Some months back I supported a Kickstarter effort to produce a tiny light meter for old cameras, to be made in Canada. After some delays due to COVID, the first production is finished, and I received my unit today. It is easily the smallest and lightest light meter I've seen. The body is 3-D printed, but seems good quality. The control buttons are also tiny, but easier to use than I expected. Nice clear LCD display on the back. Works in either Aperture or Shutter priority. It calibrated easily to my Luna-Lux SBC and seems very accurate.
Here it is on a IIIf, where it works fine, although is very close to the shutter speed dial. On a model III or II it is too close, so the dial can't be lifted to set the speed.
Otherwise it is worth a look. The designer called the company REVENI LABS.
  • Thanks 2
Oops, forgot to attach pic. Here you go.
I contacted the owner (Matthew Bechberger) recently after watching the video (third down) at the website - got a swift reply
https://www.reveni-labs.com/
I'll probably order one in September (he's backordered with over 1000 units but items will be back in stock by end of August) - looking to be popular item
He also has other interesting items/accessories on his site ie a double hotshoe
Tom, thanks for the heads up re which cameras the lightmeter is best used with (I have a IIIa, IIIf & IIIg) - will work well with the latter two I presume
Here's a comparison of the VCII and Reveni for size. The VCII weighs 38 grams, and the Reveni only 8 grams.
I think in general the VCII is a better fit for ltm Leicas as it looks "right" on them, and the larger size and analog controls make operation intuitive and fast. The Reveni has 4 tiny push buttons to control everything. Push the front button and it displays a single fstop and speed - side buttons let you change the setting for the priority chosen so it displays the matching exposure. Everything else requires button pushes to configure the options, such as ISO, aperture/shutter priority, calibration, etc.
I suggested he offer a spacer to raise the unit enough to work on older Leica models before IIIc.
Edited by TomB_tx
The VC II is an excellent meter but I found an old Metrophot meter that has a lovely look and is a little smaller that the VC II (the Metrophot's rear is curved and makes it smaller) and needs no batteries because it has a Selenium metering cell.  The Metrophot looks marginally larger than the Reveni bans meter.
Leica also produced a "Leicaphot" Selenium meter but I haven't found one with where the Selenium cell is still working and sellers often ask ridiculously high prices.
Incidentally, the meters are not arranged that way to deceive about size, it was just to stand them up for the picture.
Pete.
This V-201X looks interesting too. It seems to sit a bit higher than the Reveni, which might make it possible to use the shutter speed dial on those earlier Leicas, and there's a metal version. The downside seems to be the OLED display, which according to one of the reviews is hard to read in bright light:
https://austerityphoto.co.uk/blinded-by-the-light-the-v-201x-light-meter-on-test/
https://johnnymartyr.wordpress.com/2020/03/05/upgrade-your-meterless-film-camera/
Well, the Voigtlander meter certainly cannot compete in the weight competition against the Reveni. On the other hand, it is an actual piece of metal and not something that came out of a 3D printer. (Not that that's a bad thing,. I guess.) I do confess that my problem with the Reveni is that (based on the photos here) it's so damned ugly and not in any way complimentary to the work of art that is an LTM Leica. Just my opinion, of course, and not meant to cast criticism on anyone who might choose to use it. And yes, Voigtlander still makes the VC II meter in both black and silver. You can get one brand new from B&H in New York City for $225.
  • 2 weeks later...
The Reveni arrived earlier this week and I've had the time to learn a few things for anyone who may be interested. Reveni recommends using the EV setting to adjust the meter to match your reference meter but they also offer a calibration mode. The EV can be adjusted from -2 to +2 EV in 1/3 stops. In the calibration mode, each stop is equivalent to .01 EV and is adjustable between -20 to +20. The best way to adjust the meter is with a gray card and a meter set to read EV. When the meter ships, a card is included to show where the calibration was set before shipping. The following images were exposed using the Reveni. The camera is a M4 with a Voigtlander Heilar 50 2.0 Collapsible, o22 yellow filter. The film is Kodak XX 5222 exposed at ISO 125 and developed in HC-110B for 4.5 minutes. The negatives were scanned with a Sony A7II using a Micro-Nikkor 55 2.8 Ai-S, PK-13 extension ring and a metabones Nikon F to Sony E adapter. The light source was a Skier Copybox and editing was done with RAW Power plug in for Apple Photos. The images were captured in RAW and the only editing was to add .33 EV. I really like my Sekonic meters, a 308 and a 398 but the little Reveni is convenient. The OLED display is easy to read even in bright sunlight, can be adjusted to stay on for between 5 and 30 seconds. No meter is perfect but the little Reveni is handy to have.
Edited by madNbad
I agree with "farnz" : the Leica-Meter 2 (seen in the image below in its leathher case) or similar Metraphot 2 or 3 are at the same time smaller and much more "elegant". And are usable on all Leicas without "too close speed dial" problems. I had many lightmeters in collection, but not the Voigtlander (not to speak of the Reveni...About this, I like the idea of the LCD screen that must ease the "reading").
  • Thanks 2
I also have a Leica Meter 3 in its leather case that is still quite accurate (thanks to the case that kept the selenium cell in the dark), and it is a jewel. However, the new small meters have a huge advantage in low-light capability.
Even on the M cameras, the Reveni overhangs the accessory shoe just a bit making it difficult to see the shutter speed mark. It's been a while since I've owned a IIIc but can see how it would interfere with changing the shutter speeds.
I have the VC II, but I prefer the Gossen Digisix shown on the left in this photo. It is small, you can wear it around your neck like a film director and point it in any direction with ease and it has an incident metering cone. The main point is that it will give a range of combinations to use, which is what I really want. The iPhone with the Pocket Light Meter App on the right is OK, but I prefer to have a range to choose from. Each to his/her own.
William
I went with the V-201X with black metal casing which arrived earlier today.  It is a perfect fit on my iif and is clear of the shutter dial.  A little testing shows good accuracy.  I personally like the top display as you would be normally looking down to adjust shutter speed and aperture.
Edited by JohnW.
Spelling
Hi John,
It's an interesting looking and useful light meter but it would live in my pocket since, in my opinion, it would spoil the look, lines, and metallic finish of my Leica screw mount cameras.
Pete.
1 hour ago, farnz said:
Hi John,
Pete.
Hi Pete,
I actually agree with you, perhaps the silver version would blend in better?.  Anyhow I think it looks better on the Canon P or Autocord and is much more convenient to carry around than my Sekonic meter or using a phone light meter app.
