Whenever I remove my SL2 battery, I lose all language, app, date and time settings, etc., and I'm forced to set them each time I remove the battery.
Has anyone experienced this? I'm now charging with the usb-c port, but would like to figure this one out......
Cheers,
Scott
Damn. My £150k Rolls Royce has a flat tire.  They should do better than this ......
Damn, my 737 max has a problem. They should do better than this .....
Damn, my president is a liar .......      and gets away with it  (probably there are even more liars ......)    and will probably even be reelected  .......
Edited by caissa
  • Haha 2
  • 1 year later...
I had the same issue, but solved it following the manual, and letting the main battery fully charge, and thus allowing the internal battery to recharge.
..."The replaceable battery supplies power to a backup battery, which is permanently installed in the camera. This backup battery retains the date and time for some weeks. Once the backup battery is depleted, it must be replenished by inserting a charged main battery. The time and date will have to be set again after a full depletion of both batteries. the solution is to charge the main battery..."
