Cayenne Posted November 16, 2020 Share #41 Posted November 16, 2020 Advertisement (gone after registration) On 11/14/2020 at 4:19 PM, Raymondl said: I am getting confused by this. CA - chromatic aberrations also appears on the Leica 50mm 0.95 noc (source - https://jerrybei.com/reviews/tag/Noctilux) it also appears on the 50mm summilux APSH (source - https://www.imaging-resource.com/lenses/leica/50mm-f1.4-summilux-m-asph./review/ noting that its minor) if you want to avoid all forms of chromatic aberrations my suggestion is to use the LEICA 50mm APO (source - https://www.leicaboutique-ce.com.au/leica-aposummicronm-50mm-f2-asph-lens) Just for context. IMHO CA is a pain but it’s easily removed in digital, yes there is a drop in resolution but it’s something I can personally live with. But just thinking more. You cannot remove CA from an pure greyscale image, right? With no color, the development software wouldn't know what to "fix"...is this correct? C Link to post Share on other sites More sharing options...
Advertisement Posted November 16, 2020 Posted November 16, 2020 Hi Cayenne, Take a look here TTArtisan 50mm 0.95 review. I'm sure you'll find what you were looking for!
Raymondl Posted November 16, 2020 Share #42 Posted November 16, 2020 27 minutes ago, Cayenne said: But just thinking more. You cannot remove CA from an pure greyscale image, right? With no color, the development software wouldn't know what to "fix"...is this correct? C Depending on the CA for a greyscale image and the scene. But generally you might need to use photoshop to remove this - example: https://community.adobe.com/t5/photoshop/how-to-remove-black-aberation-fringe-in-a-black-white-photograph/td-p/8954653?page=1 might be better to ask the monochrome section in this forum for tips and tricks. 1 Link to post Share on other sites More sharing options...
BrianS Posted November 17, 2020 Share #43 Posted November 17, 2020 (edited) On 11/13/2020 at 5:24 PM, Cayenne said: What are your thoughts on shooting this lens purely on a monochrom? Would the chromatic aberrations be less of a problem since it is purely B&W or would that just result in softer/fuzzier images? TIA, cayenne Chromatic Aberration will produce a soft image in a monochrome image, digital or film. Color images- you can post-process to reduce the effects of CA by scaling RGB image planes. Use a deep yellow or orange filter to eliminate most CA, longitudinal and lateral. This is with a 1934 Carl Zeiss Jena 5cm F2 Sonnar, wide-open on the M Monochrom. I had to go back and check which lens was used for this image- then realized why it was so much sharper, I had left the orange filter on it. I keep a deep yellow filter on the 7Artisans 50/1.1 when using it on the M Monochrom. Much sharper images than what others seem to get. I have no complaints on the two that I have. Welcome, dear visitor! As registered member you'd see an image here… Simply register for free here – We are always happy to welcome new members! Edited November 17, 2020 by BrianS 2 1 Link to post Share on other sites Simply register for free here – We are always happy to welcome new members! ' data-webShareUrl='https://www.l-camera-forum.com/topic/312803-ttartisan-50mm-095-review/?do=findComment&comment=4081722'>More sharing options...
jakontil Posted November 17, 2020 Share #44 Posted November 17, 2020 Thanks flavio, very thorough reviews and unbiased cant you do anything with the close focus shifts even they provide the screw? Link to post Share on other sites More sharing options...
Harpomatic Posted November 17, 2020 Author Share #45 Posted November 17, 2020 On 11/15/2020 at 6:02 PM, Raymondl said: In my experience it’s always the inverse here. The CA is more prominent with you shoot wide open and usually reduces as you stop down to F8/11... and this what I have been taught anyhow reading online photography aids. BUT I started looking for lens reviews where they measure CA, and I found a “vintage” lens, where interestingly it shows the centre reduces CA as you stop down (expected), however the outer edges sees an increase in CA! Example: https://www.ephotozine.com/article/yashica-auto-yashinon-5-5cm-f-1-8-vintage-lens-review-34311/performance would be interesting to see the behaviour as you stop down for this lens. Ok, I stand corrected - I meant that the LaCA is a lot less disturbing in many of the wide open frames. This might be because the spherical aberration is masking it, the purple fringing is a lot stronger at wider apertures, I don’t know. But if you have a look at the series of shots with the tree branches for example the LaCA appears only 2-3 stops down from wide open, it’s masked before that. The lens is rendering in an interesting way wide open, it falls apart stopping down in my opinion. And at closer that 1.5-2m focus distance. And with focus distances above 2 meters. And it backfocuses up to 2cm at MFD. And...I don’t think it’s a good lens at all. It is nice focusing in a 50cm range only for me. I might be nitpicky... Link to post Share on other sites More sharing options...
