jimleicam3 Posted November 6, 2017 Share #1 Â Posted November 6, 2017 Advertisement (gone after registration) While changing a lens, I noticed three small dust particles on the sensor. Â I thought that these would be cleaned off automatically. Â Has anyone had a similar problem? Â How did you solve it? Â Cheers Link to post Share on other sites More sharing options...
Advertisement Posted November 6, 2017 Posted November 6, 2017 Hi jimleicam3, Take a look here Cleaning the sensor. I'm sure you'll find what you were looking for!
LD_50 Posted November 6, 2017 Share #2 Â Posted November 6, 2017 Sensor cleaning instructions can be found online from a variety of sources or you can have it professionally done. Link to post Share on other sites More sharing options...
jaapv Posted November 6, 2017 Share #3 Â Posted November 6, 2017 See the FAQ on the top of the M forums. It contains a protocol for sensor cleaning. Link to post Share on other sites More sharing options...
LocalHero1953 Posted November 6, 2017 Share #4 Â Posted November 6, 2017 I read somewhere that the SL had a cleaning function (i.e. it shakes the sensor) but I'm not sure if this is true. I do know that the SL is no more immune to dust as my M, possibly because it's sensor is less often covered by the shutter. When the M240 needs a clean, I usually do the SL as well. Link to post Share on other sites More sharing options...
LD_50 Posted November 6, 2017 Share #5  Posted November 6, 2017 From the user manual.  “CLEANING THE SENSOR  The camera is equipped with an automatic sensor cleaning function. Every time the camera is switched on, the sensor unit is subjected to ultrasonic vibrations which removes most of the dust or dirt particles adhering to the sensor cover glass. If any particles remain in spite of this (depending on their size, they can be identified by dark spots or marks on the recordings) the camera can be sent to Leica Camera AG’s Customer Care department (address: see p. 288) for the sensor to be cleaned at a cost, i.e. this cleaning is not included in the guarantee. You can also perform the cleaning yourself, as the shutter is normally open, i.e. exposing the sensor.“ 1 Link to post Share on other sites More sharing options...
Irakly Shanidze Posted November 11, 2017 Share #6 Â Posted November 11, 2017 All you have to do is turn the camera on and off a few times. If there is something stubborn, just use Arctic Butterfly brush. Link to post Share on other sites More sharing options...
robgo2 Posted November 11, 2017 Share #7 Â Posted November 11, 2017 Advertisement (gone after registration) The first thing to do when trying to remove sensor dust is to blow it vigorously with a hand bulb, such as a Giotto Rocket Blower. That will often solve the problem. If it does not, then there are a number of cleaning methods, some dry and some wet. The latter will almost always get even the most stubborn particles. Link to post Share on other sites More sharing options...
earleygallery Posted November 11, 2017 Share #8  Posted November 11, 2017  I thought that these would be cleaned off automatically. Cheers  How, by the dust fairies? Link to post Share on other sites More sharing options...
mgrayson3 Posted November 11, 2017 Share #9 Â Posted November 11, 2017 (edited) This is the one real downside of IBIS. Such cameras usually shake the sensor so gently that the dust feels only a pleasurable massage and is not tempted to relocate. On a fixed sensor, the vibration is ultrasonic and actually works effectively to dislodge dust. Â M Edited November 11, 2017 by mgrayson3 Link to post Share on other sites More sharing options...
pop Posted November 11, 2017 Share #10 Â Posted November 11, 2017 How, by the dust fairies? excerpt from the SL manual: The camera is equipped with an automatic sensor cleaning function. Every time the camera is switched on, the sensor unit is subjected to ultrasonic vibrations which removes most of the dust or dirt particles adhering to the sensor cover glass. Â Â Link to post Share on other sites More sharing options...
earleygallery Posted November 11, 2017 Share #11  Posted November 11, 2017  excerpt from the SL manual:    My bad, so it does have dust fairies! I didn't know that. 1 Link to post Share on other sites More sharing options...
frame-it Posted November 11, 2017 Share #12  Posted November 11, 2017 that's probably why there is a pause in operation after powering up..shake the sensor and look for the card. My bad, so it does have dust fairies! I didn't know that. Link to post Share on other sites More sharing options...
FlashGordonPhotography Posted November 13, 2017 Share #13 Â Posted November 13, 2017 1. Rocket Blower 2. Rocket Blower 3. Arctic Butterfly. 4. Rocket Blower. 5. Gel stick. 6 Rocket Blower. 7. Wet Clean (Visible Dust etc..) 8. Repeat 1 thru 7. 9. Camera holiday to Leica. Â Work down the list until the spots are gone and then stop. Â Gordon Link to post Share on other sites More sharing options...
