otto.f Posted March 18, 2020 Share #21 Posted March 18, 2020 (edited) Advertisement (gone after registration) I owned the MR-4. Nice nostalgic piece, but not at all functional for me. Makes my M4 too big, has no incident metering possibility, let alone spotmetering, meter is often too old to be exact. I find it a very bad advise for someone who needs to have a far away building at the horizon well exposed. Nonsense. Edited March 18, 2020 by otto.f 1 Link to post Share on other sites More sharing options...
Advertisement Posted March 18, 2020 Posted March 18, 2020 Hi otto.f, Take a look here Handheld metering and far away objects. I'm sure you'll find what you were looking for!
philipus Posted March 20, 2020 Share #22 Posted March 20, 2020 Spot meters can be found for reasonable money on eBay and other places. One just has to look around a bit and do one's homework because their functions vary quite a lot. Just earlier this week I got this fairly little known spot meter, a Sekonic L-488 Digi-Spot which is a true 1 degree spot meter which also does average metering and flash metering. It isn't very big and it's also light. Here's the manual if you want to read up on how it works. It takes ordinary AA batteries, which was important for me. I intend to use it for more 'considered' photography, like landscape and cityscape (regardless of film format) but the average metering option will come in handy sometimes so I expect to bring it with me quite a bit. Welcome, dear visitor! As registered member you'd see an image here… Simply register for free here – We are always happy to welcome new members! Ultimately it is as you write a matter of finding out what works for you. My take on this important dictate is that in photography there is rarely one solution for everything. Good luck Philip On 2/27/2020 at 9:27 PM, phib said: It seems everyone has a different opinion how to meter so now I'm at the point that I think I just have to try things out and see what works for me 2 Link to post Share on other sites Simply register for free here – We are always happy to welcome new members! Ultimately it is as you write a matter of finding out what works for you. My take on this important dictate is that in photography there is rarely one solution for everything. Good luck Philip ' data-webShareUrl='https://www.l-camera-forum.com/topic/306862-handheld-metering-and-far-away-objects/?do=findComment&comment=3935507'>More sharing options...
tommonego@gmail.com Posted March 21, 2020 Share #23 Posted March 21, 2020 I have a Soligar spot meter, nice bought it in the late '70s early 80's still works, takes a 9 volt battery. Has a Kodak battery in it so it is been there for 20 years or so. The only issue is the case is a rubberized and has turned to gump. Worth a look, prices on Eb*y are $49 - $349, they are all 30 years old or so. Link to post Share on other sites More sharing options...
Stealth3kpl Posted March 22, 2020 Share #24 Posted March 22, 2020 (edited) This is a nice explanation of metering with a spot meter with the grey scale in mind seen on his web page here I have a lightweight Minolta Spot Meter F or something. I like it. If I want an idea of what an incident meter would read, I point the spot at my palm and open up an extra stop (I'm caucasian) Pete Edited March 22, 2020 by Stealth3kpl 1 Link to post Share on other sites More sharing options...
Pyrogallol Posted March 23, 2020 Share #25 Posted March 23, 2020 Decades ago I learned to meter off a tarmac road, gives you a greycard reading. Link to post Share on other sites More sharing options...
Stealth3kpl Posted March 23, 2020 Share #26 Posted March 23, 2020 14 minutes ago, Pyrogallol said: Decades ago I learned to meter off a tarmac road, gives you a greycard reading. But there are 50 shades of grey, I saw a book about it once. Pete 1 3 Link to post Share on other sites More sharing options...
250swb Posted March 24, 2020 Share #27 Posted March 24, 2020 Advertisement (gone after registration) 23 hours ago, Pyrogallol said: Decades ago I learned to meter off a tarmac road, gives you a greycard reading. But it should also be remembered that metering from anything is about reflectance, as in '18% reflectance' of the thing you are pointing your meter at, not its tone or colour. Which is why green grass is a standard recommendation, followed perhaps in less pc times by the palm of a Caucasian hand, but it's still an accurate measure. I wonder if there are any newer recommendations more universally applicable? Link to post Share on other sites More sharing options...
dau Posted March 24, 2020 Share #28 Posted March 24, 2020 9 minutes ago, 250swb said: palm of a Caucasian hand, Any human hand will do, as palms usually are but sparingly pigmented. 1 Link to post Share on other sites More sharing options...
Reini Posted March 24, 2020 Share #29 Posted March 24, 2020 Am 26.2.2020 um 20:45 schrieb phib: I'm tired of using my phone The Light Meter app has a zoom funktion. Link to post Share on other sites More sharing options...
Stealth3kpl Posted March 24, 2020 Share #30 Posted March 24, 2020 1 hour ago, dau said: Any human hand will do, as palms usually are but sparingly pigmented. Probably. Better to calibrate with your hand anyway. Pete 1 Link to post Share on other sites More sharing options...
Ornello Posted March 25, 2020 Share #31 Posted March 25, 2020 On 2/26/2020 at 5:41 PM, 250swb said: Generally speaking spot readings for 35mm are a total waste of time because they require copious notes and each frame to be developed differently, not something that is practical for 36 exposures. Correct. Meter the grass near you, if in the same illumination. That's all you need! Link to post Share on other sites More sharing options...
