APO Summicron 50/2 ASPH: Central veiling flare / fogging
pajamies
Aside from Olaf's statemente, the central veiling flare (CVF) is a special issue reported on one lens only AFAIK, the Summicron 50/2 asph. I don't know if Olaf owns a Summicron 75/2 actually but it would be certainly useful to support his statements by some pictures on the LUF. I have not my 75/2 with me here so i cannot be of any help for that.
  • Replies 934
  • Created
  • Last Reply
I changed my mind. I do not believe that the flare posted here by other members is sensor flare.
Any flare that is from the sensor (reflection) will have to be geometrically upside-down and reversed and its ray has to pass through the center of the photograph. Anything else is just flare.
On the other hand that would explain, why CVF is worse with smaller apertures (f/16). The light could be reflected by the backside of the iris or by lens surfaces ev. several times.
The other cause - something from outside the ray trace - could be fought with a lens hood effectively.
An error in the design of the lens would show up in bad MTF curves.
Jan
Aside from Olaf's statement, the central veiling flare (CVF) is a special issue reported on one lens only AFAIK, the Apo-Summicron-M 50/2 Asph.
It has been reported on the Apo-Summicron-M 75 mm Asph as well, by several users, and on the the Summicron-M 28/2 Asph, by me.
I don't know if Olaf owns an Apo-Summicron-M 75/2 Asph actually ...
I do.
... it would be certainly useful to support his statements by some pictures on the LUF.
This has been done years ago in the German-language part of this forum—see here.
I was able to duplicate the flare from my Vernazza post 183 using the same 28/2 and shooting my window. I know think I know what it was. It wasn't the lens' fault or some strange aberration of the laws of physics that took place for those 5 pictures I shot in Vernazza. Don't get frustrated with me, at least I'm trying to be open minded here. First take a look:
That is a breath on the rear element. I think Steve was right after all. Although, it was sizzling hot and not a humid day, we had been walking around half the day and I remember switching lenses. I carry extra lenses in the cargo pockets of my shorts. That is where the condensation came from and that is why after removing the lens and inspecting it the next set of pictures where fine. At least this makes more sense. This may also be why I have seen this randomly on most all of my lenses. You just can't take anything posted here at face value, can you? Does this all sound like a more reasonable explanation?
Now, I'll place the lenses in baggies before I put them in my sweaty pants pocket... they didn't seem sweaty to me.:rolleyes:
It has been reported on the Apo-Summicron-M 75 mm Asph as well, by several users, ... in the German-language part of this forum—see here.
I don't read German unfortunately but my understanding, from Google's translation, is that all samples of the 75/2 don't suffer from CVF and that this behavior is considered unusual by Leica. Thanks for sharing anyway.
Leica User Forum - Einzelnen Beitrag anzeigen - Apo-Summicron-M 75 Asph an M9 unbrauchbar?
Rick you might try the small Zing neoprene bags for M lenses. They protect a bit and let the lens "breathe" it seems. An idea anyway. So far I have not hyperventilated while changing lenses, but the next conductress could change all that.
Just googled that. Those are perfect. I have one like that from a Nikon lens and like it also for the reason that I get tired of the focus tab banging against my leg all day long. The neoprene adds some padding - probably good for both my leg and the lens. Thanks.
Ok, first off, here is the first time I saw this central veiling flare. It was in 2011 with my 28mm Summicron at f5.6 on the M9. Common knowledge was that this lens is one of the most flare resistant lenses. This is the image I discussed in post 171. Is this what we are talking about? Pretty bad, huh?
[ATTACH]389344[/ATTACH]
I've had quite a few images taken with the 28mm Summicron Asph which show exactly the same type of "flare". In every case I was able to explain it as being caused by a bright light source just outside the field of view. It seemed to be more prevalent on my M8 when the lens had an IR/UV filter attached. I got used to being careful whenever this was a possibility particularly as I once had to re-shoot some pictures I had been asked to take for a neighbour of the interior of their house.
  • 2 weeks later...
  • 2 weeks later...
Today I experienced central flare with my Apo 50 - see attached picture.
I can induce a veiling flare quite easily on the 50 APO by taking a picture in the direction of the sun, with the sun roughly 20 degrees above top frame of the photo. It is bothersome and I do wish Leica had included a longer hood, even at some cost to the design aesthetic. On the other hand, other Leica 50s I have used have the same problem to varying degrees, and in all other respects, this lens is spectacular.
IMHO and experience, 50's are relatiively more prone to flare than other angles. This is why I think Leica should never have abandoned the beautiful separate hood that came before the last Summicron 50. It would have been perfect if the APO would have been delivered with a separate screw-hood for special light situations, alongside the built-in hood which will do for most situations.
Hello...a happy ending!
So....some of you may recall me posting images in July (page 5 of this thread)...which showed central flaring as I stopped down (leading to various of you trying similar stopping down approaches around the world!).
Well...my story has a happy ending...!
When I returned to London I sent (via my dealer) the lens back to Solms (as some of you had also suggested)...but then separately, and unsolicited, I received the following e-mail from Solms:
Dear Mr Grover
I have read in the Leica User Forum about your problems with central flare with your Apo-Summicron-M 1:2/50mm ASPH. As a matter of course we want to prevent that this effect occurs at any aperture.
My I ask you give me some details about what has happened about that before? You reported that it had been at Leica for repair. Can you please tell me when and where?
Nevertheless we would like to see the lens again to find out what is causing the problem.
Would it be OK for you if we arrange an exchange for a certain time?
Thank you very much for your support,
Best Regards, Jesko v. Oeynhausen
This was followed shortly after with this:
Dear Jim
I would like to give you an update on your lens.
We can reproduce the effect and we would like to replace your lens against
a new one, if this is OK for you. Unfortunately the supply chain is
interrupted at this moment, so it will take some more days to find a
replacement lens. Is that OK for you?
All the best,
Jesko v. Oeynhausen
And then, sure enough, a few days later a replacement new lens appeared...and I am happy to report that it is perfect...a delight...and as gorgeous as promised!
So in my case just a faulty lens that Leica were quick to rectify. So my sincere thanks to Jesko for caring, for reaching out to me, for fixing the problem, and making it all effortless for me.
Many thanks to all of you who contributed to this thread..I read them all as I waited to see how my own story would end!
Best
Jim
