TMorita Posted December 30, 2017 Share #61  Posted December 30, 2017 Advertisement (gone after registration) I’ll see if I can dig up a good, general reference that isn’t too technical. In the meanwhile here is a brief description.  There are several sources of noise in any image. The first is read noise—the ability of the camera to accurately read out the contents of the CMOS chip at each pixel. It is typically fixed at somewhere between 2 and 20 electrons depending on ISO. If you are trying to read out 20,000 electrons of signal (plenty of light) even 20 electrons is immaterial. As the light gets dimmer, though, 20 electrons are more relevant. If your signal was 100 electrons, that read noise matters—a lot. This was the situation we were in, say, ten years ago. Since then, read noise levels have been dropping. Now it’s not at all unusual to see less than 2 electrons of read noise. Even with very low light, 2 electrons is usually pretty minor.  The next source of noise is thermal noise. This really only affects long exposures. I’ll ignore this for now.  The interesting one for this discussion is shot noise. Light itself is quantized, and the flow of photons from your subject into the camera is not perfectly even. This is shot noise and is inherent in the light. Google Poisson distribution if you want to read about this. Basically, it’s the random distribution of counts that are bounded at zero. Like a bell curve for measuring light. Even a theoretically perfect detector can’t do anything about this. There just isn’t enough light at each pixel. It’s an upper wall for all detectors.  So why did I mention “pixel pitch” and “sensor size?” If you have a larger sensor or larger pixels (or both), you get more light hitting each pixel so the “wall” moves up. This is why the Sony A7s does so well, for example, compared to other full frame chips. Only 12 megapixels, so many more photons per pixel vs a higher resolution camera. Better signal-to-noise in the light itself.  We are literally getting to the point where sensors won’t be able to improve any more. Quantum efficiency on many back side illuminated sensors is approaching 80%, so there is no more light to grab. Read noise is already down around 2 electrons. Thermal noise is all but irrelevant for exposures up to several seconds. What’s left is the physics of light itself  I disagree with the "getting to the point where sensors won't be able to improve anymore" assertion. There are many sensor improvements I'm waiting for to become commercially available:  curved sensors (already patented by Sony, Microsoft, Canon, etc) native ISO <100 16-bit ADCs non-Bayer filter image sensors (Foveon, etc)  There's probably more if I spent more time thinking about it.  Toshi Link to post Share on other sites More sharing options...
Advertisement Posted December 30, 2017 Posted December 30, 2017 Hi TMorita, Take a look here Clean CL at 3200 iso?. I'm sure you'll find what you were looking for!
scott kirkpatrick Posted December 30, 2017 Share #62  Posted December 30, 2017 Sensor improvements I'd like to see in APS-C and FF are:  Deeper wells to hold more electrons within the same surface area -- this would make true 14 bit 4 micron pixels happen, but for Leica's non-telecentric lenses would probably only work with microlenses on the cover layer.  16-bit ADC (already available on big MF chips like the 100 MPX Sony's that Phase One and Hasselblad use).  Global electronic shutter so that there is no "jello" effect from a 1/20 sec scan of an image taken locally at 1/250 sec. This may require "back side" technology to separate the extracting circuits from the picture-taking circuits.  I know enough of the hassles that Foveon has to overcome to get any decent color out that i'm not holding my breath on stacked 3-color technology, nor am i convinced that we need it. It is a cool idea, though, and some very smart people worked on its hardware and software (Carver Meade, Dick Lyons, & ...).  scott Link to post Share on other sites More sharing options...
lct Posted December 30, 2017 Author Share #63 Â Posted December 30, 2017 (edited) Just shot a couple hundreds indoor pics last night mostly at 3200 isos. I did not take my usual low light gear (Sony a7s mod, Lux 35, 50 & 75) to avoid the bulk of the 75 and to test the CL at the same time so i had the CL with a Lux 35/1.4 v2, a ZM 50/1.5 and a Cron 28/2. I would have preferred a small Lux or Cron 18 or 21 instead of the 28 but the CL worked like a charm i must say. EVF not always responsive in dim light but i did not miss more than a couple of shots because of that. As far as noise is concerned, i will have to use Define or same for the first time since i don't remember when. Magic C1 where are you? Â I will bring my usual gear next time with a 75/2 instead of the 75/1.4 but the little CL is very good otherwise. And progress won't stop suddenly in 2017 hopefully. Edited December 30, 2017 by lct Link to post Share on other sites More sharing options...
