Popular Post logan2z Posted May 21, 2022 Popular Post Share #1 Posted May 21, 2022 (edited) Advertisement (gone after registration) I figured this would be most applicable on this forum. Moderators, please move if there's a more appropriate spot... Edited May 21, 2022 by logan2z 15 21 Link to post Share on other sites More sharing options...
Advertisement Posted May 21, 2022 Posted May 21, 2022 Hi logan2z, Take a look here YYE Camera: Behind the Scenes of Vintage Leica Repair . I'm sure you'll find what you were looking for!
Danner Posted May 21, 2022 Share #2 Posted May 21, 2022 Very nice 🙂 Link to post Share on other sites More sharing options...
Ko.Fe. Posted May 21, 2022 Share #3 Posted May 21, 2022 I like he is not a Leica only and servicing LTM copies (except FSU, those are trap to fix). I also read if he doesn't know how to fix Leica/Leitz gear it goes to D.A.G. Link to post Share on other sites More sharing options...
Huss Posted May 21, 2022 Share #4 Posted May 21, 2022 1 hour ago, Ko.Fe. said: I like he is not a Leica only and servicing LTM copies (except FSU, those are trap to fix). I also read if he doesn't know how to fix Leica/Leitz gear it goes to D.A.G. He doesn't touch M5, and very little with the M7. He does not collimate lenses - those go to DAG. (unless that has changed) 1 Link to post Share on other sites More sharing options...
Huss Posted May 21, 2022 Share #5 Posted May 21, 2022 Great video, thanks for posting. Q tips on the lenses.. I've done the same myself when I buy used glass that needs cleaning. Link to post Share on other sites More sharing options...
stray cat Posted May 21, 2022 Share #6 Posted May 21, 2022 Thank you very much for his. Just this past Thursday he posted me back my M2. I sent it to him with a problem I thought it had - the frame counter spinning all the time, not securing on frame numbers. This is what he wrote on completion and before shipping it back: Phil, I have your camera done. Leica M2 - The counter dial is good, nothing wrong with it. You did not wind the camera to the end, the counter wheel will be loose and spin. This is the design of the M2 counter system, when winding the camera the counter wheel is loose, only when before and after winding, the counter dial will work properly. This camera is quite smooth, serviced not long time ago, no need for another CLA at this moment. The rangefinder vertical line was slightly off, adjusted. The shutter rollers had too much tension, and loud. I believe Leica did CLA on the camera sometime ago, which is common for Leica serviced cameras and new cameras these days. Before adjustment, 1 sec was 0.88 sec. I have shutter speeds and brake all adjusted, all speeds work well now and the shutter is quieter than used to be. Checked everything in good working order. Tested the camera with a blank roll film made sure film winding and rewinding are all good. Below is the total due: Leica M2 adjust rangefinder/shutter brake & speeds $60.00 Shipping $100.00 Total $160.00 I couldn't be happier with this level of service and helpful advice. Shame about the shipping cost but that's just the reality nowadays and he did warn me. 3 Link to post Share on other sites More sharing options...
jakontil Posted May 21, 2022 Share #7 Posted May 21, 2022 Advertisement (gone after registration) 1 hour ago, stray cat said: Thank you very much for his. Just this past Thursday he posted me back my M2. I sent it to him with a problem I thought it had - the frame counter spinning all the time, not securing on frame numbers. This is what he wrote on completion and before shipping it back: Phil, I have your camera done. Leica M2 - The counter dial is good, nothing wrong with it. You did not wind the camera to the end, the counter wheel will be loose and spin. This is the design of the M2 counter system, when winding the camera the counter wheel is loose, only when before and after winding, the counter dial will work properly. This camera is quite smooth, serviced not long time ago, no need for another CLA at this moment. The rangefinder vertical line was slightly off, adjusted. The shutter rollers had too much tension, and loud. I believe Leica did CLA on the camera sometime ago, which is common for Leica serviced cameras and new cameras these days. Before adjustment, 1 sec was 0.88 sec. I have shutter speeds and brake all adjusted, all speeds work well now and the shutter is quieter than used to be. Checked everything in good working order. Tested the camera with a blank roll film made sure film winding and rewinding are all good. Below is the total due: Leica M2 adjust rangefinder/shutter brake & speeds $60.00 Shipping $100.00 Total $160.00 I couldn't be happier with this level of service and helpful advice. Shame about the shipping cost but that's just the reality nowadays and he did warn me. Now i know stuff i have to not confuse with regarding loose counter, and thanks for sharing too! YYE legend 1 Link to post Share on other sites More sharing options...
