(Very) long lenses on the CL and TL. -Please add your experiences.
jaapv
Well, just to contradict myself, here is one that I processed yesterday. sigma 150-600 @ 600
What does the Sigma 150-600 lens look like on camera?...
  • 1 month later...
The Tele elmar 135 f4 lens is too short for me, I want to enlarge it and I need answers to the following questions:
1.- Has anyone tried the Leica Vario-Elmar-R 70-210mm F4 E60 in CL or TL2?...
2.- In case I decide to buy it... would I have to buy an adapter from R to L?
3. Can I add a 2XAPO extender to the Tele Elmar 135mm f4?
Vario Elmar R 70-210/4 is a Leitz badge engineered Minolta lens manufactured 1984-1996. Would not contemplate trying or buying myself because it's so old (zooms do not improve with age) and at 720g a little heavy and maybe unbalanced on a CL or TL2. Yes you'd need an R to L adapter.
Not possible to add a 2x APO extender to the M Tele Elmar 135/4. The Leitz R 2x APO extender is only compatible with Leitz / Leica R lenses. There are no Leica extenders available for M lenses
For a long lens on your CL /TL2, you could consider a manual focus Canon FD 300/4 L lens which has 2 ED glass elements, an accessory tripod collar (enabling good balance on a tripod) and would offer the FF equivalent of 450mm on your APS-C cameras . Not to be confused with the 'non-L' version. And can be used with the Canon FD 1.4x extender 'A' for conversion to a 420mm (630mm FF equiv) lens.  Canon FD 300/4 L is usually reasonably priced and has been recommended by Doug Herr.
You could also consider Leitz R 180/2.8 Mk I (has a tripod bush) or Mk II ... or the Leitz R 250/4 Mk I or Mk II (both have tripod bushes) .... all are compatible with the R 2x APO and 1.4x APO extenders.  There are also the R 400/6.8 and R 560/6.8 'telescope' lenses to consider – both very under-rated and can be obtained relatively cheaply.
There is a new Leica Pocket Book 9th Edition due for publication shortly which lists the specifications of all Leitz / Leica lenses of all types (including R lenses) released up until  2022.
The Leica 80-200 f4 Vario-Elmar R is a far better lens than the 70-210 and works well on the CL and M cameras with live view. A better choice might be the Panasonic 70-200 L Mount lens, which has the very significant benefit of having optical image stabilisation in the lens and very good auto focus, with subject tracking. I can confirm this works very well with both the CL and SL bodies. It is about half the weight and a third of the price of the Leica 90-280, which I had and found too heavy. The downside of this lens is that due to its short flange focal distance, it cannot be used on M bodies.
Wilson
Edited by wlaidlaw
For bird photos, does this combination work well?:
Novoflex 400mm f5.6 T-Noflexar + PIGRIFF B Pistol Grip Follow Focus + Leica M Mount Adapter + Adapter L
Edited by Dopaco
vor 2 Stunden schrieb Dopaco:
The Novoflex is supposed to be a good lens, slightly better than the Leica Telyt 400 f5.6, which I have. My question would be if it is a Visoflex lens, if so Camera Quest has an M adapter, though it is not listed on their sight. I asked and they sent me one.
I suspect an 80-200 R with a 2X APO extender would be better than the elderly Novoflex (a 1950's design). Saying it is better than the Leica 400/f5.6 is no great recommendation. Another thought would be the excellent Zeiss Contax long lenses with a Contax to Leica L adapter (Novoflex). They are very reasonably priced compared with the Leica equivalents.
Wilson
It has a very cheap price, its size and appearance scares me a bit because of the resemblance to a firearm.
On the page it says it measures 177mm x 83mm.
and weight 734g.
It looks bigger in the photo. It comes with everything ready, I just have to add the adapter from M to L that I have.
I am going to travel to Extremadura "Monfrague National Park" (Spain), where there are many birds and wild animals, the 135 f4 tele lens falls short for me, unless I could enlarge it 2x.
It doesn't scare me that a lens is old, I have some very old lenses that give me better photos than many modern ones.
Wilson
Thank you.
I'm looking at the Leica R 80-200 F4 lens and if it can be magnified to x2 it would be a good fit.
3 hours ago, jaapv said:
There is, however a third-party one. The quality is reasonable, but it might do better on an APS-C sensor.
Komura 2x extender
31 minutes ago, Dopaco said:
Thank you very much, I'll check it out to see if it still exists
I have the Komura 2x extender. Never used it because reviews suggest it's better to crop the original image rather than use the Komura doubler. It's an older design
dunk
vor 35 Minuten schrieb Dopaco:
and weight 734g.
Yes, my 400 Telyt looks a little scary too. I haven't been using it much as if I go out with it I think I scare the birds. You do need 1/500 of a second to use the lens I use a leica table top tripod as a support, I try to use f8. If it is cheap enough it might be just the thing for your trip. If you want to stay with the 135, there is a Komura M-mount extender, not Leica and kind of rare, and even as a 400, APS-C equivalent, it may not be enough for birds. I find the 400 Telyt to be a little short at times.
Should work very well with any L mount camera provided the lens group is clean
https://www.novoflex.de/en/products-637/lens-adapters/adapter-rings/adapter-rings-products/adapter-rings-for-follow-focus-lenses.html
Use the Novoflex adapter LETA which bayonets onto the Novoflex Universal bayonet A .... after removing whichever adapter is currently fitted
The whole system is explained in https://www.camera-manual.com/novoflex-400/-followfocus-manual-18036-gbp
Sometimes the Noflexar lenes are hazy / dusty but it' fairly easy to dismantle and carefully clean, the lens group. BUT .... beware of 'speckled' lens coatings.
I've seen several examples with speckled / deteriorating lens coatings
The Novoflex Noflexar lens 'optics' were made by the Agfa subsidiary Staeble who also made the 1960s to 80s Leitz Elpro close-up achromats.
The 400mm Noflexar T is 3 element achromat; the regular 400mm Noflexar is a 2 element achromat; both are telescope lenses as distinct from telephoto designs.
My own Leica SL 601 / T Noflexar 400/5.6 set-up used with Novoflex follow focus mount - but with Leitz R bellows added for finer close-up focus .... also with a 2x R APO extender . Combination used for dragonflies with an R to SL adapter but could also be used with the LETA adapter without the R bellows
Handholding not recommended . The 'follow focus grip' is attached to an ARCA plate which slides into a gimbal tripod mount . Low seat next to the apparatus.
BW, dunk
Edited by dkCambridgeshire
