Stef63 Posted October 27, 2023 Share #121 Posted October 27, 2023 Advertisement (gone after registration) 24 minutes ago, steveBK said: It does work remarkably well given that the density of apple devices in any inhabited area is quite high This is why using it to track luggage works fairly well - can gain some confidence that checked bags make it through transit and onto connecting flight, when its going to pop onto luggage carousel, etc I think another generation or two of shrinking the size of them and they'll have even more use cases I can already fit one in all my bags, house/car keychains and in my wallet You could already now probably hide one in the cushioning of a camera strap if one was creative enough.. Additionally, most of the volume of an AirTag is taken up by its casing and battery. This wouldn't be necessary, as only the electronics need to be integrated into the M. 2 Link to post Share on other sites More sharing options...
Advertisement Posted October 27, 2023 Posted October 27, 2023 Hi Stef63, Take a look here Leica M11-P: New Flagship With Content Authentication . I'm sure you'll find what you were looking for!
MattMaber Posted October 27, 2023 Share #122 Posted October 27, 2023 5 hours ago, rramesh said: Don’t understand the real value of content authentication in camera. It can always be done in post. That was my thoughts, from what Ive seen its easily removed or edited and if you do edit the file in s/w which doesnt support the CA standard presumably it wont even show the changes. Not sure I see the point unless there something else 'magical' going on here. Happy to be proven wrong Link to post Share on other sites More sharing options...
hepcat Posted October 27, 2023 Share #123 Posted October 27, 2023 17 hours ago, Chuck Albertson said: I don't recall that coming up in court. I don't know the rules in your jurisdiction, but over here to authenticate an image in court (film or digital), all you need is a warm body on the witness stand testifying that it's an accurate depiction of the scene they witnessed. I supervised a crime scene unit in NoCal from 1991-1997. There was a continuing discussion for several years about what the courts might do in regard to accepting digital imaging as evidence as a result of the ability of photographers to manipulate the photos. But you're absolutely correct that in the end, it's a print that's submitted and the authentication is done by a warm body testifying under oath that the image is a "true and accurate representation of the scene as they saw it." It once again comes down to a human being truthful. Or a human lying under penalty of perjury. Just as it always has. The original capture medium is irrelevant. 3 Link to post Share on other sites More sharing options...
Simone_DF Posted October 27, 2023 Share #124 Posted October 27, 2023 1 hour ago, haikos said: Air Tag only works if another Apple device passes in its vicinity and pings it. It's not a realtime GPS unless its owner is on the app and can connect to it. Plus, the air tag is not so tiny, relatively speaking. That’s not how it works. Airtags automatically fetch and constantly update their location from any nearby iOS device, of which there are billions in the world. They work remarkably well. as someone else mentioned, most of the size is because of the button style battery and casing. The actual chip is quite small and would easily fit into a camera (except perhaps the M since space is constrained) or a case. Even the Airpods, which are as big as a Leica M battery, have the Find My chip. I suspect the only problem is licensing 1 Link to post Share on other sites More sharing options...
Anbaric Posted October 27, 2023 Share #125 Posted October 27, 2023 (edited) 36 minutes ago, MattMaber said: That was my thoughts, from what Ive seen its easily removed or edited and if you do edit the file in s/w which doesnt support the CA standard presumably it wont even show the changes. Not sure I see the point unless there something else 'magical' going on here. Happy to be proven wrong The authentication is easily removed, but then you no longer have an authenticated image. If you attempt to edit the authentication metadata, or edit the image in software that doesn't support authentication, then again you won't have an authenticated image. I assume (and I think post #107 confirms) that a cryptographic hash of the image data is generated on capture, and after each edit in software that supports authentication. If you change the image data with something else, it will no longer match the current hash and the authentication software will detect this. Edited October 27, 2023 by Anbaric 2 Link to post Share on other sites More sharing options...
