AHAB Posted September 24, 2017 Share #1 Â Posted September 24, 2017 Advertisement (gone after registration) Hi, I have a VIOOH viewfinder and there is like little fluid bubbles in the lens system. I tried to clean it according to this manual: http://www.burdicek.com/camera/?p=42 This worked BUT this does not show how to open and clean the lens system. Can anybody help disassembling the silver parts with the lenses in it. Any PDF file / link / clues how to do it welcome, as I did not manage to get the parts disassembled. Any help highly appreciated. Thanks AHAB Link to post Share on other sites More sharing options...
Advertisement Posted September 24, 2017 Posted September 24, 2017 Hi AHAB, Take a look here need help for cleaning VIOOH Viewfinder. I'm sure you'll find what you were looking for!
jc_braconi Posted September 24, 2017 Share #2  Posted September 24, 2017 I have just this sketch but it helped me to dismantle the VIOOHyou will need some spanners Welcome, dear visitor! As registered member you'd see an image here… Simply register for free here – We are always happy to welcome new members! 1 Link to post Share on other sites Simply register for free here – We are always happy to welcome new members! ' data-webShareUrl='https://www.l-camera-forum.com/topic/277178-need-help-for-cleaning-viooh-viewfinder/?do=findComment&comment=3364466'>More sharing options...
AHAB Posted September 25, 2017 Author Share #3  Posted September 25, 2017 I have just this sketch but it helped me to dismantle the VIOOH you will need some spanners  Great - Thanks - will try to open the lens part and clean it - still not sure which screw holds which part ... Link to post Share on other sites More sharing options...
Jon Pop Posted September 25, 2017 Share #4  Posted September 25, 2017 I opened mine up to attempt to clean the prism - it's pretty straightforward. Sadly, I wasn't successful at cleaning the issue since it's some sort of either delamination or de-silvering of the mirrors that cause this odd brownish streak right in the midst of the view. But since I only paid $20 for it, and I just use it for framing basically, I've survived! Link to post Share on other sites More sharing options...
AHAB Posted September 25, 2017 Author Share #5  Posted September 25, 2017 I opened mine up to attempt to clean the prism - it's pretty straightforward. Sadly, I wasn't successful at cleaning the issue since it's some sort of either delamination or de-silvering of the mirrors that cause this odd brownish streak right in the midst of the view. But since I only paid $20 for it, and I just use it for framing basically, I've survived!  I already opened it and cleaned the side with the prism in it - no problem but I failed again in opening the "silver" side of the viewfinder today - I removed all the screws but was not able to open it - further I did not dare to force it open as some mechanical parts already started moving inside ..... probably next time in Wetzlar they can do it while I am going to have a coffee Link to post Share on other sites More sharing options...
jerzy Posted September 25, 2017 Share #6 Â Posted September 25, 2017 I hope that the document which I prepared will help you and other members who may want to CLA their VIOOH. If I was unclear in explaining please let me know..VIOOH Repair Instructions.pdf 7 Link to post Share on other sites More sharing options...
jerzy Posted September 25, 2017 Share #7  Posted September 25, 2017 Advertisement (gone after registration) ...either delamination or de-silvering of the mirrors that cause this odd brownish streak right in the midst of the view. But since I only paid $20 for it, and I just use it for framing basically, I've survived! Prism of VIOOH consist of few elements that are cemented, canada balsam used at that time tends to get yellow with the time. It could be cleaned and recemented, but I am afraid that for the cost lower than repair you will get a properly working viewer 1 Link to post Share on other sites More sharing options...
AHAB Posted September 26, 2017 Author Share #8  Posted September 26, 2017 (edited) I hope that the document which I prepared will help you and other members who may want to CLA their VIOOH. If I was unclear in explaining please let me know..VIOOH Repair Instructions.pdf  Thank you very much! This is amazing! After removing the first two screws I was not able to take off the "nose" yesterday so probably I did not dare to apply enough "force" - but as it is the correct way I will retry  BTW thank you from Bavaria to Austria (as I see in the profile to Vienna) Edited September 26, 2017 by AHAB 1 Link to post Share on other sites More sharing options...
AHAB Posted September 26, 2017 Author Share #9  Posted September 26, 2017 Thank you for your help in this amazing forum.I read the manual over and over again and decided I will have to take my time to get everything right. Not really sure if I will make it the next two weeks - but will keep you updated Link to post Share on other sites More sharing options...
AHAB Posted September 26, 2017 Author Share #10  Posted September 26, 2017 I hope that the document which I prepared will help you and other members who may want to CLA their VIOOH. If I was unclear in explaining please let me know..VIOOH Repair Instructions.pdf  BTW ... which lubricant to use? Link to post Share on other sites More sharing options...