ironringer Posted May 21, 2022 Share #8 Posted May 21, 2022 Fine artistic video, showing a special and talented contributor to our Leica hobby 🙂. Thank you Julien for sharing this, and thank you Youxin for your professional and friendly work on my cameras and lenses. 1 Link to post Share on other sites More sharing options...
spydrxx Posted May 21, 2022 Share #9 Posted May 21, 2022 Thanks for sharing the video. Mr. Ye has been most graceful in my dealings with him over the years and don a fine job on whatever I have sent him. 1 Link to post Share on other sites More sharing options...
mikemgb Posted May 21, 2022 Share #10 Posted May 21, 2022 Youxin has repaired my M2, III and IIIa, his work is amazing. Link to post Share on other sites More sharing options...
TomB_tx Posted May 21, 2022 Share #11 Posted May 21, 2022 He did a great job on a 1955 DS M3 given to me after decades stored in a Texas attic - needed new curtains and a lot of work. He has also serviced several of my Japanese ltm clones and lenses. As mentioned, at times he has suggested I send to DAG instead. Link to post Share on other sites More sharing options...
malligator Posted May 21, 2022 Share #12 Posted May 21, 2022 I hope he has an intern (or interns) working under him. It would be a shame to lose all of his knowledge and ability when he starts his well-deserved retirement. Link to post Share on other sites More sharing options...
tappan Posted May 21, 2022 Share #13 Posted May 21, 2022 (edited) This is GREAT! I have sat at that kitchen table. He and his wife are MASTER technicians. Thank you Julien Jarry for producing this, and the poster for posting it. Mark Edited May 21, 2022 by tappan Poster did not produce, so I changed to "Julien Jarry" Link to post Share on other sites More sharing options...
logan2z Posted May 21, 2022 Author Share #14 Posted May 21, 2022 (edited) 6 minutes ago, tappan said: Thank you for producing this, and posting it. I can only take credit for posting it, I had no hand in producing it. But I'm glad everyone is enjoying it. Edited May 21, 2022 by logan2z 2 Link to post Share on other sites More sharing options...
CosmoM3 Posted May 21, 2022 Share #15 Posted May 21, 2022 Great guy. He brought life to my Lux 50mm V1 (1958) after a very thorough CLA. Link to post Share on other sites More sharing options...
kivis Posted May 22, 2022 Share #16 Posted May 22, 2022 Loved it. Reminds me of my former life as a Nikon F (no meter) owner. Down here was a guy named Pete Smith, the Nikon Smith. He had over 300 Nikon F's he used for parts, swaps, repairs, etc. These guys are a special bunch. Link to post Share on other sites More sharing options...
caloosajo Posted May 22, 2022 Share #17 Posted May 22, 2022 Awesome. A happier version of when Dorothy meets the Wizard. Youxin just gets it done, plain and simple. 1 Link to post Share on other sites More sharing options...
Topsy Posted May 22, 2022 Share #18 Posted May 22, 2022 On 5/21/2022 at 2:10 AM, logan2z said: I figured this would be most applicable on this forum. Moderators, please move if there's a more appropriate spot... Just watched it, great, thanks for posting the link. 👍 1 Link to post Share on other sites More sharing options...
bdolzani Posted May 27, 2022 Share #19 Posted May 27, 2022 Fantastic to see him and his space. I've been using him for years, just wonderful always. thanks for posting!! 1 Link to post Share on other sites More sharing options...
colint544 Posted May 28, 2022 Share #20 Posted May 28, 2022 That was wonderful - thank you for putting it up. 1 Link to post Share on other sites More sharing options...
