goatsby Posted December 23, 2015 Share #41 Posted December 23, 2015 Advertisement (gone after registration) To be safe, I downloaded my images, formatted the card in the camera, put the SD into the computer to upload the firmware update and then back to the camera to update. I also formatted the card again after the update was complete. You can use a new card, but if you plan on using a current SD that has images that are important it is better safe than sorry to download them first. Adam Link to post Share on other sites More sharing options...
Advertisement Posted December 23, 2015 Posted December 23, 2015 Hi goatsby, Take a look here Leica Q Firmware 1.1 has been released . I'm sure you'll find what you were looking for!
olg Posted December 23, 2015 Share #42 Posted December 23, 2015 This firmware is like answering Banana to a Yes or No question... Link to post Share on other sites More sharing options...
TK! Posted December 23, 2015 Share #43 Posted December 23, 2015 Anyone seen any improvements for high ISOs? Tempting to update before Christmas, high ISO will certainly help, but I is it worth the risk of update in these important days...? :-| -TK! Link to post Share on other sites More sharing options...
viramati Posted December 23, 2015 Share #44 Posted December 23, 2015 I'm pretty sure I am seeing quite an improvement in the banding issue at all iso's but will need to test further. From some shots I took in a dark Pub last night at iso 2000 and today at base and iso 500 I am seeing little to no banding in shadow and underexposed areas when pushed in Lr6. Anyway if after further testing this proves to be the case I will be more than happy. Link to post Share on other sites More sharing options...
Big T Posted December 24, 2015 Share #45 Posted December 24, 2015 Just upgraded to firmware 1.1 and had a strange issue. Formatted the SanDisk 32Gb Extreme Pro (95MB/s) in the Q then mounted it (Internal reader) on a MacBook Pro (OS X Yosemite V10.10.5). It would only allow me to “Read” the card and not write to it. I put the card back into the Q and took a pic. Then mounted the card back into the MacBook Pro and now could read and write. Weird. Link to post Share on other sites More sharing options...
viramati Posted December 24, 2015 Share #46 Posted December 24, 2015 Well done Leica On further testing I have found the 1.1 has basically solved the banding issue in shadow/underexposed areas. I find that up to iso 3200 I can pull detail to of the shadow area with no sign of banding. At iso 3200 it can just about be seen if you really look. At iso 6400 I can se it a little more but it is still acceptable. This is a major improvement to the cameras performance as at the end of the day it is the image that counts and this improvement to the IQ is WOW . Thank you Link to post Share on other sites More sharing options...
mschoe Posted December 24, 2015 Share #47 Posted December 24, 2015 Advertisement (gone after registration) Well done Leica On further testing I have found the 1.1 has basically solved the banding issue in shadow/underexposed areas. I find that up to iso 3200 I can pull detail to of the shadow area with no sign of banding. At iso 3200 it can just about be seen if you really look. At iso 6400 I can se it a little more but it is still acceptable. This is a major improvement to the cameras performance as at the end of the day it is the image that counts and this improvement to the IQ is WOW . Thank you I can tell exactly the same. Really tried hard to find any banding. Is it just me or is the auto white balance much more accurate with v1.1? Link to post Share on other sites More sharing options...
viramati Posted December 24, 2015 Share #48 Posted December 24, 2015 I'm also thinking DR is better but this is harder to quantify Link to post Share on other sites More sharing options...
