scott kirkpatrick Posted May 5, 2021 Share #1  Posted May 5, 2021 (edited) Advertisement (gone after registration) Yes. Here's an easy one -- the User profile interface doesn't work. I saved my profiles, uploaded them after the firmware upgrade, and they don't work. Each time I click on profiles in the quick menu, it comes up in "delete". So I run through the list (titles show correctly) and try to set one. When I check in the internal user profile, it doesn't show as Active. When I try to set them using the internal menu, that also does nothing. So it's broken. I'm using the SL2 as the standard, where all of these things work. Edited May 5, 2021 by scott kirkpatrick 2 Link to post Share on other sites More sharing options...
rim_light Posted May 5, 2021 Share #2 Â Posted May 5, 2021 Sorry to hear, but it works for me... Link to post Share on other sites More sharing options...
MediaFotografie Posted May 5, 2021 Share #3  Posted May 5, 2021 no good news - I can‘t belive this wasn‘t seen during the tests. Happy „only“ owning the SL2 non S 2 Link to post Share on other sites More sharing options...
scott kirkpatrick Posted May 5, 2021 Author Share #4  Posted May 5, 2021 39 minutes ago, rim_light said: Sorry to hear, but it works for me... Do you shift between several profiles? When you touch or click on the profile icon in the quick meny, what do you see?  Link to post Share on other sites More sharing options...
rim_light Posted May 5, 2021 Share #5  Posted May 5, 2021 1 hour ago, scott kirkpatrick said: Do you shift between several profiles? When you touch or click on the profile icon in the quick meny, what do you see?  I see the different icons for selecting the other profiles and can switch. So everything works as it should. Link to post Share on other sites More sharing options...
Photoworks Posted May 5, 2021 Share #6 Â Posted May 5, 2021 I used to have it on the SL2 first firmware. I full reset fixed it. you just need to rebuild the profiles.. Link to post Share on other sites More sharing options...
scott kirkpatrick Posted May 6, 2021 Author Share #7  Posted May 6, 2021 (edited) Advertisement (gone after registration) I'll give that a try, but I am not looking forward to the half hour that I have to spend to get all the things reset (copyright, file extension, ...) that the profiles don't preserve. Edit: (half hour later)  Did a reset (installing the firmware was already one reset). Problem improved only slightly. Now I can set "default" from the quick menu, and the quick menu shows that profile, but only the names of the other profiles that are stored. When I go to the inside menu, the default profile shows as active. I cannot set any other profile as active on the inside or from the quick menu. SO IT IS A BUG. (This doesn't happen on my SL2, either.) Second edit (which did not post, a few hours ago) I finally did all the things that are needed to get the quickmenu profile selection and display to work. It's not so easy. First I did a total reset (aargh!), then I "re-imported" the profiles. Then I "saved" each profile , which probably stores them deeper in the camera's nonvolatile memory. Now the profiles can be selected from either menu and will display (with their number) when you press "menu" once. The SL2 and the SL2S user manual tellsyou that a reset is required to make a profile go away, but do not explain the two steps needed to make a restored profile work in the camera. So it is a bug, but Leica may consider a documentation bug, which doesn't really count to them. Edited May 6, 2021 by scott kirkpatrick Link to post Share on other sites More sharing options...
scott kirkpatrick Posted May 6, 2021 Author Share #8  Posted May 6, 2021 (edited) 17 hours ago, rim_light said: I see the different icons for selecting the other profiles and can switch. So everything works as it should. OK, see post above. (Oops, it didn't post, but now my conclusions are updated. -- I agree with rim_light, but think this is not documented correctly, and even if you do the right thing, is far too fussy.) Edited May 6, 2021 by scott kirkpatrick Link to post Share on other sites More sharing options...
rim_light Posted May 6, 2021 Share #9  Posted May 6, 2021 6 hours ago, scott kirkpatrick said: Did a reset (installing the firmware was already one reset). I know that your are a responsible owner of the Leica cameras and that you work elaborated, but I had an odd error on my SL2. I had to reset it twice until it was gone. Just as an idea what else could help Link to post Share on other sites More sharing options...