MattMaber Posted October 27, 2023 Share #126 Posted October 27, 2023 Exactly, and at that point its no better than an image captured by a camera without CA. Hence Im not sure I see the point. Unless of course CA images becomes mandatory in press (unlikely) Link to post Share on other sites More sharing options...
algrove Posted October 27, 2023 Share #127 Posted October 27, 2023 Advertisement (gone after registration) 36 minutes ago, MattMaber said: That was my thoughts, from what Ive seen its easily removed or edited and if you do edit the file in s/w which doesnt support the CA standard presumably it wont even show the changes. Not sure I see the point unless there something else 'magical' going on here. Happy to be proven wrong Not so sure about these comments as it was designed to be added to the file with no tampering thereafter even by the owner of the image. Nothing like it can be added afterwards since that is the security in that no one can change the file as rendered once the protection is in place. Link to post Share on other sites More sharing options...
Simone_DF Posted October 27, 2023 Share #128 Posted October 27, 2023 3 minutes ago, MattMaber said: Exactly, and at that point its no better than an image captured by a camera without CA. Hence Im not sure I see the point. Unless of course CA images becomes mandatory in press (unlikely) Ok. Imagine this scene. There are 2 photojournalists and a controversial event is in front of them. Both capture the same scene. One has CA disabled, the other one enabled all the way through the final image. You, as a news editor, which image would you buy, one of which you can prove authenticity or the other one? 3 Link to post Share on other sites More sharing options...
MattMaber Posted October 27, 2023 Share #129 Posted October 27, 2023 6 minutes ago, Simone_DF said: Ok. Imagine this scene. There are 2 photojournalists and a controversial event is in front of them. Both capture the same scene. One has CA disabled, the other one enabled all the way through the final image. You, as a news editor, which image would you buy, one of which you can prove authenticity or the other one? Cheapest probably 😕 that's quite the journalism utopia you envision 😁 I understand the pint your making but it will need to become an industry standard too actually be relevant Again, happy to be proven wrong 4 Link to post Share on other sites More sharing options...
Anbaric Posted October 27, 2023 Share #130 Posted October 27, 2023 4 minutes ago, MattMaber said: Exactly, and at that point its no better than an image captured by a camera without CA. Hence Im not sure I see the point. Unless of course CA images becomes mandatory in press (unlikely) The point is, if you are a photographer who cares about authentication of capture and documented edits, or your employer/client does, here is a mechanism for providing it, all the way from the camera via the editor to (potentially) upload to a compliant image sharing platform. Nobody would care about this if just Leica did it, but if it becomes mainstream in cameras and image editing software, it may well become a standard. Adobe, Microsoft, Canon, Nikon, Sony, the BBC and Reuters have all been involved in this at some level (defining the standard or taking part in pilots, etc.). At least one trial with Canon and Reuters included GPS tags and timestamps, so it would be possible to authenticate where and when an image was captured, and document all subsequent edits. 2 Link to post Share on other sites More sharing options...
MattMaber Posted October 27, 2023 Share #131 Posted October 27, 2023 1 minute ago, Anbaric said: The point is, if you are a photographer who cares about authentication of capture and documented edits, or your employer/client does, here is a mechanism for providing it, all the way from the camera via the editor to (potentially) upload to a compliant image sharing platform. Nobody would care about this if just Leica did it, but if it becomes mainstream in cameras and image editing software, it may well become a standard. Adobe, Microsoft, Canon, Nikon, Sony, the BBC and Reuters have all been involved in this at some level (defining the standard or taking part in pilots, etc.). At least one trial with Canon and Reuters included GPS tags and timestamps, so it would be possible to authenticate where and when an image was captured, and document all subsequent edits. I sincerely hope it will become widely used and industry standard, but have you seen the quality of photogrpahy and journalism lately? its all smart phone vids and social journalism. 1 Link to post Share on other sites More sharing options...
Anbaric Posted October 27, 2023 Share #132 Posted October 27, 2023 16 minutes ago, algrove said: Not so sure about these comments as it was designed to be added to the file with no tampering thereafter even by the owner of the image. Nothing like it can be added afterwards since that is the security in that no one can change the file as rendered once the protection is in place. The system, if fully implemented, can handle the original capture and later (documented) edits with compliant software. So if (say) a news organisation allowed you to only make minor corrections like rotation, slight cropping and minor colour/contrast adjustments, you could prove you had only done that and not (say) added or removed a major picture element. 1 Link to post Share on other sites More sharing options...
algrove Posted October 27, 2023 Share #133 Posted October 27, 2023 Anabric The problem is it has not been "fully implemented" for 20 years. Many big names have never supported it including Apple, Google and software wise C1 does not support this. PhotoMechanic used by many pros does not mention its support for this feature either. Theories are nice, but must become factual for it to matter. I applaud Leica for this move, but it is one small step for mankind to quote an often used phrase. Link to post Share on other sites More sharing options...
