Showing results for tags 'rangefinder focus'.
Hi, I've entered the world of Leica for a year or so with the Q2, after ditching photography and my Nikon D90 for 5-6 years. This forum has been a great source of information for me from the beginning when researching about the Q2, and has also most certainly fueled some GAS. Well one thing led to another and now I have the Q2 plus an M10-P and 35 Summilux FLE + 50 Summilux ASPH. I got the 50 first and have been using it exclusively for the past 9 months (Only got the 35 last month). However, in the beginning of Jan 2021, I've noticed that I could not get as reliable focus with the 50 at F1.4 as I used to, even shots between 3-5m at F8 were out of focus dead centre. I did some research and testing and found out that the rangefinder patch did not align at infinity (got close but stops short). This happens with both the 35 and the 50, so it went off to get adjusted at Leica here in Bangkok. After adjustment everything seemed to be ok. Rangefinder patch now align at infinity for both lenses (vertical still slightly off but not an issue) and I could focus reliably with the 50 at 1.4 again, even at minimum distance of 0.7m. However, some shots at 2-3 meters now seem a bit off. But yesterday, F2 shots from 0.7m were slightly blurry, and all shots at F2 from 2-5 meters were off. When zoomed in the photos are not sharp at all. I then did a little test, taking photos slightly before the rangefinder patch aligned, which produced even blurrier pictures, and taking photos a bit pass the rangefinder patch alignment (about 1mm i.e. compensating for front focusing issues). The pictures taken with the rangefinder patch slightly past alignment were extremely sharp, as the 50 Summilux ASPH should be, and was when I first got it. I then swapped in the 35 Summilux FLE and did the same test at F1.4, resulting in photos identical in sharpness. I am aware that the DOF difference of the 35 may be masking any effects that are shown on the 50, as the DOF of 35 at F1.4 is 60cm, and 50 at F2 is 40cm. Unfortunately I don't have any long Leica lenses to test with. M10-P is still within it's 2 year warranty, bought 2nd hand but no dings or anything suggesting it has been dropped. Worked perfectly for the past 8 months as well. Both lenses were bought new and within warranty. Wondering what it might be. Maybe I need to send both the body for calibration again, but this time together with the 50 Summilux? I am really hoping that the lens does not have to go back to Germany.
- 8 replies
- summilux 50
- m10p
(and 2 more)
Tagged with:
Hallo, nach einem kleinen Sturz auf Glatteis mit dem Kamerarucksack bewegt sich beim Fokussieren der eingespiegelte rahmen nicht mehr und lässt sich somit auch nicht mehr übereinanderlegen. Im Liveview funktioniert alles normal. Bei genauem hinsehen kann man durch das Fenster des Entfernungsmessers? sehen, dass etwas gebrochen ist (von außen jedoch keine Beschädigung). Was kann das sein? Ist das reparabel und wirtschaftlich sinnvoll? Bin Dankbar für jede Hilfe!
Hi everyone. Following up on my M10-P Rangefinder drifting thread, where I asked whether the body was front focusing or not, I went to Leica in Thailand and even though the camera is still within it's warranty, they told me that they cannot solve focusing issues and the camera has to be sent to Singapore. As my camera was bought from HK, I will have to pay P&P of 250USD as well, and it will take around 2-3 months. I also would have to go find the receipt, as they cannot just look at the serial number for some reason. If I am unable to supply the receipt, then a maintenance fee will be charged as well. Yesterday I had some free time and was itching to get the problem sorted, so I researched this forum about DIY rangefinder adjustments and a few YouTube videos, went out and bought a 2mm Hex key for $1 and adjusted the roller for horizontal alignment myself, using the night stars as a guide for infinity. However, my vertical alignment is also off so there are always 2 stars in the focusing patch no matter what I do, making adjustment very difficult. At the end of all that, the rangefinder does not coincide at infinity, but focus from 0.7m - 5m seems to be accurate (still slightly front focusing but acceptable) for Summilux-M 50mm at F1.4. I have a few questions regarding the adjustments. Horizontal adjustment (please kindly see attached photo from the internet, of an M7?) When the hex key is inserted into the hole, and clockwise turns (red arrow) are very easy and the rangefinder arm does not move at all. However, when I try to turn anti-clockwise (green arrow) the rangefinder arm pivots down into the body with the turn, so I had to do a lifting motion whilst also turning the hex key. This lifted the rangefinder arm further out of the body once, but it then moved back so I am not sure whether this will cause any problems in the long term. I made sure not to press the rangefinder arm in the direction of the top plate and it looks the same as far as I can tell. Hopefully I didn't bend it? Vertical adjustment Apparently this can also be done with the 2mm hex key. However, I have no idea how to unscrew the cover screw on the camera without scratching it. Some have suggested wrapping a screwdriver in electrical tape first, but I am hesitating to attempt it. Has anyone else managed to removed the screw, and how did you do it? Any help would be much appreciated.
- 20 replies
- m10-p
- rangefinder focus
(and 1 more)
Tagged with:
Tell us about your M lens disasters. It is painful even to think about something happening to those precious little gems, let alone experiencing it. What was the worst that happened to your M lens? For me, it was water droplets between elements in my Noctilux 0.95 from a job in Southeast Asia. And I am not counting the french kiss with concrete floor of my 28/2.8 III Mandler Elmarit in Afghanistan.
