On 11/21/2019 at 9:20 AM, miguelmolez said:
Most were yes, A couple turned out actually OK.
Thanks for the photos Miguel .
You have apparently  exposure problem with your M6  ?
Best H
47 minutes ago, earleygallery said:
Most of those photos don't look very underexposed, there's clearly details in the shadow areas. I suspect it's more down to the scanning.
The sky isn’t too dark either, it’s a normal zone vii
On 11/22/2019 at 9:21 PM, 105012 said:
Ektar 100 is an amazing film, I love its results for portraits. Looking over my Ektar portraits I really don’t know why people struggle with it? Beautiful, delicate skin tones.
If that was directed at my post #15, I did not say I struggle with Ektar.
I use Ektar frequently for landscape photography, where it excels for a C41 film and produces good scans and prints.  I would not use it for portraits, but if it pleases you and others, that's fine..
On 11/23/2019 at 12:19 PM, otto.f said:
Who did the scanning of this film, was this a 24 hours service with Jpeg’s of 1 Mb sent to you by mail or something?
Hi,
Appologies for the late reply.
It was https://www.ag-photolab.co.uk who done the dev/scanning. I opted for their 18mb (medium res) option. Anyone else used these before? I went with these for dev and scan due to the fact they could send my images via the web, without waiting.
4 hours ago, miguelmolez said:
Hi,
Hi doc H.
Nope, all other rolls (portra 400) turned out OK
Well, that seems to lead to the lab practices.
I think the trick with Ektar is to shoot it at box speed as though it was transparency/slide film. I over exposed a roll of it once and the greens and reds went crazy.
I think this just looks drastically under exposed. There looks to be one shot that looks not so bad - the girls back lit on the 2nd row.
Pete
Edited by Stealth3kpl
This is really hard to diagnose without seeing the negatives. Is there poor contrast in the film numbers and does the fogging extend past the picture frame? Then it is probably fogging in the roll, or poor chemistry. If the numbers are crisp and the area around the film is clear and clean, then it is likely an exposure issue. The green cast could be from the baseline noise of the scanner trying to recover the images from extremely underexposed negatives. But as others said, you seem to have a more or less normal amount of detail hidden behind the fogging.
I think the most important step here is to see the actual negatives...by the way, did you ask the lab? They should at least get a chance to say what they think...maybe they have a clue.
Edited by Stuart Richardson
Although I never had underexposed scans (I suspect it is lab scan issue in this case), I was never happy with colors from lab scans. I compared with any own scans from Plustek. My lesson is not to trust labs for good scanning.
I did ask them. Still waiting for a reply! Will ask again tomorrow.
4 minutes ago, otto.f said:
Huh? Does this mean you do not have the negatives?
My lab has an option to send the negative back immediately or get it back in batches at later time. This saves mailing cost and works for people who just want scans.
I am not sure what is the situation with OP.
Sorry yes I have the negatives back, I'm waiting for them to reply with the regards to what happened with the scans. I'm debating whether to get my own scanner now, to see what sort of results I get with them. Probably a good decision cost wise as well for the long term.
I sent off a roll of Portra 400 to the same lab yesterday, so the scans should be available for download at some point this morning. Will be interesting to see what results I get back.
