FrankX Posted May 14, 2022 Share #41 Posted May 14, 2022 Advertisement (gone after registration) Gerade eben schrieb SrMi: I had previously good response from technicalinfo@leicacamerausa.com. Thanks! However, a contact in Wetzlar would be easier for me as I am living in Germany! Link to post Share on other sites More sharing options...
Advertisement Posted May 14, 2022 Posted May 14, 2022 Hi FrankX, Take a look here In-camera M11 Monochrome JPEGs. I'm sure you'll find what you were looking for!
hdmesa Posted May 14, 2022 Author Share #42 Posted May 14, 2022 2 hours ago, SrMi said: What was Leica's response? I'm still thinking about how to write this up in a manner in which makes sense and won't be dismissed out of hand. Maybe I just point them to this thread. It usually takes them 4-5 days to respond to the inquires I send to their "info" address, not sure about the tech one (thanks for putting that in a recent post). Link to post Share on other sites More sharing options...
SrMi Posted May 14, 2022 Share #43 Posted May 14, 2022 1 minute ago, hdmesa said: I'm still thinking about how to write this up in a manner in which makes sense and won't be dismissed out of hand. Maybe I just point them to this thread. It usually takes them 4-5 days to respond to the inquires I send to their "info" address, not sure about the tech one (thanks for putting that in a recent post). Yes, it helps to write it up in a clear and simple way. It takes time to do that, appreciate you taking it. Maybe point them to this thread once initial description of the problem has been accepted. 1 Link to post Share on other sites More sharing options...
hdmesa Posted May 14, 2022 Author Share #44 Posted May 14, 2022 47 minutes ago, tashley said: After this thread, and the one where the troll guy got banned, I got to thinking about my assertion that I never shoot in-camera JPEg other than as a backup and that I therefore have no idea, or interest in what the in-camera B&W looks like - though I do accept that it matters for some and that it therefore should be given some attention by Leica. So I thought I'd set the camera to shoot DNG+JPEG and set the film style to B&W Nat/=. I then set myself the challenge of not looking at the JPEGS until I had finished processing the DNGs to B&W to my taste. I then applied the crop from the DNG to the JPEG and exported them both per forum rules in order to see what they looked like side by side. I make no comments as to whether this is a useful exercise or whether the results demonstrate anything but here it is: DNG first in each case. Welcome, dear visitor! As registered member you'd see an image here… Simply register for free here – We are always happy to welcome new members! DNG almost always looks better provided you can edit thoughtfully in post. But you won't see the issue I've described unless you shoot with a wide-aperture M lens that has significant vignetting and you shoot it wide open and there is a good chunk of the corners with a continuous gradient tone background: 28 Lux shot at f/1.4 against a blue sky for example. This looks like you shot it with the lens stopped down a bit then added vignette in post. But maybe you were making a different point just about JPEG usefulness vs DNG. Link to post Share on other sites More sharing options...
tashley Posted May 14, 2022 Share #45 Posted May 14, 2022 2 minutes ago, hdmesa said: DNG almost always looks better provided you can edit thoughtfully in post. But you won't see the issue I've described unless you shoot with a wide-aperture M lens that has significant vignetting and you shoot it wide open and there is a good chunk of the corners with a continuous gradient tone background: 28 Lux shot at f/1.4 against a blue sky for example. This looks like you shot it with the lens stopped down a bit then added vignette in post. But maybe you were making a different point just about JPEG usefulness vs DNG. It was shot with a macro elmar 90mm at f4 so you’re right, not a lens that replicates your problems at all. As for making a point, I wasn’t! Link to post Share on other sites More sharing options...
hdmesa Posted May 14, 2022 Author Share #46 Posted May 14, 2022 44 minutes ago, FrankX said: Summilux 50 BC looks almost the same… 😕 I really hope that there will be a new firmware soon to correct this extremely strong vignetting! BTW, I still believe there is a more severe problem with the lens profiles. On the 47 MP SL2 both, the FLE35 and the 50 BC, perform much better than on the M10. Maybe due to some in-camera corrections using the Maestro 3 processor. However, with the M11 now both seem to significantly worse. Optical vignetting itself showing up more or less strongly in the DNGs across M and SL variants is something else. I know my 28 Lux vignettes strongly at f/1.4, and I'm ok with that – I just want the vignetting to be rendered correctly to the JPEGs like it is on the M10 and SL cameras. For what it's worth, Leica's vignetting correction via profiles has always been subtle – it will not remove the vignetting, that has to be done in LR/C1 to the DNGs in post. Link to post Share on other sites More sharing options...
