Me Leica! Posted November 3, 2017 Share #1 Posted November 3, 2017 Advertisement (gone after registration) I have an Epson R-D1 (which is a great little camera) and a very nice 50mm F2 Summicron lens on it. Nice combination. I recently tried out a Leica M (240) and the actual image quality was great. What I couldn't get my head around was the two sets of framelines. I know that this is a feature of Leicas, but having become used to the single frame on the Epson, having two of them just felt like clutter and until you get used to which is which, it's easy to make framing errors. If the option existed to "remove" (or temporarily render invisible) one set of them, would you use it? (Given that they are now lit electronically, I wonder if it couldn't be done by firmware or something?) 1 Link to post Share on other sites More sharing options...
Advertisement Posted November 3, 2017 Posted November 3, 2017 Hi Me Leica!, Take a look here Does anyone else dislike having two sets of framlines?. I'm sure you'll find what you were looking for!
pico Posted November 3, 2017 Share #2 Posted November 3, 2017 If the option existed to "remove" (or temporarily render invisible) one set of them, would you use it? (Given that they are now lit electronically, I wonder if it couldn't be done by firmware or something?) I don't think the frame lines are electronic. They are lit by an LED, but still use the original finder masks. Yeah, select frame lines would be good. Link to post Share on other sites More sharing options...
jaapv Posted November 3, 2017 Share #3 Posted November 3, 2017 If you would remove them you would be unable to see the framing of half the lenses... As they are mechanical, it would be quite a costly operation, as it would call for modifying all three masks. I think Leica used to honour requests to block out the 75 mm lines at a not inconsiderable cost. I rather doubt that that is still an option. Which is a rather elaborate way of saying not a realistic idea. The only electronic thing about them is the LED that replaces the light widow. Link to post Share on other sites More sharing options...
Jeff S Posted November 3, 2017 Share #4 Posted November 3, 2017 Still essentially like these.... https://www.l-camera-forum.com/topic/66999-anatomy-of-the-leica-m8-framelines/ Jeff Link to post Share on other sites More sharing options...
UliWer Posted November 3, 2017 Share #5 Posted November 3, 2017 For the M7 and the MP Leica offers an „A la carte“ - option with just the 3 frames for 35/50/90mm as the M2 had them or a 5 frames version without the 75mm frames. You pay 150,-€ more to get less frames. Normally this is only an option when you buy the camera new, though I believe they do it on request for existing cameras - but it will be much more expensive. Since the viewfinder with its frames is in principle the same for the digital bodies as for the analogue ones it should be possible to get the viewfinder changed even for an M 240 or M10. A short question to Customer Care might help. Link to post Share on other sites More sharing options...
Herr Barnack Posted November 3, 2017 Share #6 Posted November 3, 2017 Does anyone else dislike having two sets of framlines? It doesn't bother me at all - I think after a while, you get accustomed to it and tune out the set of lines that you are not using. Link to post Share on other sites More sharing options...
lct Posted November 3, 2017 Share #7 Posted November 3, 2017 Advertisement (gone after registration) I prefer the framelines of the R-D1 as well but they are only three: 28, 35 & 50 and they are totally manual. The solution could come from electronic framelines but i would not hold my breath given the Das Wesentliche dogma in force at Wetzlar. 1 Link to post Share on other sites More sharing options...
Jeff S Posted November 3, 2017 Share #8 Posted November 3, 2017 While we're fantasizing, I'd at least like the lines to form a complete rectangle so that the corners are better defined. Jeff Link to post Share on other sites More sharing options...
250swb Posted November 3, 2017 Share #9 Posted November 3, 2017 I don't see the point in removing them, use the camera and after a while you only take notice of the frameline you are using. Most people manage to breath without noticing every breath, it's same with seeing Leica framelines. 2 Link to post Share on other sites More sharing options...
lct Posted November 3, 2017 Share #10 Posted November 3, 2017 I don't see the point in removing them [...] I don't like the 75mm framelines. A pain for this 50mm shooter since the M4-P and i still don't understand why it was paired with 50mm. None of my film Ms have them and i could well ask for a removal if i happen to buy an M11 unless it has electronic framelines but i don't hold my breath. Link to post Share on other sites More sharing options...