Jeff S Posted November 13, 2017 Share #14 Â Posted November 13, 2017 Before #9, some Leica stores offer the service for a modest fee. Â Jeff 1 Link to post Share on other sites More sharing options...
meerec Posted November 13, 2017 Share #15  Posted November 13, 2017 1. Rocket Blower 2. Rocket Blower 3. Arctic Butterfly. 4. Rocket Blower. 5. Gel stick. 6 Rocket Blower. 7. Wet Clean (Visible Dust etc..) 8. Repeat 1 thru 7. 9. Camera holiday to Leica.  Work down the list until the spots are gone and then stop.   Gordon  I will NEVER EVER use a rocket blower on my sensor. I repeat: never.  I happen to live near the bush area in suberbian Sydney. There is a lot of dust in my home floating in the air. I tried blowing air with the Rocket blower into my SL sensor and it ended up with a total disaster. I pumped a lot of dust into my sensor rather than blowing it out. So much so I had to go to 7. in Gordon’s list as the result. Wet cleaning was the only option after the blowing treatment. So be warned and be careful. Link to post Share on other sites More sharing options...
helged Posted November 13, 2017 Share #16 Â Posted November 13, 2017 Regarding Arctic Butterfly: I once tried it on the M9. Never again. Some of the fibres ended outside the sensor area, resulting in a 'gentle' smearing of some sort of grease residue over the sensor. It took me many, many wet cleanings to get rid of the residue. Â Otherwise I follow the procedure outlined by many: Blowing first (with body facing down), inspection with a sensor loupe, more blowing, and eventually a wet cleaning. Â After 2 years of rather active use of the SL (I got the SL in Nov 2015), I think I have wet cleaned the sensor twice. This in contrast to the M9-family of bodies that needed regular wet cleanings. Link to post Share on other sites More sharing options...
jaapv Posted November 13, 2017 Share #17  Posted November 13, 2017 I will NEVER EVER use a rocket blower on my sensor. I repeat: never.  I happen to live near the bush area in suberbian Sydney. There is a lot of dust in my home floating in the air. I tried blowing air with the Rocket blower into my SL sensor and it ended up with a total disaster. I pumped a lot of dust into my sensor rather than blowing it out. So much so I had to go to 7. in Gordon’s list as the result. Wet cleaning was the only option after the blowing treatment. So be warned and be careful. Hence the tip to clean the camera in the bathroom, after running the shower, in dusty circumstances in the FAQ at the top of the M forums. That will take care of most if not all of the dust that is floating around. Somebody should start a FAQ thread for the SL here. 1 Link to post Share on other sites More sharing options...
robgo2 Posted November 13, 2017 Share #18  Posted November 13, 2017 (edited) I will NEVER EVER use a rocket blower on my sensor. I repeat: never.  I happen to live near the bush area in suberbian Sydney. There is a lot of dust in my home floating in the air. I tried blowing air with the Rocket blower into my SL sensor and it ended up with a total disaster. I pumped a lot of dust into my sensor rather than blowing it out. So much so I had to go to 7. in Gordon’s list as the result. Wet cleaning was the only option after the blowing treatment. So be warned and be careful.  Well, I live in dusty New Mexico, and I have never had that experience. Perhaps you should store your Rocket Blower in a dust-free plastic bag. That way you will know that any new dust appearing on the sensor did not come from the blower itself, which is widely recommended all over the world as the first step in removing sensor dust. Edited November 13, 2017 by robgo2 2 Link to post Share on other sites More sharing options...
meerec Posted November 14, 2017 Share #19  Posted November 14, 2017 Well, I live in dusty New Mexico, and I have never had that experience. Perhaps you should store your Rocket Blower in a dust-free plastic bag. That way you will know that any new dust appearing on the sensor did not come from the blower itself, which is widely recommended all over the world as the first step in removing sensor dust. To blow, the air out you squeeze the blower and it sucks the ambient air first in ... isn’t it how it works? Or have I missed something :-) Link to post Share on other sites More sharing options...
jaapv Posted November 14, 2017 Share #20 Â Posted November 14, 2017 Not all bulb blowers do that... Â https://www.cameraclean.co.uk/product-detail.php?cat=8&product=1416&desc=Professional+Dust+Free+Air+Blower+%28Black%29 2 Link to post Share on other sites More sharing options...
