, 2023 Hi lct, Take a look here Occasional unreadable dng. I'm sure you'll find what you were looking for!
lct Posted December 24, 2023 Share #102 Posted December 24, 2023 (edited) 3 hours ago, UliWer said: I know we discussed this before and I am not looking forward to convince you. For me there is a fundamental contradiction if something is switched off and stays active at the same time so that it can detect a lens code to apply a certain code. The camera does not accept the main function "off" for lens detection. It may be interesting lo look in which context the word "freeze" was first used in connection to the M11. I may have overlooked an early posting but I think it is here: https://www.l-camera-forum.com/topic/329432-m11-will-freeze-when-lens-detection-off-bug/ And then it goes on: https://www.l-camera-forum.com/topic/329232-m11-bug-with-uncoded-lens/ https://www.l-camera-forum.com/topic/338594-lens-selector-off/ https://www.l-camera-forum.com/topic/331172-m11-does-not-detect-lens-intermittent-fault/ https://www.l-camera-forum.com/topic/375926-m11-auto-lens-detection-problems/#comments I don't know if i'm the right person to comment but i haven't had any problems with my M11 since firmware update 1.6.1 so far. I don't use lens detection off for my coded lenses mostly but it works perfectly with uncoded lenses when i don't want to apply a Leica lens profile to them. FWIW. Edited December 24, 2023 by lct Link to post Share on other sites More sharing options...
hjddd Posted January 31, 2024 Share #103 Posted January 31, 2024 We have been waiting for enough time to wait for Leica to release new firmware。 Where is it? 1 Link to post Share on other sites More sharing options...
jaapv Posted January 31, 2024 Share #104 Posted January 31, 2024 In Wetzlar I assume... 1 Link to post Share on other sites More sharing options...
Tailwagger Posted January 31, 2024 Share #105 Posted January 31, 2024 4 hours ago, hjddd said: We have been waiting for enough time to wait for Leica to release new firmware。 Where is it? Have to agree. Just encountered my 7th corrupted file. Disappointing that this issue has yet to be addressed. All one can hope is that in getting to the bottom of this one, they've finally figured out where the internal collisions are happening, though given the delay, if so, one has to assume that the problem(s) are difficult to address. Either that or their doing far more testing this time around to avoid any further mud in the face. 1 Link to post Share on other sites More sharing options...
Stevejack Posted February 9, 2024 Share #106 Posted February 9, 2024 Did anyone confirm if the corruption still exists when shooting to both internal + SD card (so files are mirrored across both)? The first DNG after turning the camera on is often corrupted for me, shooting to SD only. It's not consistent but it's often. I've switched to IN=SD which is mirroring the DNG files on both the internal storage and the SD card. I'm assuming this means the file is written to the internal drive first, then copied across to the SD card. Can anyone confirm if doing this has solved the problem for them? Link to post Share on other sites More sharing options...
84bravo Posted February 9, 2024 Share #107 Posted February 9, 2024 Advertisement (gone after registration) On 12/23/2023 at 6:33 PM, Crem said: Leica really screws up by not permitting firmware downgrades. I don't disagree, but I don't think any manufacturer permits firmware downgrades. That's been my experience with Canon and Nikon. Link to post Share on other sites More sharing options...
Stevejack Posted February 11, 2024 Share #108 Posted February 11, 2024 On 2/9/2024 at 2:55 PM, Stevejack said: Did anyone confirm if the corruption still exists when shooting to both internal + SD card (so files are mirrored across both)? The first DNG after turning the camera on is often corrupted for me, shooting to SD only. It's not consistent but it's often. I've switched to IN=SD which is mirroring the DNG files on both the internal storage and the SD card. I'm assuming this means the file is written to the internal drive first, then copied across to the SD card. Can anyone confirm if doing this has solved the problem for them? After some testing I can confirm that setting the storage to IN=SD has not solved the problem, the first file recorded to the SD card after switching the camera on is still occasionally corrupted. 1 Link to post Share on other sites More sharing options...
mattcheol Posted February 11, 2024 Share #109 Posted February 11, 2024 2 hours ago, Stevejack said: After some testing I can confirm that setting the storage to IN=SD has not solved the problem, the first file recorded to the SD card after switching the camera on is still occasionally corrupted. Agreed. I have since actually sold off my M11 because things were so frustrating. But I can concur with this as I exclusively shot in IN=SD mode and also had the DNG corruption issue. 2 Link to post Share on other sites More sharing options...