Histon Posted November 3, 2017 Share #11 Posted November 3, 2017 I have an Epson R-D1 (which is a great little camera) and a very nice 50mm F2 Summicron lens on it. Nice combination. I recently tried out a Leica M (240) and the actual image quality was great. What I couldn't get my head around was the two sets of framelines. I know that this is a feature of Leicas, but having become used to the single frame on the Epson, having two of them just felt like clutter and until you get used to which is which, it's easy to make framing errors. If the option existed to "remove" (or temporarily render invisible) one set of them, would you use it? (Given that they are now lit electronically, I wonder if it couldn't be done by firmware or something?) This is my only complaint on my 240-P I have two bodies, one with 50mm., one with 35mm. Having the extra frameline really does "put me off". I've sort of trained myself to get over it, but this really should't happen in this "day and age". I can perhaps understand why it was done in days gone by. http://www.richardhiston.org Link to post Share on other sites More sharing options...
UliWer Posted November 3, 2017 Share #12 Posted November 3, 2017 Well, the reason why it happens in this day and age are the same as why it was done in days gone by: they want to give users the opportunity to use different lenses - also beyond the „classical“ trio of 35/50/90. I am sure it was possible to produce an M 240 with just one frame, or 3 or five. If they would produce them I could imagine the threads in this forum about the longitude of waiting lists for cameras with all the different frame options. Link to post Share on other sites More sharing options...
Exodies Posted November 3, 2017 Share #13 Posted November 3, 2017 Y’all seem incapable of getting off mechanical frame lines. Why is that? Link to post Share on other sites More sharing options...
UliWer Posted November 3, 2017 Share #14 Posted November 3, 2017 .... Why is that? Well, perhaps because the question was asked in the subforum for the M (Typ 240) and relied explicitely to this camera? Of course there are lots of cameras around without any need for (mechanical) frames. Even the M 1 didn't have them. Though all those cameras and options are a different topic. Link to post Share on other sites More sharing options...
LocalHero1953 Posted November 3, 2017 Share #15 Posted November 3, 2017 Y’all seem incapable of getting off mechanical frame lines. Why is that? Das Wesentliche 1 Link to post Share on other sites More sharing options...
jlindstrom Posted November 3, 2017 Share #16 Posted November 3, 2017 Ideally I’d like to have just 28/50/90 frames, each own their own. But there lies the problem, the 28 & 90 are paired... It used to be the way, that one could send their camera to Leica for service and ask them to remove the extra frames (at cost), but I’m not sure if that’s still the case. Link to post Share on other sites More sharing options...
jdlaing Posted November 3, 2017 Share #17 Posted November 3, 2017 I have an Epson R-D1 (which is a great little camera) and a very nice 50mm F2 Summicron lens on it. Nice combination. I recently tried out a Leica M (240) and the actual image quality was great. What I couldn't get my head around was the two sets of framelines. I know that this is a feature of Leicas, but having become used to the single frame on the Epson, having two of them just felt like clutter and until you get used to which is which, it's easy to make framing errors. If the option existed to "remove" (or temporarily render invisible) one set of them, would you use it? (Given that they are now lit electronically, I wonder if it couldn't be done by firmware or something?) No. I see no reason to fiddle with what works just fine. Link to post Share on other sites More sharing options...
Guest Posted November 3, 2017 Share #18 Posted November 3, 2017 For the latest digital M-cameras, where the light frames are generated electronically, a different programming should be possible, so that in combination with coded lenses only the corresponding light frame can be seen alone. For non-coded lenses it would have to stay with the now practiced double frame reflection, since only three different settings of the frame selector lever are possible. Link to post Share on other sites More sharing options...
lct Posted November 3, 2017 Share #19 Posted November 3, 2017 For the latest digital M-cameras, where the light frames are generated electronically [...] I suspect they are not... Link to post Share on other sites More sharing options...
pop Posted November 3, 2017 Share #20 Posted November 3, 2017 For the latest digital M-cameras, where the light frames are generated electronically.... They are not. The frames are still the same cutouts in sheet metal and they are still brought in place by the same mechanical means. They are just lit with an internal electric light. Link to post Share on other sites More sharing options...