Chaemono Posted December 30, 2017 Share #64  Posted December 30, 2017 (edited) ISO 3200  aldi.jpg   I feel rather spoilt by the CL too... Noise reduction zeroed in ACR. I'm starting to do some comparisons CL + 35 Summicron-TL vs. α7R III + 50 Apo Summicron-M and 50/1.4 Zeiss Planar FE. What is ISO 2500 for the α7R III is ISO 1600 for the CL. I didn't go beyond 1600 on the CL today and they are really good. But first at ISO 800 and ISO 1250, respectively.  Uncompressed JPEGs here: https://www.smugmug.com/gallery/n-qDx8fd/  α7R III + 50 Apo Summicron-M, opened in LR and only WB adjusted a bit. Welcome, dear visitor! As registered member you'd see an image here… Simply register for free here – We are always happy to welcome new members! ISO 1250 f/2.0 @1/160 sec.  CL + 35 Summicron-TL, opened in LR and WB adjusted to try to match the Sony ISO 800 f/1.4 @1/160 sec. Edited December 30, 2017 by Chaemono Link to post Share on other sites Simply register for free here – We are always happy to welcome new members! ISO 1250 f/2.0 @1/160 sec.  CL + 35 Summicron-TL, opened in LR and WB adjusted to try to match the Sony ISO 800 f/1.4 @1/160 sec. ' data-webShareUrl='https://www.l-camera-forum.com/topic/280201-clean-cl-at-3200-iso/?do=findComment&comment=3428886'>More sharing options...
Chaemono Posted December 30, 2017 Share #65  Posted December 30, 2017 (edited) And now with the Shadows lifted by +100  Uncompressed JPEGs here: https://www.smugmug.com/gallery/n-qDx8fd/  α7R III, Highlights -11, Shadows +100, NR +30, LR default sharpening Welcome, dear visitor! As registered member you'd see an image here… Simply register for free here – We are always happy to welcome new members! ISO 1250 f/2.0 @1/160 sec.  CL, Exposure -0.20, Highlights -13, Shadows +100, NR +30, LR default sharpening ISO 800 f/1.4 @1/160 sec. Edited December 30, 2017 by Chaemono Link to post Share on other sites Simply register for free here – We are always happy to welcome new members! ISO 1250 f/2.0 @1/160 sec.  CL, Exposure -0.20, Highlights -13, Shadows +100, NR +30, LR default sharpening ISO 800 f/1.4 @1/160 sec. ' data-webShareUrl='https://www.l-camera-forum.com/topic/280201-clean-cl-at-3200-iso/?do=findComment&comment=3428891'>More sharing options...
Chaemono Posted December 30, 2017 Share #66  Posted December 30, 2017 (edited) And now the crops  Uncompressed JPEGs here: https://www.smugmug.com/gallery/n-qDx8fd/  α7R III Welcome, dear visitor! As registered member you'd see an image here… Simply register for free here – We are always happy to welcome new members! ISO 1250 f/2.0 @1/160 sec.  CL ISO 800 f/1.4 @1/160 sec. Edited December 30, 2017 by Chaemono 1 Link to post Share on other sites Simply register for free here – We are always happy to welcome new members! ISO 1250 f/2.0 @1/160 sec.  CL ISO 800 f/1.4 @1/160 sec. ' data-webShareUrl='https://www.l-camera-forum.com/topic/280201-clean-cl-at-3200-iso/?do=findComment&comment=3428894'>More sharing options...
Chaemono Posted December 30, 2017 Share #67  Posted December 30, 2017 Advertisement (gone after registration) And now CL and α7R III at ISO 1600 and ISO 2500, respectively. ISO 2500 on the Sony is really ISO 1600 on the CL. CL with the wonderful 35 Summicron-TL and α7R III with its native 50/1.4 Zeiss Planar FE.  Uncompressed JPEGs here: https://www.smugmug.com/gallery/n-qDx8fd/   α7R III, from ARW opened in LR and WB adjusted a bit to try to match CL Welcome, dear visitor! As registered member you'd see an image here… Simply register for free here – We are always happy to welcome new members! ISO 2500 f/3.2 @1/320 sec.   CL, from DNG opened in LR and WB adjusted a bit to try to match Sony ISO 1600 f/3.2 @1/320 sec. Link to post Share on other sites Simply register for free here – We are always happy to welcome new members! ISO 2500 f/3.2 @1/320 sec.   CL, from DNG opened in LR and WB adjusted a bit to try to match Sony ISO 1600 f/3.2 @1/320 sec. ' data-webShareUrl='https://www.l-camera-forum.com/topic/280201-clean-cl-at-3200-iso/?do=findComment&comment=3428942'>More sharing options...