LocalHero1953 Posted May 6, 2021 Share #10  Posted May 6, 2021 (edited) I have similar gripes with the user profile, as reported above. And yes, I also did a factory reset. Yes, I realise you can embed those user profiles by 'saving' them, but when you restart the camera, the quick start menu does not show the profile you previously selected. It remembers the settings (or appears to - see my last para below), but does not display the profile number. If anyone has anything other than a SL2-S with f/w v2.0, can they report its behaviour? Did the SL or SL2 remember the profile you selected before switching off and display it in the quickstart menu. One of my profiles was for video; reloading it is incomplete - it shows as a Photo setting, and when I switch to Video it shows as P-mode, not M-mode as set in the profile. Also, previous versions of the SL2-S f/w certainly remembered that I was in a 'Video' profile when I restarted. In the current version it doesn't - it drops me back to 'Photo'. I've lost trust that the SL2-S actually recalls ALL the profile settings after a restart.😒 Edited May 6, 2021 by LocalHero1953 Link to post Share on other sites More sharing options...
SJH Posted May 6, 2021 Share #11  Posted May 6, 2021 1 hour ago, LocalHero1953 said: I have similar gripes with the user profile, as reported above. And yes, I also did a factory reset. Yes, I realise you can embed those user profiles by 'saving' them, but when you restart the camera, the quick start menu does not show the profile you previously selected. It remembers the settings (or appears to - see my last para below), but does not display the profile number. If anyone has anything other than a SL2-S with f/w v2.0, can they report its behaviour? Did the SL or SL2 remember the profile you selected before switching off and display it in the quickstart menu. One of my profiles was for video; reloading it is incomplete - it shows as a Photo setting, and when I switch to Video it shows as P-mode, not M-mode as set in the profile. Also, previous versions of the SL2-S f/w certainly remembered that I was in a 'Video' profile when I restarted. In the current version it doesn't - it drops me back to 'Photo'. I've lost trust that the SL2-S actually recalls ALL the profile settings after a restart.😒 I have the same issue on my SL2-S with v2 in that it doesn't show the Profile number selected in the Quick Menu or the active Profile in the Profiles Menu. I seem to remember that this functioned this way originally on both my SL2 and then my current SL2-S. It's annoying because when you come back to the camera it's not clear what Profile is actually set. 1 Link to post Share on other sites More sharing options...
stallus Posted May 6, 2021 Share #12  Posted May 6, 2021 Here is another minor bug: File Modification Date/Time is still wrong (+2h) in Leica SL2-S with FW 2.0. (Was also wrong in FW 1.0) This means: The file time stamp is +2 hours ahead of other Exif date/times like: Create Date, Date/Time Original, File Access Date/Time, File Inode Change Date/Time  checked with Exiftool Link to post Share on other sites More sharing options...
farnz Posted May 7, 2021 Share #13  Posted May 7, 2021 3 hours ago, stallus said: Here is another minor bug: File Modification Date/Time is still wrong (+2h) in Leica SL2-S with FW 2.0. (Was also wrong in FW 1.0)  Ah, so the SL2-S Time Travel function is still working? Good to know. Very useful for returning to catch a decisive moment that was narrowly missed. Pete. Link to post Share on other sites More sharing options...
msh58 Posted May 7, 2021 Share #14  Posted May 7, 2021 vor 17 Stunden schrieb scott kirkpatrick: OK, see post above. (Oops, it didn't post, but now my conclusions are updated. -- I agree with rim_light, but think this is not documented correctly, and even if you do the right thing, is far too fussy.) This discussion suddenly reminded me that to my knowledge Leica never changes the documentation (PDF manuals) to document exactly the functionality of the present version of the firmware. This should be pretty straightforward to do and would make many trial and error rounds unnecessary. Naturally, when the equipment was solely mechanical or not having any possibilities for upgrades, need to change the documentation was very rare. A bug can be turned into a feature by simply documenting it - Matti Link to post Share on other sites More sharing options...
LikameLeica Posted May 7, 2021 Share #15  Posted May 7, 2021 On 5/6/2021 at 5:17 PM, scott kirkpatrick said: I'll give that a try, but I am not looking forward to the half hour that I have to spend to get all the things reset (copyright, file extension, ...) that the profiles don't preserve. Edit: (half hour later)  Did a reset (installing the firmware was already one reset). Problem improved only slightly. Now I can set "default" from the quick menu, and the quick menu shows that profile, but only the names of the other profiles that are stored. When I go to the inside menu, the default profile shows as active. I cannot set any other profile as active on the inside or from the quick menu. SO IT IS A BUG. (This doesn't happen on my SL2, either.) Second edit (which did not post, a few hours ago) I finally did all the things that are needed to get the quickmenu profile selection and display to work. It's not so easy. First I did a total reset (aargh!), then I "re-imported" the profiles. Then I "saved" each profile , which probably stores them deeper in the camera's nonvolatile memory. Now the profiles can be selected from either menu and will display (with their number) when you press "menu" once. The SL2 and the SL2S user manual tellsyou that a reset is required to make a profile go away, but do not explain the two steps needed to make a restored profile work in the camera. So it is a bug, but Leica may consider a documentation bug, which doesn't really count to them. I took these same steps as recommended in the 2nd edit and it took care of the problem.  An extra, 5 minutes of work, but annoying none the less. Link to post Share on other sites More sharing options...