AHAB Posted September 26, 2017 Author Share #11  Posted September 26, 2017 I hope that the document which I prepared will help you and other members who may want to CLA their VIOOH. If I was unclear in explaining please let me know..VIOOH Repair Instructions.pdf  as everything works smooth with the viewfinder - as soon as the nose is loose and I can clean the lenses ... I can skip the other procedures which are to disassemble the rest Link to post Share on other sites More sharing options...
jerzy Posted September 26, 2017 Share #12 Â Posted September 26, 2017 AHAB, you have PM. As lubricant I use synthetic lubricant which I received from my a friendly technician. In case you want to clean optics only you may skip a lot of steps in instructions. 1 Link to post Share on other sites More sharing options...
michelmooij Posted March 1, 2018 Share #13 Â Posted March 1, 2018 If there are tiny black spots in the viewfinder, what might be the cause of that? Is the problem in the connecting faces of the prism? Link to post Share on other sites More sharing options...
chris_livsey Posted March 2, 2018 Share #14 Â Posted March 2, 2018 If there are tiny black spots in the viewfinder, what might be the cause of that? Is the problem in the connecting faces of the prism? De-silvering of the mirror surfaces, they can be re-silvered but I suspect the cost will exceed the amount required to buy a "new" copy in better condition. If you can tolerate them the deterioration is slow if kept in warm dry storage when not in use, not in a leather case where the humidity promotes deterioration. 1 Link to post Share on other sites More sharing options...
wlaidlaw Posted March 2, 2018 Share #15  Posted March 2, 2018 If you decide to purchase new rather than trying to repair and unless you are dead set on buying Leitz, I would strongly recommend the TEWE zoom finder. Optically this is somewhat in advance of the VIOOH or VIDOM and especially for the longer focal lengths (the TEWE goes up to 200mm) gives a larger and clearer image. See here for Roger Hicks' article on the TEWE http://www.rogerandfrances.com/subscription/tewe%20polyfocus.html .  Personally I don't find any of the zoom/turret finders up to much, even though I have a VIDOM and a TEWE. I much prefer to use the far superior individual Leitz bright line finders, SBLOO (35mm), SBOOI (50mm), SGOOD (85mm). They are excellent and hugely better than any zoom finder.  Wilson Link to post Share on other sites More sharing options...
jerzy Posted March 2, 2018 Share #16 Â Posted March 2, 2018 Chris, there are no silvered surfaces in VIOOH, light is reflected within the prism though. I believe this is because of different "thickness" of glas and air, it is along time ago when I learned it at school:-) I believe this is dust/dirt and could be cleaned, see pdf in one of the postings above how to do it. 1 Link to post Share on other sites More sharing options...
gyoung Posted March 2, 2018 Share #17 Â Posted March 2, 2018 If you decide to purchase new rather than trying to repair and unless you are dead set on buying Leitz, I would strongly recommend the TEWE zoom finder. Optically this is somewhat in advance of the VIOOH or VIDOM and especially for the longer focal lengths (the TEWE goes up to 200mm) gives a larger and clearer image. See here for Roger Hicks' article on the TEWE http://www.rogerandfrances.com/subscription/tewe%20polyfocus.html . Â Personally I don't find any of the zoom/turret finders up to much, even though I have a VIDOM and a TEWE. I much prefer to use the far superior individual Leitz bright line finders, SBLOO (35mm), SBOOI (50mm), SGOOD (85mm). They are excellent and hugely better than any zoom finder. Â Wilson I like my TEWE best of the half dozen or so turret or zoom finders I have, I've used it on evf digital cameras too to give an optical 'experienc'. Mine could do with a clean to get rid of a bit of 'haze'. But individual brightline finders arr better, Leica or Voigtlander. Â Gerry 1 Link to post Share on other sites More sharing options...
chris_livsey Posted March 2, 2018 Share #18 Â Posted March 2, 2018 (edited) Chris, there are no silvered surfaces in VIOOH, light is reflected within the prism though. I believe this is because of different "thickness" of glas and air, it is along time ago when I learned it at school:-) I believe this is dust/dirt and could be cleaned, see pdf in one of the postings above how to do it. Ah my incorrect assumption of silvering on the prism, I have deleted the mis-leading post, thank you for the correction. It would be though unusual to see black spots, unless they are fungal perhaps? Â Dear me past deletion time slot/edit !! This is why deletion should remain an option for the poster. Edited March 2, 2018 by chris_livsey Link to post Share on other sites More sharing options...
michelmooij Posted March 3, 2018 Share #19 Â Posted March 3, 2018 Chris, there are no silvered surfaces in VIOOH, light is reflected within the prism though. I believe this is because of different "thickness" of glas and air, it is along time ago when I learned it at school:-) I believe this is dust/dirt and could be cleaned, see pdf in one of the postings above how to do it. So, if there are no silverings on the prism, what is the risc of cleaning then? Link to post Share on other sites More sharing options...
jerzy Posted March 3, 2018 Share #20 Â Posted March 3, 2018 In order to clean you need to take it apart, you might need a set of screwdrivers. Otherwise same rules as cleaning uncoated lenses and not with sandpaper -. How to disassembly and put together is described in pdf In all VIOOHs which I have seen all optical elements were uncoated Link to post Share on other sites More sharing options...
