acg69 Posted October 23, 2020 Share #1 Posted October 23, 2020 Advertisement (gone after registration) I am sure the answer is simple but I am not sure whether there has to be a hardware thing waiting to be activated by firmware update or whether it is 100% a firmware thing. Just asking:) Link to post Share on other sites More sharing options...
Advertisement Posted October 23, 2020 Posted October 23, 2020 Hi acg69, Take a look here Is multishot possible for the Q2 with a future firmware upgrade? . I'm sure you'll find what you were looking for!
tom.w.bn Posted October 23, 2020 Share #2 Posted October 23, 2020 The simple answer is: no. The Q2 has no moving sensor, you need that for multishot. Image stabilization in the Q2 is done via optical image stabilization in the lens. 3 3 Link to post Share on other sites More sharing options...
acg69 Posted October 26, 2020 Author Share #3 Posted October 26, 2020 ΟΚ, Ι guess that settles that:) Link to post Share on other sites More sharing options...
SrMi Posted October 27, 2020 Share #4 Posted October 27, 2020 In theory, it would be possible without moving the sensor, as it is likely done in Pentax and Olympus cameras (hand-held high-resolution mode). Instead of shifting the sensor, the camera uses slight shifts in camera position (hand-held). I doubt it would be added in Q2. You can also do it in the post: https://www.dpreview.com/articles/0727694641/here-s-how-to-pixel-shift-with-any-camera Link to post Share on other sites More sharing options...
pibitller Posted October 30, 2020 Share #5 Posted October 30, 2020 Technically it has to be possible: it has to be the same to move the CMOS a few microns in two directions as the movement of a few millimeters (per meter of distance to the subject) in two directions of the subject and environment, and to develop the software for the treatment of the images... I think moving the camera is not a good idea, as it changes the point of view... Link to post Share on other sites More sharing options...
tom.w.bn Posted October 31, 2020 Share #6 Posted October 31, 2020 I thought we are talking about using the highres mode for high quality shots. This requires a tripod and with a tripod the only thing that can move is the sensor. The other options are hit or miss. Link to post Share on other sites More sharing options...
scott kirkpatrick Posted October 31, 2020 Share #7 Posted October 31, 2020 (edited) Advertisement (gone after registration) I worked on a multi-shot application back in the 1990s. The idea was to get increased resolution when scanning in business cards held in your hand and captured with the bezel camera of your laptop (yes there were laptops with cameras back that far into the dawn of imaging). You just save enough images to get some spread and then average them, or combine them in some more clever way. It's called super-resolution and is a very old idea. As with multi-shot sub-pixel resolution, it never worked as well as we had hoped, but it works. I suspect that every time you capture a bar code or QR code with your phone you are using some similar averaging algorithm to separate the signal from surrounding noise. Edited October 31, 2020 by scott kirkpatrick 1 Link to post Share on other sites More sharing options...
Pelu2010 Posted September 2, 2021 Share #8 Posted September 2, 2021 Hey, you can do it manually [ 😉 ] If you would like to make the effort. And if someone writes a script for photoshop then it´s even easier. You could get 150 to 200 mpx. But you only need it if your work is presented like this: https://www.derbelight.com Or if you plan a mpx website. 1 Link to post Share on other sites More sharing options...
Ba Erv Posted September 2, 2021 Share #9 Posted September 2, 2021 (edited) With LR’s recent updates its also possible to just use Enhance and Super Resolution option without all the other fiddling to get an equivalent higher pixel image. I haven’t tested this method with the Q2 but I have compared it with Multi-shot in the SL2-S and see no significant difference in image quality. I think the LR algorithm is equal to or perhaps even slightly better than the in-camera Multi-shot in some scenes. Unfortunately, LR doesn’t support the Q2Mono sensor for the Enhance function. The Super Resolution option is supported but I found the results undesirable with horrible areas of pixelation. Edited September 2, 2021 by Ba Erv Link to post Share on other sites More sharing options...
acg69 Posted September 2, 2021 Author Share #10 Posted September 2, 2021 16 minutes ago, Ba Erv said: With LR’s recent updates its also possible to just use Enhance and Super Resolution option without all the other fiddling to get an equivalent higher pixel image. I haven’t tested this method with the Q2 but I have compared it with Multi-shot in the SL2-S and see no significant difference in image quality. I think the LR algorithm is equal to or perhaps even slightly better than the in-camera Multi-shot in some scenes. Unfortunately, LR doesn’t support the Q2Mono sensor for the Enhance function. The Super Resolution option is supported but I found the results undesirable with horrible areas of pixelation. I tried it once on my MacBook Pro (retina, older model) and it took an eternity and a half... Never tried it again:/ Link to post Share on other sites More sharing options...
Ba Erv Posted September 2, 2021 Share #11 Posted September 2, 2021 2 hours ago, acg69 said: I tried it once on my MacBook Pro (retina, older model) and it took an eternity and a half... Never tried it again:/ I’m on a new MacBook M1 so it only takes 7 seconds to process. Link to post Share on other sites More sharing options...
charles tay Posted September 5, 2021 Share #12 Posted September 5, 2021 On 9/2/2021 at 1:58 PM, Pelu2010 said: Hey, you can do it manually [ 😉 ] If you would like to make the effort. And if someone writes a script for photoshop then it´s even easier. You could get 150 to 200 mpx. But you only need it if your work is presented like this: https://www.derbelight.com Or if you plan a mpx website. Thanks for sharing. 1 Link to post Share on other sites More sharing options...
Pelu2010 Posted March 21, 2022 Share #13 Posted March 21, 2022 I gutes Dung this manually is just if you really want or need to get a higher resolution. It would be great if we could get pixel shifting (no matter how they do it) in the q2. I just don't see the point why not. Link to post Share on other sites More sharing options...