LikameLeica Posted May 7, 2021 Share #16  Posted May 7, 2021 12 hours ago, LikameLeica said: I took these same steps as recommended in the 2nd edit and it took care of the problem.  An extra, 5 minutes of work, but annoying none the less. After spending more time with the camera after taking these steps, I have discovered that yes the Profiles show the proper profile # in the quick menu and switch as I change profiles, however the actual customized setting that I had taken substantial time thinking through and setting up have been lost.  I am now having to reset manually all the customized setting in the profiles.  Having been an owner of the original SL, I recall a similar issue with firmware upgrades not retaining profile settings properly after a firmware upgrade.  Would be nice if this gets addressed in future upgrades.  Link to post Share on other sites More sharing options...
stallus Posted September 23, 2021 Share #17  Posted September 23, 2021 Am 6.5.2021 um 22:38 schrieb stallus: Here is another minor bug: File Modification Date/Time is still wrong (+2h) in Leica SL2-S with FW 2.0. (Was also wrong in FW 1.0) This means: The file time stamp is +2 hours ahead of other Exif date/times like: Create Date, Date/Time Original, File Access Date/Time, File Inode Change Date/Time  checked with Exiftool This bug is still present in Firmware 2.1 ! Leica should open a public bugtracker for firmware revisions! Then all users could report bugs or feature requests.  regards Reiner Link to post Share on other sites More sharing options...
SrMi Posted September 23, 2021 Share #18 Â Posted September 23, 2021 1 hour ago, stallus said: This bug is still present in Firmware 2.1 ! Leica should open a public bugtracker for firmware revisions! Then all users could report bugs or feature requests. Â regards Reiner My SL2-S does not have that issue. The file stamp is the same as the EXIF date/times. Can anyone reproduce the issues reported by stallus? Maybe there is an issue with your OS? Â Link to post Share on other sites More sharing options...
stallus Posted September 23, 2021 Share #19  Posted September 23, 2021 vor 39 Minuten schrieb SrMi: My SL2-S does not have that issue. The file stamp is the same as the EXIF date/times. Can anyone reproduce the issues reported by stallus? Maybe there is an issue with your OS?  What shows exiftool with your DNG files? Below is a sample of my DNG exifdata (with exiftool). Wrong timestamp is marked red, Correct time is marked green. Best regards Reiner  exiftool L1000372.DNG  ExifTool Version Number        : 12.30 File Name                      : L1000372.DNG Directory                      : . File Size                      : 43 MiBFile Modification Date/Time    : 2021:09:24 00:52:15+02:00 File Access Date/Time          : 2021:09:24 00:52:14+02:00 File Inode Change Date/Time    : 2021:09:24 00:52:15+02:00 File Permissions               : -rwxr-xr-x File Type                      : DNG File Type Extension            : dng MIME Type                      : image/x-adobe-dng Exif Byte Order                : Little-endian (Intel, II) Make                           : LEICA CAMERA AG Camera Model Name              : LEICA SL2-S Orientation                    : Horizontal (normal) Software                       : 2.12Modify Date                    : 2021:09:23 22:52:15 Artist                         : Image Width                    : 6048 Image Height                   : 4048 Bits Per Sample                : 14 Compression                    : Uncompressed Photometric Interpretation     : Color Filter Array Strip Offsets                  : 1933312 Samples Per Pixel              : 1 Rows Per Strip                 : 4048 Strip Byte Counts              : 42844160 X Resolution                   : 300 Y Resolution                   : 300 Resolution Unit                : inches CFA Repeat Pattern Dim         : 2 2 CFA Pattern 2                  : 0 1 1 2 CFA Layout                     : Rectangular Black Level Repeat Dim         : 2 2 Black Level                    : 515 514 515 516 White Level                    : 16383 Default Crop Origin            : 12 24 Default Crop Size              : 6000 4000 Bayer Green Split              : 0 Anti Alias Strength            : 0.7 Best Quality Scale             : 1 Raw Data Unique ID             : 74010F34161709E507FDE15500000000 Active Area                    : 0 0 4048 6024 Opcode List 1                  : FixBadPixelsConstant Opcode List 3                  : WarpRectilinear Default User Crop              : 0 