hdmesa Posted May 14, 2022 Author Share #47 Posted May 14, 2022 Advertisement (gone after registration) Just now, tashley said: It was shot with a macro elmar 90mm at f4 so you’re right, not a lens that replicates your problems at all. As for making a point, I wasn’t! Your images do illustrate that editing the DNGs can creatively surpass the in-camera JPEGs But yeah, to see this issue I'm describing, you have to have what amounts to a gradient (vignetting) superimposed over a continuous-tone subject (sky gradient, wall of a building, etc.). 1 Link to post Share on other sites More sharing options...
hdmesa Posted May 14, 2022 Author Share #48 Posted May 14, 2022 1 hour ago, Cupbest said: Do you have a profile set? If not, what if you assign the 50f2 summicron profile? i have that lens. I love it. I've tried it with the 50 Cron profile and with no profile. But of course stopping down so that there is little optical vignetting negates the issue. You have to have strong vignetting to provoke the issue, and sometimes that strong vignetting is creatively what I want to be there, so I don't want it removed anyway. 2 hours ago, Photoworks said: did somebody contact Leica Germany support? Seams something they should look at. Not yet, but I plan to. Link to post Share on other sites More sharing options...
hdmesa Posted May 14, 2022 Author Share #49 Posted May 14, 2022 2 hours ago, charlesphoto99 said: Actually, if the post title or first post had said something about the jpeg driver affecting viewing the DNG's, as you did above, it would be more obvious what the overarching issue is. I don't have an 11, but will most likely someday (though probably more likely a used M12). I do find that Leica's are maybe getting ahead of themselves a bit. with the technology. Part of me would love to have a film MP style of digital M11 (with a screen though - that affectation I never got). No A mode, metering options, highlight protecting, live view, auto iso, electronic shutter etc etc. Instead just a pared down, central weighted meter, aperture and shutter speed only image making machine. JPEG rendering engine affects the view on the LCD and EVF on all mirrorless cameras – it's what generates the video feed that you see. That's not something unique to Leica and is not the problem in and of itself. I just mentioned it since I wanted to make the point that even someone who shoots DNG-only may still see and possibly be annoyed by the strange peephole-vignetting effect while shooting. Link to post Share on other sites More sharing options...
hdmesa Posted May 14, 2022 Author Share #50 Posted May 14, 2022 (edited) Nice blue sky today. This is probably the most dramatic demonstration of the issue – lens with heavy vignetting wide open against a blue sky. I think this is the example I'll send Leica. SOOC JPEG (VIV setting, no adjustments): Welcome, dear visitor! As registered member you'd see an image here… Simply register for free here – We are always happy to welcome new members! DNG processed in C1 with High Contrast profile and exported to JPEG (no adjustments except increased exposure slider a bit): Edited May 14, 2022 by hdmesa Link to post Share on other sites Simply register for free here – We are always happy to welcome new members! DNG processed in C1 with High Contrast profile and exported to JPEG (no adjustments except increased exposure slider a bit): ' data-webShareUrl='https://www.l-camera-forum.com/topic/332280-in-camera-m11-monochrome-jpegs/?do=findComment&comment=4435019'>More sharing options...
hdmesa Posted May 14, 2022 Author Share #51 Posted May 14, 2022 1 hour ago, SrMi said: Yes, it helps to write it up in a clear and simple way. It takes time to do that, appreciate you taking it. Maybe point them to this thread once initial description of the problem has been accepted. Email has been sent. Thanks for the encouragement to do so. Will report back with any response. 1 Link to post Share on other sites More sharing options...
Ktsa5239 Posted May 14, 2022 Share #52 Posted May 14, 2022 54 minutes ago, hdmesa said: Nice blue sky today. This is probably the most dramatic demonstration of the issue – lens with heavy vignetting wide open against a blue sky. I think this is the example I'll send Leica. SOOC JPEG (VIV setting, no adjustments): Welcome, dear visitor! As registered member you'd see an image here… Simply register for free here – We are always happy to welcome new members! DNG processed in C1 with High Contrast profile and exported to JPEG (no adjustments except increased exposure slider a bit): Thanks for emailing in about this, turns out after testing. I can replicated the exact same issue on my APO35 and 28cron but on the APO50 and 90cron it doesn't happen. No clue why that is though. And on the lenses that heavily vignettes, it's showing the vignetting even stopped down to f11. Link to post Share on other sites More sharing options...
