phong Posted March 15, 2017 Share #1 Posted March 15, 2017 Advertisement (gone after registration) Hi there, The sensor on my 240 camera is getting dirty. What materials (swabs, cleaning fluid) are generally recommended ? Any special cleaning tip for the 240 ? Thanks, -Phong Link to post Share on other sites More sharing options...
Advertisement Posted March 15, 2017 Posted March 15, 2017 Hi phong, Take a look here Typ 240 sensor cleaning. I'm sure you'll find what you were looking for!
Reeray Posted March 15, 2017 Share #2 Posted March 15, 2017 (edited) I use the Visible Dust kit. 1.0x green swabs and matching sensor clean fluid. Leica recommend Isopropyl which I've also used successfully.. Make sure the battery is fully charged, blow out with an anti static blower (never use canned air) 2 drops on one side of the swab, leave for 30 seconds for it to soak in, then wipe from one side, and return wipe with the dry side. You may need to repeat this for a really dirty sensor. After you've cleaned the sensor, blow out the rear lens caps which is where most crud comes from. I do this this at every lens change as well as a quick blower shot when I get home. It's now been 2 years since my last wet clean. Hope this helps Edited March 15, 2017 by Reeray 1 Link to post Share on other sites More sharing options...
jim0266 Posted March 15, 2017 Share #3 Posted March 15, 2017 Been very happy with the Eyelead sensor gel stick. Make sure you get the version for Sony cameras, which they recommend for the 240 series. https://photographylife.com/product/sensor-gel-stick-for-sony/ Link to post Share on other sites More sharing options...
pop Posted March 15, 2017 Share #4 Posted March 15, 2017 Perhaps this might be useful: http://www.l-camera-forum.com/topic/216580-leica-m8-m82-m9-m9p-mm-mtyp240-faqs-questions-with-answers/?p=2464057&do=findComment&comment=2464057 2 Link to post Share on other sites More sharing options...
sblutter Posted March 15, 2017 Share #5 Posted March 15, 2017 Spotting digital in post is so much easier than what we had to do with silver prints. Is my last step before finalizing / printing. That said, compressed air (upright & gently!) + gel stick for the stubborn bits works for me Link to post Share on other sites More sharing options...
cirke Posted March 15, 2017 Share #6 Posted March 15, 2017 Visible Dust kit Link to post Share on other sites More sharing options...
olgierdc Posted March 15, 2017 Share #7 Posted March 15, 2017 Advertisement (gone after registration) ... or like that: https://www.youtube.com/watch?v=o3tevFw02CM. But you need ACDC Link to post Share on other sites More sharing options...
olgierdc Posted March 15, 2017 Share #8 Posted March 15, 2017 You don't believe ? Look next video: 2 Link to post Share on other sites More sharing options...
justj Posted March 15, 2017 Share #9 Posted March 15, 2017 I use Pentax imagesensor cleaning kit- like the one used on above video. 2 Link to post Share on other sites More sharing options...
DaveNC Posted March 15, 2017 Share #10 Posted March 15, 2017 You don't believe ? Look next video: What was that song at the end? A good luck chant? Link to post Share on other sites More sharing options...
jaapv Posted March 15, 2017 Share #11 Posted March 15, 2017 Spotting digital in post is so much easier than what we had to do with silver prints. Is my last step before finalizing / printing. That said, compressed air (upright & gently!) + gel stick for the stubborn bits works for me Not a safe advice. Using compressed air from a can has led to a number of cases of serious sensor damage, ranging from non-removable deposits to cracked sensors from thermal shock by the cold spray. Additionally the high pressure may transport dust between the filter layers of the sensor, impossible to remove. Use a blower bulb or vacuum system instead. 2 Link to post Share on other sites More sharing options...
lct Posted March 16, 2017 Share #12 Posted March 16, 2017 +1 Link to post Share on other sites More sharing options...
sml_photo Posted March 16, 2017 Share #13 Posted March 16, 2017 You don't believe ? Look next video: That's a Leica camera, but is it a Leica repair location? That is, is that what Leica technicians use? Link to post Share on other sites More sharing options...
david strachan Posted March 16, 2017 Share #14 Posted March 16, 2017 (edited) They look good. I've just ordered one of the Sony gel sticks...and easy to reuse. cheers... Edited March 16, 2017 by david strachan Link to post Share on other sites More sharing options...
Steve Ricoh Posted March 18, 2017 Share #15 Posted March 18, 2017 (edited) I've noticed dust bunnies on my M240, and I'm really careful how and where I change lenses. Watching the video of the gel, the technician seems to clean it by transferring the dirt from the gel stick onto some form of sticky paper, but to be successful it needs to be paper a bit stickier. I wonder if this comes with the kit (Is it the Sony gel stick referred to above ?). Having 'spotted' with the gel stick I notice there's no final wet wipe to get the sensor uniformly clean, I find it surprising, plus she seems to wipe the around the lens mount on the body before sending it on its way. Again rather surprising since pretty easy to transfer dust etc from the cloth into the shutter cavity, and then like magnetism onto the sensor. Edited March 19, 2017 by Steve Ricoh Link to post Share on other sites More sharing options...
david strachan Posted March 19, 2017 Share #16 Posted March 19, 2017 Steve The stick comes with 10 pieces of the sticky paper. More can easily be purchased. I found this "sales" blurb...might add more information. https://photographylife.com/product/sensor-gel-stick-for-sony/ In general I'm finding my M-P fairly easy to keep clean...had it now for 5 months and haven't used a wet clean yet, just strong blower. 1 Link to post Share on other sites More sharing options...
Gregm61 Posted March 20, 2017 Share #17 Posted March 20, 2017 That's a Leica camera, but is it a Leica repair location? That is, is that what Leica technicians use? That's at the factory. About as official as it gets. Link to post Share on other sites More sharing options...
Steve Ricoh Posted April 1, 2017 Share #18 Posted April 1, 2017 In another thread I read about shutter lubricant contamination (especially on newish cameras) but I'm guessing the Eyelead sensor gel stick would be inadvisable since it would in itself become contaminated and just spread the lub. around. If lubricant is observed perhaps a wet clean would be best, reserving the Eyelead just for dust. When ordering the Eyelead, is it the one designed for the Sony I should look for? I read somewhere the version for the Sony is less sticky, something to do with the image stabilisation method of mounting. Link to post Share on other sites More sharing options...
Exodies Posted April 1, 2017 Share #19 Posted April 1, 2017 The stick needs to be just slightly more sticky than the sensor. Unless your dirt has one side stickier than the other and is sticky side down. Link to post Share on other sites More sharing options...
Steve Ricoh Posted April 1, 2017 Share #20 Posted April 1, 2017 Sounds like a case of the Van der Waals... Link to post Share on other sites More sharing options...