Mr.Q Posted December 24, 2015 Share #49 Posted December 24, 2015 Wow, thanks for the initial reports. I can't wait to upgrade this weekend! Link to post Share on other sites More sharing options...
olg Posted December 24, 2015 Share #50 Posted December 24, 2015 Even at ISO 3200 you have to zoom to find a little of banding. Happy to see this improvement. The only three things, I don't like on this camera, and I'm not the only one thinking this, can be corrected by firmware updates: - Turn ON/OFF, LCD or EVF. - DNG Only option (like Leica M files) - Lossless DNG compression (like Leica M files) Leica? If you're there. Can you please make this camera perfect? You're 95% there! Thanks. Link to post Share on other sites More sharing options...
stefanusj Posted December 24, 2015 Share #51 Posted December 24, 2015 agree!!! Even at ISO 3200 you have to zoom to find a little of banding. Happy to see this improvement. The only three things, I don't like on this camera, and I'm not the only one thinking this, can be corrected by firmware updates: - Turn ON/OFF, LCD or EVF. - DNG Only option (like Leica M files) - Lossless DNG compression (like Leica M files) Leica? If you're there. Can you please make this camera perfect? You're 95% there! Thanks. Link to post Share on other sites More sharing options...
mehtasunil Posted December 25, 2015 Share #52 Posted December 25, 2015 After upgrading to 1.1, in Monochrome mode I still see Color image in live view..yes it takes images in monochrome but live view is Color...am i missing something? any one with same problem? Link to post Share on other sites More sharing options...
marchyman Posted December 25, 2015 Share #53 Posted December 25, 2015 ? I see a mono image in both viewfinder and lcd screen. A half press makes no difference. I do use back-button focus. Don't know if that changes anything. 1.1 has not changed anything in that respect. Ahhh, I see. Hit the "set" button. It cycles the display mode and one of the modes is color. Link to post Share on other sites More sharing options...
mehtasunil Posted December 25, 2015 Share #54 Posted December 25, 2015 ? I see a mono image in both viewfinder and lcd screen. A half press makes no difference. I do use back-button focus. Don't know if that changes anything. 1.1 has not changed anything in that respect. Ahhh, I see. Hit the "set" button. It cycles the display mode and one of the modes is color. Thanks Hitting SET button worked...Thanks Link to post Share on other sites More sharing options...
barjohn Posted December 26, 2015 Share #55 Posted December 26, 2015 Since upgrading to 1.1 I am seeing a strange problem where the camera switches to EVF view only on its own and will not let me switch it back to the LCD unless I pull the battery. Anyone else encountered this behavior? I tried pushing different buttons, ½ press of shutter, etc., nothing seemed to work. It happened several times. Seems to be ok since last battery pull but will test more today. Link to post Share on other sites More sharing options...
pop Posted December 26, 2015 Share #56 Posted December 26, 2015 Is there dust or an other obstruction in the viewfinder ocular? Link to post Share on other sites More sharing options...
prk60091 Posted December 27, 2015 Share #57 Posted December 27, 2015 Since upgrading to 1.1 I am seeing a strange problem where the camera switches to EVF view only on its own and will not let me switch it back to the LCD unless I pull the battery. Anyone else encountered this behavior? I tried pushing different buttons, ½ press of shutter, etc., nothing seemed to work. It happened several times. Seems to be ok since last battery pull but will test more today. Did update yesterday. As off now, no such issue. i think the AWB settings have improved. Link to post Share on other sites More sharing options...
barjohn Posted December 27, 2015 Share #58 Posted December 27, 2015 No dust on viewfinder. Also, hasn't repeated since battery removal reboot. Link to post Share on other sites More sharing options...
cafecacao Posted December 28, 2015 Share #59 Posted December 28, 2015 with me, DNG file is better Link to post Share on other sites More sharing options...
Iduna Posted December 28, 2015 Share #60 Posted December 28, 2015 Well done Leica On further testing I have found the 1.1 has basically solved the banding issue in shadow/underexposed areas. I find that up to iso 3200 I can pull detail to of the shadow area with no sign of banding. At iso 3200 it can just about be seen if you really look. At iso 6400 I can se it a little more but it is still acceptable. This is a major improvement to the cameras performance as at the end of the day it is the image that counts and this improvement to the IQ is WOW . Thank you I can confirm that banding improved a lot. I loaded the update a few days back without any problems in just a second. Link to post Share on other sites More sharing options...
