I experimented with IR photography using my Elmarit 28/2.8 on the M8. I realized that this lens appears to cause a significant hot spot under IR conditions, especially with apertures 8 and up. :(
Can you please share your experience with other lenses on the M8 when using for IR photography?
Thanks!
Ralph
Thanks!
Ralph
ASPH or pre ASPH? I have no hotspots with my pre ASPH and Hoya IR72 filter.
I'm using the CV 21mm w/B+W 093 filter on the M8. No hotspots that I can see with the CV 21. Have used the Summicron 35mm ASPH and Summicron 50mm--also no hotspots. (These are "known safe" lenses.) Need to shoot more IR: Infrared - a set on Flickr
Ditto on the Zeiss 25mm photo posting--love to see some.
Thanks,
Will
  • 8 years later...
Wold be great if m8-shooters chime in on experiences with lenses working for ir-photography on the m8 (i.e., lenses without a central hot sport when using ir-filter).
Thanks...
I've been shooting infra-red handheld with my M8 for about 10 years and my favourite lens, which has no IR hot-spot, is the 21/2.8 Kobalux (which is also sold under the Avenon brand).
Before that I used the Voigtlander 35/1.2 Nokton v1 and there was no obvious hot-spot on that.  (Wide open it understandably vignettes a lot, which might be mistaken as a hot-spot at such a wide aperture but it's not.)
I used the Voigtlander 15/4.5 Ultra-wide Heliar v1 (LTM) for a while and it had no hot-spot but it became awkward to attach the IR filter owing to no filter thread and a fixed semi-hood.
The 35/3.5 Summaron has a reputation for having no IR hot-spot but I can't confirm since I haven't used it.
Pete.
An example I shot handheld this week with the 21/2.8 Kobalux on my M8 with a SinghRay I-Ray filter (830 nm).
Station Road Bridge on the River Ouse, York.
Hi!
So far I have tried and used a 28mm Elmarit-M ASPH (mkI) and a 50mm Summilux from 1971 with a Ø43mm original Leica filter, probably something like a R72 (+ a StepDown ring with the 28mm..), and a 21mm Elmarit-M ASPH and a 90mm Summicron (pre-ASPH) with a cheap eBay Ø55mm 950nm filter, and I have not detected any hot-spots as I can find with any of these lenses.. I haven't looked at very many photos yet, so if I see it in the future I will correct myself... ;)
Best regards,
Rune :)
M8 + 21mm SEM:
  • 1 month later...
VC Ultron 28/2. Hoya R72
  • 1 month later...
St Mary's Church Battersea, London.
M8 with Voigtlander 75/2.5 Color-Heliar MC with 093 infra-red pass filter.
  • 4 weeks later...
