M9 strap eyelets
BretonBkk
Just wondering if a number of people had the strap eyelet of their camera coming off. It's very unpleasant has your really risk loosing your tool! Leitz should probably look into a more secure assemblage.
x
I don't think the design of the eyelets is particularly strong on any M camera. That is why I always say don't use a wrist strap that puts not only all the weight, but also a lot of twisting torque on one eyelet, not spreading just the weight 50/50 between two. First time I've seen it on an M9 though.
Steve
How are they fixed on an M2 or a lllf? I use both of these cameras with wrist straps, neck straps and a finger loop thingy, and have done for some years, no problems to date.
IIRC, the eyelets then were just a special kind of rivets that were put through holes in the body and flattened out on the inside with special tools that were inserted in the film chamber or (after getting the take-up spool assembly out) the ´take-up chamber´. I did have some of them come loose to the extent that they could be turned around (never actually fell off), and the local technician fixed them more or less on the spot.
The design in the photo here looks far more precarious; the size of those screws seem more fit for a watch movement than for carrying more than a kilogram of valuables around one´s neck...:(
I could never feel comfortable carrying around an M9 and a Nocti with (4) 5x8 screws holding almost 1300g of gear. Good grief!
"The full-metal housing, made from a high-tensile magnesium alloy, and a top deck and bottom plate machined from blocks of solid brass, provide perfect protection for their precious inner mechanisms. In short: an M camera is not only an investment for life, but also a lifelong companion."
Not to worry. The inner mechanisms will be protected as the camera slams into the pavement........
A major job to fix. The entire camera has to come apart IIRC. Not good.
And it means that doing a preventative fix to alleviate it from ever happening is pretty much impossible financially. One just has to keep their fingers crossed that it won't happen to them, there's nothing else to do. Hopefully Leica is making the lugs more robust with their current production.
Much like your hot shoe issue? Whats the world coming to when you can't even trust your Leica?
Well- yes but that hot shoe was stressed beyond its design parameters:o. Still. those were four similar screws.