Harpomatic Posted November 17, 2020 Author Share #46 Posted November 17, 2020 11 hours ago, jakontil said: Thanks flavio, very thorough reviews and unbiased cant you do anything with the close focus shifts even they provide the screw? Thank you! I have written a short article about the focus calibration and how that drove me mad because of that MFD issue. I short: nope. https://www.47-degree.com/focus-shift/calibrating-focus-on-the-ttartisan-50mm-095 Link to post Share on other sites More sharing options...
BrianS Posted November 17, 2020 Share #47 Posted November 17, 2020 Advertisement (gone after registration) 4 hours ago, Harpomatic said: Thank you! I have written a short article about the focus calibration and how that drove me mad because of that MFD issue. I short: nope. https://www.47-degree.com/focus-shift/calibrating-focus-on-the-ttartisan-50mm-095 I read your article- I suspect the focal length is too far off to focus properly across the full range. Adjusting the RF Cam is the same as shimming the lens, moves the entire optical block. This only works if the focal length of the lens agrees with the Cam of the lens used to link with the cameras rangefinder. Most classic normal lenses, the movement is 1:1 with the RF. The lens must be very close to the 51.6mm standard. If not- time to move elements around within the lens to make the effective focal length agree with the camera. I'm sticking with my 50/1.1 7Artisans lenses. I have them perfectly adjusted, one for the M9 and the second with a deep yellow filter for the M Monochrom. 1 Link to post Share on other sites More sharing options...
Harpomatic Posted November 17, 2020 Author Share #48 Posted November 17, 2020 48 minutes ago, BrianS said: I read your article- I suspect the focal length is too far off to focus properly across the full range. Adjusting the RF Cam is the same as shimming the lens, moves the entire optical block. This only works if the focal length of the lens agrees with the Cam of the lens used to link with the cameras rangefinder. Most classic normal lenses, the movement is 1:1 with the RF. The lens must be very close to the 51.6mm standard. If not- time to move elements around within the lens to make the effective focal length agree with the camera. Brian, it’s so interesting to read your contributions. I always learn something useful. Thanks! 1 Link to post Share on other sites More sharing options...
Cayenne Posted November 19, 2020 Share #49 Posted November 19, 2020 On 11/16/2020 at 6:25 PM, BrianS said: Chromatic Aberration will produce a soft image in a monochrome image, digital or film. Color images- you can post-process to reduce the effects of CA by scaling RGB image planes. Use a deep yellow or orange filter to eliminate most CA, longitudinal and lateral. This is with a 1934 Carl Zeiss Jena 5cm F2 Sonnar, wide-open on the M Monochrom. I had to go back and check which lens was used for this image- then realized why it was so much sharper, I had left the orange filter on it. I keep a deep yellow filter on the 7Artisans 50/1.1 when using it on the M Monochrom. Much sharper images than what others seem to get. I have no complaints on the two that I have. Welcome, dear visitor! As registered member you'd see an image here… Simply register for free here – We are always happy to welcome new members! OH thank you for the suggestion of the yellow/orange filters. I do already keep a yellow one on my current lens (the Ultron 35mm)....it isn't very dark, but I do have a much darker orange one...both are B&W.... If I get this lens, I might keep that orange one on it. Hmm....I'll see if there's one of these lenses out there to rent first to experiment with the filters. Thank you again...this is ALL very interesting to read here, I learn so much each day!! cayenne 1 Link to post Share on other sites More sharing options...
jakontil Posted November 21, 2020 Share #50 Posted November 21, 2020 On 11/17/2020 at 11:10 PM, Harpomatic said: Thank you! I have written a short article about the focus calibration and how that drove me mad because of that MFD issue. I short: nope. https://www.47-degree.com/focus-shift/calibrating-focus-on-the-ttartisan-50mm-095 Thanks flavio, i read throught it, and yeah it makes sense why it shifted... i guess you saved me from getting this lens... suffering from a focus shifts is something i cant live with from a lens 1 Link to post Share on other sites More sharing options...
Harpomatic Posted November 22, 2020 Author Share #51 Posted November 22, 2020 22 hours ago, jakontil said: Thanks flavio, i read throught it, and yeah it makes sense why it shifted... i guess you saved me from getting this lens... I will be honest, I was really looking forward to this lens and it really reiterated why I love small and high quality lenses. And more versatile! The TTArtisan is not versatile at all. The CV Nokton 50mm 1.2 is so much more value for money. 1 Link to post Share on other sites More sharing options...
cboy Posted November 22, 2020 Share #52 Posted November 22, 2020 Op im trying to think what possible practical use could 0.95 be? Apart from artistic or studio/tripod setups...whats the distance is depth of field? Link to post Share on other sites More sharing options...
