stevegaskin Posted November 6, 2019 Share #1 Posted November 6, 2019 Advertisement (gone after registration) I’ve just acquired an M-P 240 and looking to get a 28mm lens in the near future. Having ‘spent out’ on the body and a 50mm Summarit I need to find a good quality but ‘lower cost’ option. Type R lenses seem to go quite cheap (about £400), and with a non-Leica adapter such as Novoflex this seem quite tempting. My question is, how will an R lens perform on an M, has anyone experience of using this combination, or would I be better buying a Zeiss or Voigtlander. Link to post Share on other sites More sharing options...
Advertisement Posted November 6, 2019 Posted November 6, 2019 Hi stevegaskin, Take a look here Leica R lenses on M. I'm sure you'll find what you were looking for!
jdlaing Posted November 6, 2019 Share #2 Posted November 6, 2019 R lenses being quite large you may be better off looking at a Voigtlander 28mm. 1 Link to post Share on other sites More sharing options...
stevegaskin Posted November 6, 2019 Author Share #3 Posted November 6, 2019 10 minutes ago, jdlaing said: R lenses being quite large you may be better off looking at a Voigtlander 28mm. Hi, the 28mm Elmarit R seems to be approx’ the same size as a Summilux Link to post Share on other sites More sharing options...
jdlaing Posted November 6, 2019 Share #4 Posted November 6, 2019 The hood is where the viewfinder blockage matters. My preferences are for a more modern rendering as well. Link to post Share on other sites More sharing options...
stevegaskin Posted November 6, 2019 Author Share #5 Posted November 6, 2019 Ah, good point about the hood, still getting used to rangefinder operation; thanks for your feedback Link to post Share on other sites More sharing options...
jdlaing Posted November 6, 2019 Share #6 Posted November 6, 2019 1 minute ago, stevegaskin said: Ah, good point about the hood, still getting used to rangefinder operation; thanks for your feedback Also.... I don’t think the R is aspherical but I may be wrong. Link to post Share on other sites More sharing options...
Decimusmaximus7 Posted November 6, 2019 Share #7 Posted November 6, 2019 Advertisement (gone after registration) What about the Canon 28mm 2.8 LTM? Quite small and you keep your rangefinder. Link to post Share on other sites More sharing options...
lct Posted November 6, 2019 Share #8 Posted November 6, 2019 The Elmarit-R 28/2.8 v1 (code # 11204 or 11247) is not a large lens and its hood is not a problem when using the EVF given that R lenses are not coupled to the rangefinder. Now the pleasure to use the outdated EVF is limited and this lens performs poorly at edges and corners on my Canon 5D so i'm not sure it would do fine on the M240. The Elmarit-R 28/2.8 v2 (11259 or 11333) has not this problem but it is larger, more expensive, difficult to find and it is not coupled to the rangefinder either. All in all, i would forget the idea of using an R lens at this stage but YMMV. Link to post Share on other sites More sharing options...
UliWer Posted November 6, 2019 Share #9 Posted November 6, 2019 vor einer Stunde schrieb stevegaskin: Ah, good point about the hood, still getting used to rangefinder operation; thanks for your feedback You should consider that you cannot use the rangefinder for focussing with an R-lens since they are not coupled. So the large hood is not such a big problem as you are forced to use the electronic viewfinder anyway. To make use of the M‘s „soul“, which is the rangefinder after all, you should concentrate on coupled lenses which were made for the M or the screw-mount Leica. Only the excellent Macro R- lenses or some tele lenses longer than 135mm will be really useful with the EVF as they give you some opportunities you don‘t have with M-lenses. Link to post Share on other sites More sharing options...
stevegaskin Posted November 7, 2019 Author Share #10 Posted November 7, 2019 Ah, good point about the hood, still getting used to rangefinder operation; thanks for your feedback Link to post Share on other sites More sharing options...
stevegaskin Posted November 7, 2019 Author Share #11 Posted November 7, 2019 Thanks for your response and suggestions. I think I’ll wait to get an Elmarit or Summicron; need to start saving Link to post Share on other sites More sharing options...
a.noctilux Posted November 7, 2019 Share #12 Posted November 7, 2019 (edited) Hello Steve, Elmarit-M 2.8/28mm asph. is (in my own view) good "companion" of Summarit-M 50mm. This combo M+28+50 is light, not very expensive and very compact kit, but results are second to none. Edited November 7, 2019 by a.noctilux Link to post Share on other sites More sharing options...
stevegaskin Posted November 7, 2019 Author Share #13 Posted November 7, 2019 1 minute ago, a.noctilux said: Hello Steve, Elmarit-M 2.8/28mm asph. is (in my own view) good "companion" of Summarit-M 50mm. This combo M+28+50 is light, not very expensive and very compact kit, but results are second to none. Hi, thank you. I have the 50mm Summarit (I have only just bought this along with an M-P 240 so funds are somewhat low at the moment : ). I had an M9 with an Elmarit 28mm a few years ago; should have kept the lens! Link to post Share on other sites More sharing options...
Musotographer Posted November 7, 2019 Share #14 Posted November 7, 2019 (edited) When I got my M10, with its LiveView/EVF capability, I started buying some R lenses. I was intrigued by them and they were relatively cheap, but though their quality is very good indeed, in truth I used them very little and I have now sold most of them. I was just too attached to using the RF. The only one I used a lot was the glorious 80/1.4; a wonderful lens for portraits (for which I always used the EVF anyway), and it is a third of the price of its M twin, the 75/1.4. But even that I have now sold in favour of the 75, so that I can use it on my M9 Monochrom (no LV.) I would recommend the last pre-Aspherical Elmarit-M 28 ('version IV'), which one can buy relatively cheaply depending on condition. It only blocks a very small corner of the RF; as it barely flares it doesn't need a hood; and I prefer its beautiful rendering to the Aspherical's which I find a touch aggressive. I also prefer its handling to the Asph's, which is really small. Hope that helps. Edited November 7, 2019 by Musotographer 1 Link to post Share on other sites More sharing options...
