x
people that have freezing issues and using Leica thumb grip, put a piece of tape electric tape on the top of the thumb grip. I have heard from a source at Wetzlar that this is a work-around solution. This solution works for M10 freeze too.
Usually it was when your using thumb grip and live view at the same time.
My friend that put piece of tape on this thumb grip does not have any problems anymore.
Maybe this is discussed already.
  • Haha 1
I’m pretty sure this is sarcasm
5 hours ago, charlesphoto99 said:
Tinfoil hat and standing on one leg is really the only optimal, trouble free way to use the M11. Might want to invest in a good monopod.
Nope no sarcasm, try it and youll see a difference. The thumb grip shorts the camera sometimes and freezes it up, electric tape makes it work.
Nothing to lose, try it.
Edited by Borna
@Borna. Ok, I’m sure everyone wants to know more about this now… tape where…..where your thumb contacts the thumbrest?, on the hotshoe contact?  Please elaborate or even better provide a diagram. We all want to see this.  Thanks.
Take one centimeter and half of electric tape, ad it at the end of the thumb grip where it lays one part over and one part under the thumb rest. The end of the thumb grip needs to be covered.
Try it
My M11 works flawlessly although (because?) i'm using a "Thumbie" instead of a thumb grip. I removed its black paint though so it must be a better electricity conductor 😄 Edit: Just kidding but true.
Edited by lct
20 minutes ago, lct said:
I just meant to say that my story is true,not that i believe in the OP's explanation, sorry for any confusion. BTW the "Thumbie" is just stuck on the top plate of the camera with no electric contact to it or the hotshoe whatsoever.
I understood you, but I still think you are not having issues because you have not stuck any thumb grip towards the hot shoe.
Just waiting to see if someone else could try this and report back :)
Just tried with the thumb grip of my M240 to no avail, my M11 still works as well as it did with and w/o thumb grip, with and w/o Visoflex 2. If this thread had not 96 pages, i would think the so-called freeze debacle is a mere joke. At least, in my admittedly very short experience, thumb grips are of no visible effect sorry 😎
Edited by lct
I've used thumb grips on my M9, M9M, M10, M10-P, M10-R and M10M and have not ever had freeze issues with any of them. Why would the M11 be any different?
I just examined the thumb grip on my M10M and noted that there is a rubber strip along the back side where it presses against the camera body. Therefore, it seems thumb grips would already be insulated.
Edited by fotografr