hdmesa Posted May 14, 2022 Author Share #53 Posted May 14, 2022 10 minutes ago, Ktsa5239 said: Thanks for emailing in about this, turns out after testing. I can replicated the exact same issue on my APO35 and 28cron but on the APO50 and 90cron it doesn't happen. No clue why that is though. And on the lenses that heavily vignettes, it's showing the vignetting even stopped down to f11. That’s interesting. Sounds like a firmware glitch only affecting certain Leica M lenses and non-6-bit coded lenses. Link to post Share on other sites More sharing options...
aristotle Posted May 15, 2022 Share #54 Posted May 15, 2022 All very interesting. Some sort of glitch in the firmware that performs the lens compensation for JPEGs only? While I don't typically shoot JPEG, a bug is still a bug. I almost always use manual exposure, but for the times that I'd want autoexposure, I'd like it to work. Even if the display thing wasn't an issue, I can certainly understand complaining about the bug. Link to post Share on other sites More sharing options...
hdmesa Posted May 15, 2022 Author Share #55 Posted May 15, 2022 2 hours ago, aristotle said: All very interesting. Some sort of glitch in the firmware that performs the lens compensation for JPEGs only? While I don't typically shoot JPEG, a bug is still a bug. I almost always use manual exposure, but for the times that I'd want autoexposure, I'd like it to work. Even if the display thing wasn't an issue, I can certainly understand complaining about the bug. The issue can affect live view and playback in all exposure modes and even if you only shoot DNG. But it doesn't affect the DNG once imported into LR/C1. A lot of people won't notice the issue since it requires you 1) use a lens known to have heavy vignetting, 2) shoot that lens wide open, and 3) have a continuous tone background such as a blue sky. Link to post Share on other sites More sharing options...
tashley Posted May 15, 2022 Share #56 Posted May 15, 2022 7 hours ago, hdmesa said: The issue can affect live view and playback in all exposure modes and even if you only shoot DNG. But it doesn't affect the DNG once imported into LR/C1. A lot of people won't notice the issue since it requires you 1) use a lens known to have heavy vignetting, 2) shoot that lens wide open, and 3) have a continuous tone background such as a blue sky. As soon as the weather is nice again here and we get a deep blue sky, I'll try this with my 35 Lux. 1 Link to post Share on other sites More sharing options...
hdmesa Posted May 21, 2022 Author Share #57 Posted May 21, 2022 Will post again when I hear back from Leica: Quote ... Thank you for the pictures. I have forwarded your mail to our product management team and will get back to you as soon as I have more information. Best regards ... Link to post Share on other sites More sharing options...
Ktsa5239 Posted May 21, 2022 Share #58 Posted May 21, 2022 So I've went into the Leica Store Sydney to show them this issue but they said no one else has raised it. The problem for me is that even DNG files are showing strong vignetting. Here is the APO35 at f2 Welcome, dear visitor! As registered member you'd see an image here… Simply register for free here – We are always happy to welcome new members! Heres APO35 at f4 It improves alittle bit but not that much. They suggested I tried a regular 35mm summicron on the shelf and the difference is obvious. At f4 the regular 35 summicron has less vignetting. I wonder what is causing this ..... Link to post Share on other sites Simply register for free here – We are always happy to welcome new members! Heres APO35 at f4 It improves alittle bit but not that much. They suggested I tried a regular 35mm summicron on the shelf and the difference is obvious. At f4 the regular 35 summicron has less vignetting. I wonder what is causing this ..... ' data-webShareUrl='https://www.l-camera-forum.com/topic/332280-in-camera-m11-monochrome-jpegs/?do=findComment&comment=4438896'>More sharing options...
hdmesa Posted May 21, 2022 Author Share #59 Posted May 21, 2022 7 hours ago, Ktsa5239 said: So I've went into the Leica Store Sydney to show them this issue but they said no one else has raised it. The problem for me is that even DNG files are showing strong vignetting. Here is the APO35 at f2 Welcome, dear visitor! As registered member you'd see an image here… Simply register for free here – We are always happy to welcome new members! Heres APO35 at f4 It improves alittle bit but not that much. They suggested I tried a regular 35mm summicron on the shelf and the difference is obvious. At f4 the regular 35 summicron has less vignetting. I wonder what is causing this ..... Looks like normal vignetting to me. The issue I'm seeing has a much more abrupt separation between the vignetting's edge and the rest of the image – like looking through a peephole. If you want to really see it, use a lens like the 28 Lux at f/1.4. Link to post Share on other sites More sharing options...
hdmesa Posted May 23, 2022 Author Share #60 Posted May 23, 2022 Minor update: Leica has requested the original DNG for the example I provided, so I sent that plus two other DNG+JPEG sets that show the issue for their review. Link to post Share on other sites More sharing options...
