Annibale G. Posted September 10, 2007 Share #1 Posted September 10, 2007 Advertisement (gone after registration) Do you use filters for your B/W photography with your M camera? Which ones? and in what occasions? Annibale Quote Link to post Share on other sites More sharing options...
Advertisement Posted September 10, 2007 Posted September 10, 2007 Hi Annibale G., Take a look here Filters for Black and white and M cameras. I'm sure you'll find what you were looking for!
stunsworth Posted September 10, 2007 Share #2 Posted September 10, 2007 When I'm shooting b&w with the M6 I have a yellow filter on the camera most of the time to darken the sky an emphasise the contrast between clouds and sky. Occasionally I'll use an orange filter if I want that contrast to be even greater, and a red filter if I want the greatest contrast. Red filters do horrible things with caucasian skin tones - makes them very white. Quote Link to post Share on other sites More sharing options...
el.nino Posted September 10, 2007 Share #3 Posted September 10, 2007 same here. yellow and orange most of the time. Quote Link to post Share on other sites More sharing options...
topoxforddoc Posted September 10, 2007 Share #4 Posted September 10, 2007 Yellow most of the time too. Occasionally red when I want really dark moody skies Charlie Quote Link to post Share on other sites More sharing options...
Annibale G. Posted September 12, 2007 Author Share #5 Posted September 12, 2007 Do you suggest any use of the filters for reportage photography ? Quote Link to post Share on other sites More sharing options...
luigi bertolotti Posted September 12, 2007 Share #6 Posted September 12, 2007 I'm an avid mountaineer.. and UV is mandatory over 2000 meters... both for BW and color, for it's easy to have a certain impression of out-of-focus expecially with 90/135. In mountains, also orange or even red can give a value for contrast: red is great on glaciers. Quote Link to post Share on other sites More sharing options...
sender Posted September 12, 2007 Share #7 Posted September 12, 2007 Advertisement (gone after registration) Green and yellow/green is very useful too - helps with contrast in the sky, and great for eyes and skin. Quote Link to post Share on other sites More sharing options...
lct Posted September 13, 2007 Share #8 Posted September 13, 2007 Digital filters (Epson's) might help to compare. Color no filter: http://tinyurl.com/rv7w/EPSN3275_conofi-afterweb.jpg BW no filter: http://tinyurl.com/rv7w/EPSN3275_bwnofi-afterweb.jpg BW green filter: http://tinyurl.com/rv7w/EPSN3275_bwgrfi-afterweb.jpg BW yellow filter: http://tinyurl.com/rv7w/EPSN3275_bwyefi-afterweb.jpg BW red filter: http://tinyurl.com/rv7w/EPSN3275_bwrefi-afterweb.jpg Quote Link to post Share on other sites More sharing options...
octo Posted September 15, 2007 Share #9 Posted September 15, 2007 Yellow, yellow-green, orange and red. The first one being used most. Quote Link to post Share on other sites More sharing options...
lars_bergquist Posted September 16, 2007 Share #10 Posted September 16, 2007 Since the early 1960's, improved optical cement (!) and coatings make Leica lenses pretty impervious to UV. So clear UVa filters are for mechanical protection only, but as such worthwhile. Black and white with the M8 and the DMR is an entirely different matter. Color filters are not needed if you shoot DNGs and use a PP app with a channel mixer (read: PhotoShop) so that you can vary the contributions of the blue and red channels, thus simulating the effects of filters in the yellow-orange-red series. But if you shoot JPGs – blasphemous thought – you will need these filters just as when you are using film. With the exception of the yellow. Removing the UV/IR filter is enough, the native extended red and IR sensitivity does approximate an yellow filter, darkening blue sky and also lightening foliage. The old man from the Age of the Yellow Filter Quote Link to post Share on other sites More sharing options...
cbretteville Posted September 16, 2007 Share #11 Posted September 16, 2007 Yellow as a general rule, red for more effect and yellow-green when shooting people. - C Quote Link to post Share on other sites More sharing options...
spydrxx Posted September 16, 2007 Share #12 Posted September 16, 2007 Mostly yellow for outdoor photography, red where I want high contrast between clouds and the sky (but the greenery turns pretty dark). Used to use a green, but no longer. I assume you are talking about filters for film use rather than digital. Quote Link to post Share on other sites More sharing options...
lars_bergquist Posted September 16, 2007 Share #13 Posted September 16, 2007 The yellow-green filter 'should' reduce both blue and red. This idea however rests on some very simplistic thinking about object colours, i.e. spectral reflectances. Actual tests show that a yellow-green filter does only what a yellow filter does, but with more loss of speed (about 1 f-stop, as against 1/2 for the medium yellow). Such tests were in fact done already during the 1930's, but the result seems unable to budge the preconceived notions. The use of the yellow-green filter does seem mostly limited to Germany however. The green filter on the other hand does indeed darken red. The influence on blue seems no greater than that of the yellow filter, though. This filter was introduced during the 1930's, when some early panchromatic films (mostly 'fast' films, but also early Kodak Panatomic) exhibited an extended red sensitivity which gave light-skinned people the "panchro sickness", making them look positively tubercular. The use of this filter, outside landscape work – where yellow is more economic of light – decreased with the advent of pan films with a more even spectral sensitivity. Conclusion: You don't need any damn green filters. The old man from the Age of the Soap Box Quote Link to post Share on other sites More sharing options...
Kasimir Posted September 16, 2007 Share #14 Posted September 16, 2007 Heliopan states in it's instruction sheets that yellow filters reduce the light less or the same as green filters do. Maybe green filters are used in Germany because of this. I myself use them in Norway and find the results for landscapes - especially in spring - pleasing. Quote Link to post Share on other sites More sharing options...
stunsworth Posted September 16, 2007 Share #15 Posted September 16, 2007 Conclusion: You don't need any damn green filters So what would you recommend to lighten foliage? Quote Link to post Share on other sites More sharing options...
lars_bergquist Posted September 17, 2007 Share #16 Posted September 17, 2007 Ewald: I do not doubt that, I contend only (with good reason, I think) that a yellow filter would do the same job and save you one half stop of speed. Steve: A medium yellow filter with film. With a M8, just unscrew the IR/UV filter and put it in your shirt pocket ... The old man from the Age of Wratten Filters Quote Link to post Share on other sites More sharing options...
