the top cover with what is inside ....and outside
Hi JC, isn't the llla a smaller body size than the later lllf? I am sure I read elsewhere that the entire construction is different, the later cameras being made from fewer castings.
I have seen earlier cameras converted to 'lllf spec' which typically have a flash sync dial stuck to the top plate of the camera, not a wholesale change to the later body style as with this example.
Of course, my knowledge is limited compared to yours, and I know you probably have examples of each in your collection ;)
That's what I thought that the change was at the IIIc - about 1/8-inch longer. I don't have a IIIa - just Japanese clones of the III that are all shorter (left to right) than the IIIc and IIIf. (Except for my Leotax - which looks like a IIIf but is even longer by another 1/8 inch.)
I'm sure the top cover with the "Red dial" sync engraving would have been new.
On my monitor the numbers look black
how are the two pins of the selector : flat or folded ?
I had poor lighting on the earlier shot - here is a comparison. The "IIIa" serial number is indeed red dial with the sync pins folded up:
Compared to a "black dial" with the flat pins:
I'm still sure the covers and body would have to have been replaced, and likely most (if not all) of the internal works.
By the way - I've also seen the application of an old serial number to a new unit at a company where I used to work. The customer wanted a piece of test equipment up-graded to a newer model - but the new model was entirely different design with no parts or case in common with the old one. The customer required the same serial number for tracking purposes, so the old serial was put on an entirely new unit, and the company files of serial numbers were updated to explain the change. I suspect Leitz did the same on this unit.
Edited by TomB_tx
The IIIf red-dial is interesting, as it has the serial number from a 1936 IIIa.
Gentlemen,
The Leica IIIa is five and a half inches long; the Leica IIIf is five and three quarter inches long. The chassis and method of construction is completely different. Futhermore the post war cameras use the "42-215" and "42-216" shutter.
Leica Camera AG used to have an archivist, however Herr Kaufmann disposed of his services to save money. It was unfortunate as one used to be able to search the archives and obtain the history of a camera.
Have fun.
Justin
My latest one:
Yours sincerely
Thomas
My latest one: [ATTACH]354476[/ATTACH] Yours sincerely Thomas
Congratulations Thomas, that really is a "find".
What is the serial number?
I sent mine to Ottmar Michaely, not only for a CLA, but also to allow the Model I to accept modern film cassettes.
Have fun.
Justin
  • 1 month later...
here one of mine : IIIb
Regards
Gerhard
I just received this Ic back from repair after it had been in pieces for over 20 years. Now it is ready to photograph the wide, wide world!
Nice to see another Ic returned to useful service! I just got mine back last week from Youxin Ye and it too is again in working order, after new curtains and replacing some missing internal parts. This was given to me in pieces, and I found a bottom plate (DAG) and covered the bare body shell (after patching the holes left by flash-sync conversion) with an Aki-Asahi material. When I got it there were loose screws rattling inside, and the curtains were crinkled and cracked. With a 35 it works well scale-focusing, but now to look for a FONOR or such...
The previous owner had it in a box with a focoslide, and indicated it had been used on a copy stand - so no range/viewfinder had been needed.
Edited by TomB_tx
A FOKOS will be the right choice for the look and the space occuped.
Something along these lines?
Susie
I have a nice black enamel FOKOS, but am missing the turret clip to mount it on the camera.
And I would like to acquire a nice chrome FOKOS with the clip and would use it with my chrome Standard (Model E) and the Ic.
Thanks... Maurice
