x
  • 3 weeks later...
Count me in with this one, Leica II eighty years young and as smooth as my M2.
Bill, useable they are, here is a shot of Farnz taken by Robert Parker who wanted to try it out. Just as it is in the photo it was loaded with HP5 @ 1600, and really low pub light most likely 1/20th sec.
I got the chance to see what one looks like while using it. It's little wonder people might not take you seriously with it, how little they know!
What a handsome devil!:D It must be a combination of the special light in the Chandos, the superb skills of the photographer and the awsome quality of the Leica II that portrays this otherwise gnarled subject in such a flattering way.:p
Pete.
Each one of these has a roll of film loaded into it and each one gets its turn to be taken out for a walk about once a week. They're all in excellent working order.
Front L to R: Leica II 1932, Standard 1939
Back L to R: Leica IIf 1953, Standard 1939, IIIf 1952
I've newly acquired some vintage gears.
The Barnacks hold a certain degree of sexiness for me. And I can't get enough of shooting with them.
1930 Leica I upgraded to II (D)
with Elmar 3.5cm f/3.5
1946 Leica IIIc upgraded to IIIf
with Collapsible Nickel Elmar 5cm f/3.5
I generally use Leica Ms & Nikon DSLRs.
I have been wanting to get a IIIf. I ordered a IIIf RD ST and a 90/2 LTM last week. I should have them this week.
How is the 90/2 LTM? Should i return the 90/2? Please advise.
I am planning to get a 50/2 or 50/3.5.
Thanks.
Thanks.
wait to get and next try them; if they are in good conditions you' ld not be disapointed.
One thing to check on your LTM Summicron 90/2 is whether it is a "real" LTM lens or one of the early Summicron M lenses with the LTM to M adapter (glued on by the factory) removed. The value is substantially different, as I believe that there were only 500 genuine LTM 90 Summicrons made (all in 1957) against quite a lot of Summicron-M Mk1's with the adapter. I forget now how to tell the difference, maybe something to do with the red mounting dot but our resident historical guru, Mr. Braconi of the post above, will I am sure, be able to give us the correct information. From memory, the early Summicron 90's are pretty large and heavy and you may find on the small IIIF body, is a bit unbalanced. A good performer for its day and a huge improvement on the 85/1.5 Summarex but don't expect it to compare with the stunning abilities of the later M fit 90mm lenses, in particular the 90 Elmarit-M and ASPH Summicron.
Wilson
One other point. In my opinion, for a 50mm lens, I would go for the collapsible Summicron rather than the 50/2 Summitar. I have a Summitar (hex diaphragm model, bought new by my father in 1953) on my IIF and it is quite soft wide open and aperture shifts noticeably. I was going to get a Summicron but got a focusing adapter to use my Zeiss Opton Sonnar 50/1.5 instead, which is as good as a collapsible Summicron if not slightly better.
Wilson
Thanks Mr. Braconi and Mr. Wilson.
I'll post pics of the 90/2 once I get it. Hope it is the real one. Yes, I read that the 90/2 LTMs are rare but not as good as the current 90/2.
I have two 90 Elmarits-R but do not have the M version. I use one on my Nikon w/Leitax and the other on my SL2 and SL.
Would love to have it a 90 Elmarit M.
Regards,
AB
The Ic is just back from a CLA by Youxin Ye and works beautifully. The Summaron is new to me as well and in superb condition
Strange but the image I (thought) I uploaded disappeared - I'll try again
Wilson
Don't know if it helps but I've used a Summilux 50 LTM on my II and that's pretty unbalanced (though still very nice to use; picture on the previous page in this thread). The 50 weighs 380gr and is 5,5cm long. The 90 is almost twice the size, 660gr and 11cm.
cheers
Philip
