hunterspoint Posted December 8, 2018 Share #1 Posted December 8, 2018 Advertisement (gone after registration) Can the Aperture stop down below 6.4 ? Quote Link to post Share on other sites More sharing options...
Advertisement Posted December 8, 2018 Posted December 8, 2018 Hi hunterspoint, Take a look here XVario Aperture question. I'm sure you'll find what you were looking for!
wda Posted December 8, 2018 Share #2 Posted December 8, 2018 (edited) Yes; provided you select a wider angle on the lens zoom. Some people think of stopping down as setting a smaller diameter aperture. In which case you can stop down to more restricting apertures to increase depth of field or control exposure. Edited December 8, 2018 by wda Quote Link to post Share on other sites More sharing options...
hunterspoint Posted December 9, 2018 Author Share #3 Posted December 9, 2018 Thanks. I am trying to do a macro shot using an old Elpro lens. Have my lens at 70 but can only go as high as 6.4. How do I get more Depth of field . Would like get up to 16 if possible. Am I missing something? i have no problem doing this on my CL Lens , Q or M Lens . sorry if it is a silly question Quote Link to post Share on other sites More sharing options...
DwF Posted December 9, 2018 Share #4 Posted December 9, 2018 On the X Vario, if you set the aperture dial at say f3.5, as I often do, the aperture will open to the fastest (most shallow DOF) setting for every focal length as you zoom from 28-70 (18-46mm in aps-c speak :) You can however, zoom to other focal lengths including 70 and stop the lens to f 16 for greater depth of field. I hope this helps. David Quote Link to post Share on other sites More sharing options...
wda Posted December 9, 2018 Share #5 Posted December 9, 2018 Set Aperture Priority mode and select your desired lens aperture. Depending on lighting and subject, you might need to use a tripod or higher ISO setting. Quote Link to post Share on other sites More sharing options...
gbealnz Posted December 9, 2018 Share #6 Posted December 9, 2018 (edited) Not a silly question, that is what we are here for, to help. I use my X-Vario a lot for close-ups, especially of equipment I have or am looking to sell. I use either the native lens, without assistance, or the Elpro V1a, or V1b. For use with the V1a/b I use a tripod, and use no more than ISO400. I set the aperture dial to F11 or F16, to maximise DoF. Shutter dial is set to "A", and usually I end up with a speed of 1/5th second or thereabouts. I use the self-timer to reduce the camera shake when tripping the shutter. Gary Edited December 9, 2018 by gbealnz Spelling Quote Link to post Share on other sites More sharing options...
hunterspoint Posted December 9, 2018 Author Share #7 Posted December 9, 2018 Advertisement (gone after registration) Thanks. I figured out what the problem was. The numbers on my aperture dial are no longer visible so wasn’t able to see the markings. THanks for your help . Quote Link to post Share on other sites More sharing options...
wda Posted December 11, 2018 Share #8 Posted December 11, 2018 That is astonishing. Are you getting that rectified? Quote Link to post Share on other sites More sharing options...