0 1 1 Preview Image Start            : 1816064 Preview Image Length           : 117248 Subfile Type                   : Reduced-resolution image Jpg From Raw Start             : 102400 Jpg From Raw Length            : 1713664 About                          : Leica Camera AG Rating                         : 0 Copyright                      : Exposure Time                  : 1/13 F Number                       : 4.0 Exposure Program               : Aperture-priority AE ISO                            : 6400 Sensitivity Type               : Standard Output Sensitivity Standard Output Sensitivity    : 6400 Exif Version                   : 0231Date/Time Original             : 2021:09:23 22:52:15 Create Date                    : 2021:09:23 22:52:15 Offset Time                    : +02:00 Offset Time Original           : +02:00 Offset Time Digitized          : +02:00 Components Configuration       : Y, Cb, Cr, - Exposure Compensation          : 0 Max Aperture Value             : 2.8 Metering Mode                  : Other Light Source                   : Unknown Flash                          : Off, Did not fire Focal Length                   : 65.0 mm Serial Number                  : 5628413 Original File Name             : L1000372.DNG Original Directory             : 100LEICA Focus Distance                 : 3.33 m File Index                     : 372 Film Mode                      : WB RGB Levels                  : 0.8284789644 1 0.3184079602 Internal Serial Number         : (XEL) 2020:11:08 no. 0039 Flashpix Version               : 0100 Color Space                    : sRGB Exif Image Width               : 6048 Exif Image Height              : 4048 Sensing Method                 : One-chip color area File Source                    : Digital Camera Custom Rendered                : Normal White Balance                  : Auto Digital Zoom Ratio             : undef Focal Length In 35mm Format    : 65 mm Scene Capture Type             : Standard Contrast                       : Normal Saturation                     : Normal Sharpness                      : Normal Lens Info                      : 28-70mm f/3 Lens Make                      : SIGMA Lens Model                     : 28 - 70mm F2.8 DG DN | Contemporary 021 Lens Serial Number             : 5649576 DNG Version                    : 1.4.0.0 DNG Backward Version           : 1.3.0.0 Unique Camera Model            : LEICA SL2-S Localized Camera Model         : LEICA SL2-S Color Matrix 1                 : 1.0946 -0.4156 0.0254 -0.487 1.4366 0.3355 -0.0791 0.1776 0.7477 Color Matrix 2                 : 0.7275 -0.198 -0.0514 -0.4369 1.1949 0.2302 -0.127 0.2137 0.5473 As Shot Neutral                : 0.8284789644 1 0.3184079602 Baseline Exposure              : 0 Baseline Noise                 : 1 Baseline Sharpness             : 1 Linear Response Limit          : 1 Camera Serial Number           : 5628413 Maker Note Safety              : Unsafe Calibration Illuminant 1       : Standard Light A Calibration Illuminant 2       : D50 Aperture                       : 4.0 Blue Balance                   : 0.318408 CFA Pattern                    : [Red,Green][Green,Blue] Image Size                     : 6048x4048 Jpg From Raw                   : (Binary data 1713664 bytes, use -b option to extract) Megapixels                     : 24.5 Preview Image                  : (Binary data 117248 bytes, use -b option to extract) Red Balance                    : 0.828479 Scale Factor To 35 mm Equivalent: 1.0 Shutter Speed                  : 1/13Create Date                    : 2021:09:23 22:52:15+02:00 Date/Time Original             : 2021:09:23 22:52:15+02:00 Modify Date                    : 2021:09:23 22:52:15+02:00 Circle Of Confusion            : 0.030 mm Depth Of Field                 : 0.62 m (3.05 - 3.67 m) Field Of View                  : 30.4 deg (1.81 m) Focal Length                   : 65.0 mm (35 mm equivalent: 65.0 mm) Hyperfocal Distance            : 35.15 m Light Value                    : 1.7 Lens ID                        : 28-70mm F2.8 DG DN | Contemporary 021  Link to post Share on other sites More sharing options...
frame-it Posted September 23, 2021 Share #20  Posted September 23, 2021 On 5/7/2021 at 9:59 AM, msh58 said: This discussion suddenly reminded me that to my knowledge Leica never changes the documentation (PDF manuals) to document exactly the functionality of the present version of the firmware. they did do that for the SL601, for a while then stopped Link to post Share on other sites More sharing options...
