SJH Posted May 17, 2022 Share #1 Posted May 17, 2022 Advertisement (gone after registration) Given all the comments about getting sharp images with a 60mb sensor and no IBIS, I thought this Leica video should be interesting to many in that it proposes that the M11 should be set to 4 x fl as a minimum shutter speed. Interesting even for 50mm lenses in low light at 1/200th. Personally I've used my M11 at say 1/125th with a 50mm lens for example (or as low as 1/30th with a reasonable hit rate) and been fine but I think it's interesting that this video has appeared around only 2 'myths'!! 1 1 Link to post Share on other sites More sharing options...
Advertisement Posted May 17, 2022 Posted May 17, 2022 Hi SJH, Take a look here Leica YouTube Video implies the M11 requires 4 x fl shutter speed minimum. I'm sure you'll find what you were looking for!
SrMi Posted May 17, 2022 Share #2 Posted May 17, 2022 This video has been discussed before, probably in the long thread "Problems getting sharp images by 60MP". AFAICR, the conclusion was that handholding speed vary by photographer. 1 Link to post Share on other sites More sharing options...
FlashGordonPhotography Posted May 17, 2022 Share #3 Posted May 17, 2022 You and I do not need to hold a camera at the same ratio of shutter speed. We are different. It’s up to you to learn what you are capable of. There is no set number. Gordon 1 1 Link to post Share on other sites More sharing options...
SJH Posted May 17, 2022 Author Share #4 Posted May 17, 2022 Thanks all I hadn't seen that post re the video. Link to post Share on other sites More sharing options...
adan Posted May 18, 2022 Share #5 Posted May 18, 2022 I've had my 24-Mpixel plain M10 set to 4x from the beginning. Reason - subject motion. I like to photograph people doing stuff - I leave motionless-subject pictures to the morticians. Even 4x is often not enough with wide angles (4 x 21mm = 1/84th sec) - so I've taken to manually setting the shutter dial to 1/250th or higher when using auto-ISO. 2 1 Link to post Share on other sites More sharing options...
PhoToad Posted May 18, 2022 Share #6 Posted May 18, 2022 To avoid blur from camera shake, Jesko von Oeynhausen (Global Director Product Division Photo with Leica) has recommended 1/4f already with the introduction of the M10-R. 1 Link to post Share on other sites More sharing options...
hdmesa Posted May 18, 2022 Share #7 Posted May 18, 2022 Advertisement (gone after registration) M11: 1/4f works well right after several cups of coffee -|- 1/2f is fine most of the time -|- 1/1f may require exceptional technique 2 Link to post Share on other sites More sharing options...
PhoToad Posted May 19, 2022 Share #8 Posted May 19, 2022 << M11: 1/4f works well right after several cups of coffee -|- 1/2f is fine most of the time -|- 1/1f may require exceptional technique >> Maybe; I am not up to putting others' abilities into question. But if I was to consider purchasing an M11, I would rather trust the caveat from a knowledgable Leica expert than individual experiences. Link to post Share on other sites More sharing options...
SJH Posted May 19, 2022 Author Share #9 Posted May 19, 2022 (edited) I find the the new M11 grip helps at times. Didn’t really bother with my M10R but proves useful in some cases with the new camera and it goes straight onto my Peak Design tripod for example if needed. Edited May 19, 2022 by SJH 1 Link to post Share on other sites More sharing options...
lct Posted May 19, 2022 Share #10 Posted May 19, 2022 21 hours ago, hdmesa said: M11: 1/4f works well right after several cups of coffee -|- 1/2f is fine most of the time -|- 1/1f may require exceptional technique Mainly 1/2f or 1/3f for me but i often do click-click-click to keep one shot out of three. May help people with less than rock solid hands in low light. Here handheld at 1/20s (M11, 50/2 v4, f/2, 6400iso, FF and 100% crop). Welcome, dear visitor! As registered member you'd see an image here… Simply register for free here – We are always happy to welcome new members! Link to post Share on other sites Simply register for free here – We are always happy to welcome new members! ' data-webShareUrl='https://www.l-camera-forum.com/topic/332526-leica-youtube-video-implies-the-m11-requires-4-x-fl-shutter-speed-minimum/?do=findComment&comment=4438068'>More sharing options...
tom0511 Posted May 20, 2022 Share #11 Posted May 20, 2022 (edited) My practise is to use 1/250 as a standard (helps also to avoid motion blur from my kids etc.) However if the light gets lower and I have to crank up ISO too much I do not hesistate to go 1/125 (for 28-50mm), or even 1/60 if necessary. And to be honest, even if there is the slightest blur when zooming in 100%, many images still look fine at normal viewing size. And usually the images in lower light are not the ones where I would need super crisp small details, its more friends at the table, kids at the fire camp,... So I have the "blurr" thing of high MP in mind, but I just try to find the best comromise and I have not felt limited by this in any ways. Edited May 20, 2022 by tom0511 Link to post Share on other sites More sharing options...
