xpr.108 Posted November 24, 2012 Share #1 Â Posted November 24, 2012 Advertisement (gone after registration) I have only been using 40 rok and 35mm lens since I purchased my M system few years ago. Â I am thinking about getting either 21 or 24mm to use with m6 or M8/9... Â Pardon my ignorance, will I be able to focus these with m6 or m8/9? I understand that none of the camera I owned have those "frame line" built in. Is the external finder merely for framing your shot and nothing more? Â Â Thank you in advance for clarifying this for me! Link to post Share on other sites More sharing options...
Advertisement Posted November 24, 2012 Posted November 24, 2012 Hi xpr.108, Take a look here Using 21mm or 24mm without external finder. I'm sure you'll find what you were looking for!
IWC Doppel Posted November 24, 2012 Share #2 Â Posted November 24, 2012 With your M8 you can use the 24 with frame lines and using the full viewfinder get away with a 21 Â You will need to either really undestand the fov and guess or use an external viewfinder non the M6 or M9 I use a voigtkander metal 21/25 finder and I'm very happy with the results Link to post Share on other sites More sharing options...
IWC Doppel Posted November 24, 2012 Share #3 Â Posted November 24, 2012 PS you will need to focus with the internal viewfinder and frame with the external which is less of a pain than it sounds in practice Link to post Share on other sites More sharing options...
250swb Posted November 24, 2012 Share #4 Â Posted November 24, 2012 Is the external finder merely for framing your shot and nothing more? Â Yes, it is merely for the careful and thoughtful composition of your image, it is pointless and a waste of time for anything else. Â You still focus using the focus patch in the camera's viewfinder. Â Steve Link to post Share on other sites More sharing options...
xpr.108 Posted November 24, 2012 Author Share #5  Posted November 24, 2012 I just want to check with all the experts here before saving up for another glass  Thank you very much for your time!!!!  :) Link to post Share on other sites More sharing options...
Dirk Mandeville Posted November 24, 2012 Share #6 Â Posted November 24, 2012 I just got a CV 15mm super wide heliar, but don't have a finder for it. Focusing through the rangefinder is no problem, but is impossible to accurately compose shots without the finder as you are just guessing. But you can still get the shots you want with a little trial and error. I am planning on using it with live view / evf on the new M, so I don't think I will get a finder for it. If I planned on using it regularly on the M9, I would definitely spring for the finder. Link to post Share on other sites More sharing options...
rramesh Posted November 27, 2012 Share #7 Â Posted November 27, 2012 Advertisement (gone after registration) As you go wider, an external finder is essential for accurate framing. Without one, you will in most cases lose part of the image as you will need to crop. Â In fact this is where I see one value in the new M as it can be used with the tilt electronic viewfinder. When I used an Olympus with the same tilt viewfinder used in the Leica, I could get close to ground level shots accurately. Link to post Share on other sites More sharing options...
pgk Posted November 27, 2012 Share #8 Â Posted November 27, 2012 As you go wider, an external finder is essential for accurate framing. I have been using the 21SE without a finder for a few months with fair success BUT I recently picked up a Frankenfinder and the difference is significant. So, yes you can use a 21 without a finder, but as might be expected, it is a lot easier and 'better' to use it with one. Link to post Share on other sites More sharing options...
wda Posted November 27, 2012 Share #9 Â Posted November 27, 2012 I cannot understand why anyone would invest in high quality precision equipment and then guess the picture framing without using a special viewfinder. It just does not make sense. Link to post Share on other sites More sharing options...
pgk Posted November 27, 2012 Share #10 Â Posted November 27, 2012 I cannot understand why anyone would invest in high quality precision equipment and then guess the picture framing without using a special viewfinder. It just does not make sense. In my case its very simple - affording and finding a viewfinder..... especially as I wanted a Frankenfinder. I eventually bought one quite reasonably. Link to post Share on other sites More sharing options...
jaapv Posted November 27, 2012 Share #11 Â Posted November 27, 2012 I cannot understand why anyone would invest in high quality precision equipment and then guess the picture framing without using a special viewfinder. It just does not make sense.It just depends on how accurately one is able to estimate the field of view. Some photographers are amazingly good at it.It is not as if these external viewfinders are anything near accurate. For instance the Zeiss ones are forever cutting of feet, the Leica ones are generally too narrow and CV ones have individual variation in accuracy. The Frankenfinder is probably the best of the lot. Link to post Share on other sites More sharing options...
xpr.108 Posted November 28, 2012 Author Share #12 Â Posted November 28, 2012 I am so glad that I can still focus with built-in viewfinder. Â My preference would be not to use external finder (thanks for this thread) since I can focus using built-in finder. I simply find external viewfinder too <fill in the blank>, albeit very useful tool. Â I'll have to get my hands a 15mm heliar or something to test my FOV skills. Â Thanks again for clarifying this for me! Link to post Share on other sites More sharing options...