Stevejack Posted February 11, 2024 Share #110 Posted February 11, 2024 Just now, mattcheol said: Agreed. I have since actually sold off my M11 because things were so frustrating. But I can concur with this as I exclusively shot in IN=SD mode and also had the DNG corruption issue. It seems the only solution is to use the internal storage and transfer images via the M11 built in USB-C port. Crazy state of affairs that this is the situation we're in. I have an M11 still on firmware 1.2 which doesn't have the issue, but when I purchased the M11M it had the newest firmware already on it so I had no choice in the matter and obviously can't revert to an earlier firmware. 1 Link to post Share on other sites More sharing options...
LeicaR10 Posted February 11, 2024 Share #111 Posted February 11, 2024 Mattcheol, +1. You are not alone. I traded my M11s to include the P and went back to the M10-R & M cameras. I simply had to make a choice, corrupt DNG files, magenta cast, firmware updates that create issues that were previously fixed or had no issues before. Others report no issues and I am happy for them. Personally, I could not take further risk with the M11s that simply did not work reliably for me. r/ Mark Link to post Share on other sites More sharing options...
pop Posted February 11, 2024 Share #112 Posted February 11, 2024 5 hours ago, Stevejack said: obviously can't revert Have you tried? Link to post Share on other sites More sharing options...
Stevejack Posted February 11, 2024 Share #113 Posted February 11, 2024 3 hours ago, pop said: Have you tried? Wait - you know a way for the end user to do this? How? I thought it wasn't possible because the camera will deny an older firmware version but if you have the solution I'm all ears. Link to post Share on other sites More sharing options...
pop Posted February 11, 2024 Share #114 Posted February 11, 2024 1 hour ago, Stevejack said: Wait - you know a way for the end user to do this? How? I thought it wasn't possible because the camera will deny an older firmware version but if you have the solution I'm all ears. I don't have an M11, but I seem to remember that earlier models accepted quite easily older firmware versions. Hence my question whether you had tried to do so. The opposite would be that you didn't try because you simply assumed that it wasn't possible. Link to post Share on other sites More sharing options...
Stevejack Posted February 11, 2024 Share #115 Posted February 11, 2024 10 minutes ago, pop said: I don't have an M11, but I seem to remember that earlier models accepted quite easily older firmware versions. Hence my question whether you had tried to do so. The opposite would be that you didn't try because you simply assumed that it wasn't possible. Ah, yes sorry I did try and when it didn’t work I went looking and read that it wasn’t possible. when you load an older firmware version onto the SD card the camera doesn’t recognise it so you can’t start the update process. The option to update is blanked out. Link to post Share on other sites More sharing options...
Edax Posted February 27, 2024 Share #116 Posted February 27, 2024 Link to post Share on other sites More sharing options...
jaapv Posted February 27, 2024 Share #117 Posted February 27, 2024 The Internet is full of complaints about Windows corrupting SD cards. Frying pan into the fire comes to mind. Just as bad as Mac. The best remedy is to follow best practice by locking the card before inserting it into the reader. Link to post Share on other sites More sharing options...
lct Posted February 27, 2024 Share #118 Posted February 27, 2024 (edited) 58 minutes ago, jaapv said: [...]The best remedy is to follow best practice by locking the card before inserting it into the reader. A practice i have never used in 20+ years but if it works for others i have nothing to say against it. Edit: Except that i don't see how backup memory can be done and user profiles exported to a card if it is locked, sorry if i sound negative this way. Edited February 27, 2024 by lct Link to post Share on other sites More sharing options...
Edax Posted February 27, 2024 Share #119 Posted February 27, 2024 14 minutes ago, jaapv said: The Internet is full of complaints about Windows corrupting SD cards. Frying pan into the fire comes to mind. Just as bad as Mac. The best remedy is to follow best practice by locking the card before inserting it into the reader. Works fine until the lock breaks down, happened after only a few actuations with one of my Sandisk Extreme SD cards. I considered modifying a card reader especially for the M11 in such a way that every card seems locked.. Link to post Share on other sites More sharing options...
lct Posted February 27, 2024 Share #120 Posted February 27, 2024 My current Sony card doesn't seem to have any lock BTW. I have no idea why. Link to post Share on other sites More sharing options...
