Guest NEIL-D-WILLIAMS Posted August 13, 2014 Share #1 Â Posted August 13, 2014 Advertisement (gone after registration) How do I use LV with my new Elmar lens........... It says no lens connected Link to post Share on other sites More sharing options...
Advertisement Posted August 13, 2014 Posted August 13, 2014 Hi Guest NEIL-D-WILLIAMS, Take a look here Just bought a 50mm 2.8 Elmer help. I'm sure you'll find what you were looking for!
lct Posted August 13, 2014 Share #2 Â Posted August 13, 2014 LV works with any lens but if you want auto iso you must code your Elmar if it is not coded already. Link to post Share on other sites More sharing options...
Guest NEIL-D-WILLIAMS Posted August 13, 2014 Share #3 Â Posted August 13, 2014 LV works with any lens but if you want auto iso you must code your Elmar if it is not coded already. Sorry can you explain what you mean? Link to post Share on other sites More sharing options...
lct Posted August 13, 2014 Share #4  Posted August 13, 2014 Sure, do you have coding pits like these on the bayonet of your lens? If not, you may wish to press the Menu button of the M240 and choose "Lens Detection", "Manual", "50 f/2.8 11831/11823/11824". Welcome, dear visitor! As registered member you'd see an image here… Simply register for free here – We are always happy to welcome new members! Link to post Share on other sites Simply register for free here – We are always happy to welcome new members! ' data-webShareUrl='https://www.l-camera-forum.com/topic/232172-just-bought-a-50mm-28-elmer-help/?do=findComment&comment=2649029'>More sharing options...
Guest NEIL-D-WILLIAMS Posted August 14, 2014 Share #5 Â Posted August 14, 2014 Thanks for the info.... Â ..I do not have anything like that on the lens as it is a screw mount but the manual settings works fine .....thanks for the help Link to post Share on other sites More sharing options...
lct Posted August 14, 2014 Share #6 Â Posted August 14, 2014 Then you have an adapter ring that can be coded (more or less easily) in order for the lens to be recognized automatically if need be. Link to post Share on other sites More sharing options...
Guest NEIL-D-WILLIAMS Posted August 14, 2014 Share #7 Â Posted August 14, 2014 Advertisement (gone after registration) This is what I got........bright lines work and in reality I got this lens for the MM so no need for live view Link to post Share on other sites More sharing options...
250swb Posted August 14, 2014 Share #8 Â Posted August 14, 2014 The easier way is to use an LTM adapter with the coding pits machined in, then you can leave 'lens detection' set to 'Auto'. Â Steve Link to post Share on other sites More sharing options...
Guest NEIL-D-WILLIAMS Posted August 14, 2014 Share #9 Â Posted August 14, 2014 LTM? Link to post Share on other sites More sharing options...
Erik Gunst Lund Posted August 14, 2014 Share #10  Posted August 14, 2014 Thanks for the info.... ..I do not have anything like that on the lens as it is a screw mount but the manual settings works fine .....thanks for the help  LTM?  LTM Leica Thread Mount also Leica Screw Mount is used by some people online but not an official abbreviation or standard like LTM is, used for microscopes enlarger etc. Link to post Share on other sites More sharing options...
250swb Posted August 14, 2014 Share #11 Â Posted August 14, 2014 LTM? Â An LTM adapter is what your are holding in the photo. The one you have is an older Voigtlander version before Leica lenses were coded. But on Ebay you can now buy codable adapters, the large cut out around the circumference is replaced with metal and on the reverse side are six rebates to take some black paint. You need a 50/75 LTM adapter, some hobby paint like Humbrol matt black, and the code for the lens. It has to be a 50/75 adapter not just because of the framelines, but because the camera expects a correlation between the frameline and the code for it to work automatically. Â Steve Link to post Share on other sites More sharing options...
Bill W Posted August 14, 2014 Share #12 Â Posted August 14, 2014 I have read this thread and I thought Neil was asking about live view not working for this lens. I guess my question is if he gets another adapter, will this allow live view to work. Is live view not working because it cannot detect a lens attached. Link to post Share on other sites More sharing options...
luigi bertolotti Posted August 14, 2014 Share #13 Â Posted August 14, 2014 With a lens like the Elmar one must take into account that LTM/BM adapters without the cutout (to say, codable) can't work properly because they interfere with the focusing knob. Link to post Share on other sites More sharing options...
pop Posted August 14, 2014 Share #14  Posted August 14, 2014 How do I use LV with my new Elmar lens........... It says no lens connected  With the current firmware version (2.0.1.5) this should no longer be an issue.  However, mind that the camera returns all settings to the factory default and that it drops any stored profiles upon installation of this firmware version. Better save them to the SD card before installing, if you want to keep them. Link to post Share on other sites More sharing options...