Messsucherkamera Posted November 30, 2012 Share #13  Posted November 30, 2012 Yes, it is merely for the careful and thoughtful composition of your image, it is pointless and a waste of time for anything else. You still focus using the focus patch in the camera's viewfinder. Steve You can also use zone focusing or hyperfocal technique, unless you want to shoot wide open for shallow depth of field. Link to post Share on other sites More sharing options...
Einst_Stein Posted December 1, 2012 Share #14 Â Posted December 1, 2012 Don't know 21mm, but I have Zeiss Zm 25mm. Â With ZM 25mm, you can see the full view through M9's view finder, however, there is about 5~10% at the edge you have to move a little your eye towards the edge to really see the full view. If you wear a glass it might not be possible. For quick composition, you are looking at about 90~95% of the view. This may not be that bad, given most SLRs have only the 90% view finder. Â However, I find it's a lot more comfortable to compose with a 24mm external view finder. Â Mu suggestion, it's OK to use only M9's built-in viewfinder, but you may find the external viewfinder indispensable once you have it. Link to post Share on other sites More sharing options...
ohnri Posted December 4, 2012 Share #15  Posted December 4, 2012 My 21mm 'lux was one of my most used lenss on my M9.  I never found an external finder to be helpful.  OTOH, I used an external finder just about 100% of the time when shooting at 16mm.  So, I would say, give it a go without one and see how you like it.  -Bill  Fashion Meets Fighting  http://www.hatakeyamagallery.com/april-2012-bill-fulcher/ Link to post Share on other sites More sharing options...
efreed2754 Posted December 4, 2012 Share #16 Â Posted December 4, 2012 Sold my 21 24 28 finder when purchasing 18 and got the Leica 18 finder. Also have a 24 so the dotted lines work for both lenses. And one can site between the two for 21. This finder is good if you think you might get an 18. Â Sometimes throw on the 24 without the finder. You meter and focus as always. Found if put subject in middle and chimp get by. Especially if not in a rush. Â If you go for the 21 you will want to use the finder to be sure to place interesting subjects properly in the foreground. Worth the time to install the finder. Â So if you only do buildings or rocks you can chimp....or use new M without a finder. Link to post Share on other sites More sharing options...
John Z. Goriup Posted December 25, 2012 Share #17 Â Posted December 25, 2012 I have been using the 21SE without a finder for a few months with fair success BUT I recently picked up a Frankenfinder and the difference is significant. So, yes you can use a 21 without a finder, but as might be expected, it is a lot easier and 'better' to use it with one. Â Please forgive my ignorance and lack of familiarity with "insider code-speak". Even though I've been an avid Leica user for over 5 decades, I'm a total newbie when it comes to the interweb..............what on Earth is a Frankenfinder, pray tell ? Â JZG Link to post Share on other sites More sharing options...
Erik Gunst Lund Posted December 25, 2012 Share #18 Â Posted December 25, 2012 It is the viewfinder designed for the WATE, f/4 16-18-21mm ASPH It is very large and not so pretty... looks like something put together of left over spare parts... Link to post Share on other sites More sharing options...
Bill W Posted December 25, 2012 Share #19 Â Posted December 25, 2012 When I decided to get a 21mm, I actually picked up the finder first used. The Leica version can get expensive. I find it really helpful to compose and not guess. Link to post Share on other sites More sharing options...
Bill W Posted December 25, 2012 Share #20  Posted December 25, 2012 Please forgive my ignorance and lack of familiarity with "insider code-speak". Even though I've been an avid Leica user for over 5 decades, I'm a total newbie when it comes to the interweb..............what on Earth is a Frankenfinder, pray tell ? JZG I believe it is referred to as the Universal Wide-Angle Viewfinder M. It is large compared to the single finders. Some folks like them. Link to post Share on other sites More sharing options...
