35FLE and filter reflections
Harryup
I'm using a Nex-7 and M5 together with 35/1.4FLE and WATE.
When using theNex and the WATE I'm using no filters and having no problems but with the Summilux I'm using a Leica UV-filter and getting some blue rings coming from reflections between the filter and front lens. Especially when shooting in dark scenes and there are light sources outside of the actual coverage of the lens.
Is the original square lens hood sufficient? Any alternatives?
Have anyone seen the same problem with any Leica Digital M's?
Without the filters I need to point the camera into the light source to get a very very vague symptom of the problem.
Thanks in advance
Harry
Just using the filter for protection and because I have never had the problem with the M5.
I have never had the problem with min Nikon DSLR neither with 35mm lenses.
But the new square lens hood could maybe been a bit longer without interfering?
How severe is the problem with a 240 since I will order one later?
/Harry
As said this will happen with any digital camera, it's simply a reflection from the sensor. It can happen without a filter too!
Maybe it's less of a problem on a DSLR because the sensor is further away typically, but it does still happen.
The solution is to remove your filter when using the camera in such circumstances.
/Harry
The problem is not severe in the first place. I don't want to start the protection filter wars again, but one should remove them in high flare risk situations. A solid lens hood is all the protection you need anyway.
  • 2 weeks later...
In practice I've found both Sigma EX DC and Hoya HD2 filters to have lower reflections than the Leica ones, they are true broadband multicoated. I have a Sigma EX DC on the 35mm FLE.
Bob.
I’m confused. According to the Hoya web site here in the UK there is no such thing as an HD2 filter moreover the filters in their HD series are not available in sizes below 52mm.
However a Hoya 49mm HD2 UV Filters is apparently available from B&H in the US at $62.90 (USD).
Don't use any filters when shooting during night time.
You WILL get reflections no matter what with a filter attached during shooting in very dim light or dark scenes with street lights and all types of strong light sources all over the place that you can't control.
Even the best of the best filters with 0.1% reflection rate WILL cause reflections in these conditions. This includes the Hoya HD series and B+W XS-Pro Nano MRC series filters. I'm talking from a lot of frustrating experience and wasted money on filters.
  • 2 years later...