Anbaric Posted October 27, 2023 Share #134 Posted October 27, 2023 1 minute ago, MattMaber said: I sincerely hope it will become widely used and industry standard, but have you seen the quality of photogrpahy and journalism lately? its all smart phone vids and social journalism. If this catches on I would bet it gets added to smartphones, which of course already have GPS and biometrics, so you could in principle show it was you who unlocked the phone 5 seconds before the image was captured at the depicted event. It won't make that crappy phone footage any better though! In 'authenticated journalism' mode, the camera should refuse to operate unless the phone is rotated into landscape orientation. 🙂 Link to post Share on other sites More sharing options...
Simone_DF Posted October 27, 2023 Share #135 Posted October 27, 2023 19 minutes ago, MattMaber said: Cheapest probably 😕 that's quite the journalism utopia you envision 😁 I understand the pint your making but it will need to become an industry standard too actually be relevant Again, happy to be proven wrong Oh, but I totally agree with you. I just wanted to illustrate potential use (emphasis on potential!) of this technology. Link to post Share on other sites More sharing options...
MattMaber Posted October 27, 2023 Share #136 Posted October 27, 2023 Just now, Simone_DF said: Oh, but I totally agree with you. I just wanted to illustrate potential use (emphasis on potential!) of this technology. theres no reason surely they cant create the unique code hasn't an encrypted hash from the serial no, wifi Mac or some other unique data and create that on camera. The chip seems a bit of marketing MacGuffin tbh Link to post Share on other sites More sharing options...
Anbaric Posted October 27, 2023 Share #137 Posted October 27, 2023 6 minutes ago, algrove said: The problem is it has not been "fully implemented" for 20 years. Many big names have never supported it including Apple, Google and software wise C1 does not support this. PhotoMechanic used by many pros does not mention its support for this feature either. There have been ideas like this before, but this time there seems to be a bit more momentum behind them, driven by Adobe and others, with some consolidation of the various camps. I think AI-generated fakes are giving the imaging industries pause for thought, and there are now open technical standards anyone can adopt: https://news.adobe.com/news/news-details/2022/Adobe-Partners-With-Leica-and-Nikon-To-Implement-Content-Authenticity-Technology-Into-Cameras/default.aspx https://www.canon.co.uk/press-centre/press-releases/2023/08/reuters-new-proof-of-concept-employs-authentication-system/ https://c2pa.org/ Will this become a universal standard, or will it go the way of DNG as something only Adobe and a couple of camera makers take seriously? We'll have to wait and see. But I think something like this is needed in an age when media are so easily faked, sometimes with major social and political consequences. 1 Link to post Share on other sites More sharing options...
Simone_DF Posted October 27, 2023 Share #138 Posted October 27, 2023 Just now, MattMaber said: theres no reason surely they cant create the unique code hasn't an encrypted hash from the serial no, wifi Mac or some other unique data and create that on camera. The chip seems a bit of marketing MacGuffin tbh Not really. The secure enclave adds an extra strong layer of security. Apple has done something somewhat similar with Apple Pay. Your card data is stored on a separate on-device chip, and communicate to the external world only via a secure hash, which in turn is sent to Apple servers to be decrypted, authenticated then encrypted again to be sent to the receiver end (the merchant) 1 Link to post Share on other sites More sharing options...
MattMaber Posted October 27, 2023 Share #139 Posted October 27, 2023 lol I guess I value my Apple Pay transactions higher. 1 Link to post Share on other sites More sharing options...
FrozenInTime Posted October 27, 2023 Share #140 Posted October 27, 2023 This story illustrates that no amount of authentication associated with the captured image file and processing chain will in itself ensure journalistic integrity. https://petapixel.com/2023/10/25/picture-that-won-worlds-largest-photo-competition-was-staged/ 2 Link to post Share on other sites More sharing options...