Harpomatic Posted November 22, 2020 Author Share #53 Posted November 22, 2020 7 hours ago, cboy said: Op im trying to think what possible practical use could 0.95 be? Apart from artistic or studio/tripod setups...whats the distance is depth of field? Practical? None at all. Razor thin depth of field and you mince everything else into oblivion outside of the focus plane. I don’t think there is a real “need” for that speed, outside of obsessing about bokeh. Unless you shoot film/M8/M9 in pitch dark conditions and need the speed to expose the film/sensor. But this is a personal opinion. 1 Link to post Share on other sites More sharing options...
jdlaing Posted November 22, 2020 Share #54 Posted November 22, 2020 4 hours ago, Harpomatic said: But this is a personal opinion. Yes. It is. 1 Link to post Share on other sites More sharing options...
cboy Posted November 24, 2020 Share #55 Posted November 24, 2020 Anyhow thankyou Harpomatic for your review thats gives us great insights on the nature of this lens which you kindly shared to all in this forum. Much appreciated! 1 Link to post Share on other sites More sharing options...
Harpomatic Posted November 26, 2020 Author Share #56 Posted November 26, 2020 On 11/24/2020 at 8:21 PM, cboy said: Anyhow thankyou Harpomatic for your review thats gives us great insights on the nature of this lens which you kindly shared to all in this forum. Much appreciated! Thank you for your kind words. It gives me pleasure to know that my review can be helpful! Link to post Share on other sites More sharing options...
ZHNL Posted November 26, 2020 Share #57 Posted November 26, 2020 I bought the lens. It is an awesome piece. I can’t believe it can be sold at this price with such a wonderful performance at .95. I think it has slightly softer bokeh than Leica one actually. It was slightly back focus out of box. I adjusted it following instruction also YouTube instruction, it works at close distance after adjust, I haven’t test infinity yet. I didn’t test focus shift, I will mostly use it wide open between 0.7m and 3m. For stopdown shooting I have lux and APOcron. At around 3M, it is a challenge for perfect rangefinder focus anyway with lens this fast. 50noct, 75lux, 90APO, even 50lux, you name it. for lens like this using rangefinder, You need adjust your shooting habit. For fast glass rangefinder shooting, always focus from one direction, and trip the shutter as soon as patch meet or over-meet depend on your camera, lens and eye condition. I much prefer use it on SL2 or any MILC camera though. Just want neutralize the negative review and offer different opinion here. 1 1 Link to post Share on other sites More sharing options...
epand56 Posted November 29, 2020 Share #58 Posted November 29, 2020 Thank you for your very detailed review, Flavio. I was in the mood of buying this lens and you convinced me: I will, stick to my Summilux 50/1.4 Asph. However, would be interesting a twin review, made by you, of the Leica Noctilux 50/0.95. Just to see what's the added value of those 13 times more one should pay for it. Maybe somebody at Leica will lend you a sample for a coupe weeks 😉 Link to post Share on other sites More sharing options...
gmbmuc Posted November 29, 2020 Share #59 Posted November 29, 2020 Am 26.11.2020 um 02:49 schrieb ZHNL: I bought the lens. It is an awesome piece. I can’t believe it can be sold at this price with such a wonderful performance at .95. I think it has slightly softer bokeh than Leica one actually. It was slightly back focus out of box. I adjusted it following instruction also YouTube instruction, it works at close distance after adjust, I haven’t test infinity yet. I didn’t test focus shift, I will mostly use it wide open between 0.7m and 3m. For stopdown shooting I have lux and APOcron. At around 3M, it is a challenge for perfect rangefinder focus anyway with lens this fast. 50noct, 75lux, 90APO, even 50lux, you name it. for lens like this using rangefinder, You need adjust your shooting habit. For fast glass rangefinder shooting, always focus from one direction, and trip the shutter as soon as patch meet or over-meet depend on your camera, lens and eye condition. I much prefer use it on SL2 or any MILC camera though. Just want neutralize the negative review and offer different opinion here. +1 Link to post Share on other sites More sharing options...
Harpomatic Posted November 29, 2020 Author Share #60 Posted November 29, 2020 8 hours ago, epand56 said: Thank you for your very detailed review, Flavio. I was in the mood of buying this lens and you convinced me: I will, stick to my Summilux 50/1.4 Asph. However, would be interesting a twin review, made by you, of the Leica Noctilux 50/0.95. Just to see what's the added value of those 13 times more one should pay for it. Maybe somebody at Leica will lend you a sample for a coupe weeks 😉 Thank you, I have expressed my most honest and as unbiased opinions as possible. I really wanted to like the lens. I agreed that the comparison would be most interesting, but I have sold the lens and am concentrating on a new big review with other lenses. But I have to agree that staying with your Lux Asph is a great choice! 1 Link to post Share on other sites More sharing options...
