Showing results for tags 'summilux 50'.
  • Forenumzug
    • Systemkamera Forum
    • Fuji X Forum (deutsch)
    • Fuji X Forum (English)
    • SAD Temp
    • CER Temp
Found 7 results
  1. Winter came late to Lebanon this season, Acile was the first storm to put our mountains under the beautiful snow mantel. A pair of backcountry skis was all I needed to go up one of the most beautiful cedars reserves to witness what Acile had done. Hope you enjoy the view.
  2. I did a direct comparison shot with the following 50mm Leica-M lenses: Summarit 2.5, DR Summicron, Summicron vers. V, APO-Summicron, Summilux V3, Summilux ASPH. All shot at aperture f2 (Summarit at 2.5), focus on infinity, lens hood, M10-P, jpg out of camera. Here’s the whole picture:
  3. Hi, I've entered the world of Leica for a year or so with the Q2, after ditching photography and my Nikon D90 for 5-6 years. This forum has been a great source of information for me from the beginning when researching about the Q2, and has also most certainly fueled some GAS. Well one thing led to another and now I have the Q2 plus an M10-P and 35 Summilux FLE + 50 Summilux ASPH. I got the 50 first and have been using it exclusively for the past 9 months (Only got the 35 last month). However, in the beginning of Jan 2021, I've noticed that I could not get as reliable focus with the 50 at F1.4 as I used to, even shots between 3-5m at F8 were out of focus dead centre. I did some research and testing and found out that the rangefinder patch did not align at infinity (got close but stops short). This happens with both the 35 and the 50, so it went off to get adjusted at Leica here in Bangkok. After adjustment everything seemed to be ok. Rangefinder patch now align at infinity for both lenses (vertical still slightly off but not an issue) and I could focus reliably with the 50 at 1.4 again, even at minimum distance of 0.7m. However, some shots at 2-3 meters now seem a bit off. But yesterday, F2 shots from 0.7m were slightly blurry, and all shots at F2 from 2-5 meters were off. When zoomed in the photos are not sharp at all. I then did a little test, taking photos slightly before the rangefinder patch aligned, which produced even blurrier pictures, and taking photos a bit pass the rangefinder patch alignment (about 1mm i.e. compensating for front focusing issues). The pictures taken with the rangefinder patch slightly past alignment were extremely sharp, as the 50 Summilux ASPH should be, and was when I first got it. I then swapped in the 35 Summilux FLE and did the same test at F1.4, resulting in photos identical in sharpness. I am aware that the DOF difference of the 35 may be masking any effects that are shown on the 50, as the DOF of 35 at F1.4 is 60cm, and 50 at F2 is 40cm. Unfortunately I don't have any long Leica lenses to test with. M10-P is still within it's 2 year warranty, bought 2nd hand but no dings or anything suggesting it has been dropped. Worked perfectly for the past 8 months as well. Both lenses were bought new and within warranty. Wondering what it might be. Maybe I need to send both the body for calibration again, but this time together with the 50 Summilux? I am really hoping that the lens does not have to go back to Germany.
  4. Tried to do Multi-shot exposure on my SL2s with Summicron-M 50mm, Super-Elmar-M21mm, Voigtlander APO-Lanthar 35mm. File size 12000x8000=96MB. Terrible result with all 3 lenses and I thought of doing something wrong. Changed to a super rigid tripod and the results were the same bad. Pictures look at 100% kind of having poor resolution. Even the 1 shot DNG files are in no way the quality of the same lenses on my M10-R. I use the original Leica M Adapter to L. All pictures shorter than 1/1000s. 100% crop. Anybody comes to the same conclusion.
  5. Searched online but couldn’t find a definite answer on this. Can anyone help me? I am trying to find out if the lux 50mm E46 pre asph (pic below) weights 275g (same as the regular black model) or if it’s heavier? If anyone who has the lens can let me know the exact weight I’d really appreciate it
  6. Hello everyone, I’m asking the question here because I can’t find anything researching online: Leica doesn’t offer lens coding service for the Summilux 50mm v2. i believe it’s due to the mounting method for that flange, which has no screws in the back and probably the barrel needs to be taken apart to do it. i am coding the lens with a Sharpie and it works, but the coding marks wear off with time. Does anybody know of a way to permanently code the lens? Dremel not an option! 😬 Thanks a lot!