Chaemono Posted December 30, 2017 Share #68  Posted December 30, 2017 And now with the Shadows lifted by +100  Uncompressed JPEGs here: https://www.smugmug.com/gallery/n-qDx8fd/   α7R III, Shadows +100, NR +25, LR default sharpening Welcome, dear visitor! As registered member you'd see an image here… Simply register for free here – We are always happy to welcome new members! ISO 2500 f/3.2 @1/320 sec.   CL, Exposure +0.40, Shadows +100, NR +25, LR default sharpening ISO 1600 f/3.2 @1/320 sec. Link to post Share on other sites Simply register for free here – We are always happy to welcome new members! ISO 2500 f/3.2 @1/320 sec.   CL, Exposure +0.40, Shadows +100, NR +25, LR default sharpening ISO 1600 f/3.2 @1/320 sec. ' data-webShareUrl='https://www.l-camera-forum.com/topic/280201-clean-cl-at-3200-iso/?do=findComment&comment=3428944'>More sharing options...
Chaemono Posted December 30, 2017 Share #69  Posted December 30, 2017 And now the crops of Baby Jesus. CL with a tad more noise.  Uncompressed JPEGs here: https://www.smugmug.com/gallery/n-qDx8fd/   α7R III Welcome, dear visitor! As registered member you'd see an image here… Simply register for free here – We are always happy to welcome new members! ISO 2500 f/3.2 @1/320 sec.   CL ISO 1600 f/3.2 @1/320 sec. Link to post Share on other sites Simply register for free here – We are always happy to welcome new members! ISO 2500 f/3.2 @1/320 sec.   CL ISO 1600 f/3.2 @1/320 sec. ' data-webShareUrl='https://www.l-camera-forum.com/topic/280201-clean-cl-at-3200-iso/?do=findComment&comment=3428945'>More sharing options...
jaapv Posted December 30, 2017 Share #70  Posted December 30, 2017 I must confess that, as I have no intention of moving to Sony -horrid UI- these “tests” are of no interest whatsoever to me. With modern sensors performance is good enough from any brand. It is the camera that counts. 1 Link to post Share on other sites More sharing options...
jmahto Posted December 31, 2017 Share #71  Posted December 31, 2017 I must confess that, as I have no intention of moving to Sony -horrid UI- these “tests” are of no interest whatsoever to me. With modern sensors performance is good enough from any brand. It is the camera that counts. +1  Camera body is not just a sensor. 1 Link to post Share on other sites More sharing options...
Chaemono Posted December 31, 2017 Share #72 Â Posted December 31, 2017 I don't use jpegs but i'm not good at handling LR so i wonder if i missed something. Now if you say that the M10 doesn't do better...M10 does great. See here: https://www.smugmug.com/gallery/n-Jfdr66/ Link to post Share on other sites More sharing options...
Chaemono Posted December 31, 2017 Share #73  Posted December 31, 2017 (edited) And back to topic, next I’ll do ISO 3200 on the CL but adjust the aperture on the α7R III to the APS-C equivalent for depth of field. In the Baby Jesus picture above, exposure was pushed a bit on the CL as aperture on both cameras was f/3.2. So it will be ISO 3200 f/1.4 on the CL and ISO 5000 f/2.0 on the α7R III. That should give similar exposure and then we’ll compare noise. Edited December 31, 2017 by Chaemono Link to post Share on other sites More sharing options...
lct Posted December 31, 2017 Author Share #74 Â Posted December 31, 2017 Interesting thank you but i'm not sure to follow your comparison with different isos and apertures. The crop factor does not come into play here. If the available light requires f/2 at 3200 iso on FF cameras the same light requires f/2 at 3200 iso on APS-C as well. Am i missing something? Link to post Share on other sites More sharing options...
Chaemono Posted December 31, 2017 Share #75 Â Posted December 31, 2017 (edited) Interesting thank you but i'm not sure to follow your comparison with different isos and apertures. The crop factor does not come into play here. If the available light requires f/2 at 3200 iso on FF cameras the same light requires f/2 at 3200 iso on APS-C as well. Am i missing something? Â Edit Edited December 31, 2017 by Chaemono Link to post Share on other sites More sharing options...
jaapv Posted December 31, 2017 Share #76 Â Posted December 31, 2017 Interesting thank you but i'm not sure to follow your comparison with different isos and apertures. The crop factor does not come into play here. If the available light requires f/2 at 3200 iso on FF cameras the same light requires f/2 at 3200 iso on APS-C as well. Am i missing something? Agree. Too many variables make for meaningless tests. Link to post Share on other sites More sharing options...
