Showing results for tags 'rangefinder patch'.
More search options
    • Leica Q / Leica Q2
    • Leica FOTOS App
    • LHSA Member Forum
    • Leica FOTOS App
Name
PLZ
Found 2 results
  1. Hallo, nach einem kleinen Sturz auf Glatteis mit dem Kamerarucksack bewegt sich beim Fokussieren der eingespiegelte rahmen nicht mehr und lässt sich somit auch nicht mehr übereinanderlegen. Im Liveview funktioniert alles normal. Bei genauem hinsehen kann man durch das Fenster des Entfernungsmessers? sehen, dass etwas gebrochen ist (von außen jedoch keine Beschädigung). Was kann das sein? Ist das reparabel und wirtschaftlich sinnvoll? Bin Dankbar für jede Hilfe!
  2. Hey everyone, I just got my m2 off ebay and had a look through the viewfinder only to see 2 main very noticeable spots. I attached a picture and the one on the lower left looks much dimmer and looks like a dot and a hair almost? It's kind of light greyish and I think it's a particle or dust but I'm not quite sure. However, in the middle the speck seems much darker (basically black) and more prominent. Could this be separation or is it another speckle of dust (imo it doesn't seem like one). If this has happened to you or you know what it is, any input on how to fix or your thoughts would would be greatly appreciated! Also the shutter curtain on the front seems a little pushed forward and I can see the whole seam on it, is that normal? The curtain works 100% fine but I'm not sure if Im supposed to see the whole seam and overlap of the two curtains. On the back it stays slightly open by 1mm or so (didn't include a pic sorry)... should it cause a light leak? The camera was also recently CLA'd. Lastly, the viewfinder has some "gold specks" which I think is separation, but I hope i'm wrong. Please help if you can clarify, recommend a fix, or give any thoughts on ^^. Overall the camera seems amazing and none of the things I mentioned has really bothered me, but if I can learn more about them then it would be great. Thanks in advance, Ashley