Chaemono Posted December 31, 2017 Share #77  Posted December 31, 2017 (edited) Interesting thank you but i'm not sure to follow your comparison with different isos and apertures. The crop factor does not come into play here. If the available light requires f/2 at 3200 iso on FF cameras the same light requires f/2 at 3200 iso on APS-C as well. Am i missing something? Theoretically, you may be right. But if one wants an equivalent depth of field, same fall off from the focus point, same lush, beautiful bokeh to compare APS-C with FF, one needs to adjust for the crop factor in aperture as well. But I'm sure you know this. Be patient. Many pictures to follow soon. I was generous and gave the α7R III the 50 Apo Summicron in order not to handicap it . They are not tests. They are comparisons of a similar look between APS-C and FF. We need to keep everything constant in order to solve for noise. Edited December 31, 2017 by Chaemono Link to post Share on other sites More sharing options...
Chaemono Posted December 31, 2017 Share #78  Posted December 31, 2017 First, only WB adjusted on the α7R III to try match the CL  Uncompressed JPEGs here: https://www.smugmug.com/gallery/n-qDx8fd/  α7R III + 50 Apo Summicron-M Welcome, dear visitor! As registered member you'd see an image here… Simply register for free here – We are always happy to welcome new members! ISO 5000 f/2.0 (wide open) @1/3200 sec.   CL + 35 Summilux-TL (but it's really more like a Summicron in the FF world  ) ISO 3200 f/1.4 (again, wide open) @1/3200 sec. Link to post Share on other sites Simply register for free here – We are always happy to welcome new members! ISO 5000 f/2.0 (wide open) @1/3200 sec.   CL + 35 Summilux-TL (but it's really more like a Summicron in the FF world  ) ISO 3200 f/1.4 (again, wide open) @1/3200 sec. ' data-webShareUrl='https://www.l-camera-forum.com/topic/280201-clean-cl-at-3200-iso/?do=findComment&comment=3429347'>More sharing options...
Chaemono Posted December 31, 2017 Share #79  Posted December 31, 2017 And now with the Shadows lifted by +100  Uncompressed JPEGs here: https://www.smugmug.com/gallery/n-qDx8fd/  α7R III, Exposure +0.10, Shadows +100, Blacks +20, NR +30, LR default sharpening Welcome, dear visitor! As registered member you'd see an image here… Simply register for free here – We are always happy to welcome new members! ISO 5000 f/2.0 (wide open) @1/3200 sec.   CL + 35, Highlights +10, Shadows +100, NR +30, LR default sharpening  ISO 3200 f/1.4 (again, wide open) @1/3200 sec. Link to post Share on other sites Simply register for free here – We are always happy to welcome new members! ISO 5000 f/2.0 (wide open) @1/3200 sec.   CL + 35, Highlights +10, Shadows +100, NR +30, LR default sharpening  ISO 3200 f/1.4 (again, wide open) @1/3200 sec. ' data-webShareUrl='https://www.l-camera-forum.com/topic/280201-clean-cl-at-3200-iso/?do=findComment&comment=3429351'>More sharing options...
Chaemono Posted December 31, 2017 Share #80  Posted December 31, 2017 (edited) And now the crops to look for that ugly ISO 3200 CL noise.  I'd say the α7R III sensor is terrific but it doesn't come close to the best FF sensors like in the D850 (Sony sensor). In fact, it's close to the best APS-C sensors when it comes to tonal range and color sensitivity at high ISO like the one found in the CL (probably also from Sony ) IMO.  Uncompressed JPEGs here: https://www.smugmug.com/gallery/n-qDx8fd/  α7R III Welcome, dear visitor! As registered member you'd see an image here… Simply register for free here – We are always happy to welcome new members! ISO 5000 f/2.0 (wide open) @1/3200 sec.   CL ISO 3200 f/1.4 (again, wide open) @1/3200 sec. Edited December 31, 2017 by Chaemono Link to post Share on other sites Simply register for free here – We are always happy to welcome new members! ISO 5000 f/2.0 (wide open) @1/3200 sec.   CL ISO 3200 f/1.4 (again, wide open) @1/3200 sec. ' data-webShareUrl='https://www.l-camera-forum.com/topic/280201-clean-cl-at-3200-iso/?do=findComment&comment=3429358'>More sharing options...
