pklein Posted September 5, 2009 Share #141 Posted September 5, 2009 Advertisement (gone after registration) I played with the numbers for number of pixels and sensor size, M8 vs. M9, The pixel pitches appear to be virtually identical at around 6.8 microns each, give or take a few hundredths. This means that the M9 will get no high ISO or dynamic range improvement based on pixel pitch alone. This means, in turn, that any improvement in high ISO performance could be obtained only by: 1. A significant decrease in the "dead space" between the pixels. 2. Improvement in the noise performance of the sensor or camera circuitry (better shielding, use of less noisy components, etc.) 3. Better signal processing, including noise reduction. If Leica and Kodak have somehow accomplished #1 or #2, great. If they've used #3, we may be faced with the age-old issue: Which is worse, noise or loss of detail? I am *very* interested in what available light samples at 640, 1250 and 2500 look like. Time will tell. Link to post Share on other sites More sharing options...
Advertisement Posted September 5, 2009 Posted September 5, 2009 Hi pklein, Take a look here M9 full specs and pictures are out. Let's discuss.. I'm sure you'll find what you were looking for!
UliWer Posted September 5, 2009 Share #142 Posted September 5, 2009 My black one weights 320g. I have seen that mistake many times (250g), wonder if some spec sheets were wrongly printed at some point. Put mine on the balance: 310g without hood (perhaps a little bit less). So the "250g" in the data sheet must be a real rumour. P.S.: This keeps me away of some thoughts that a new 35 SummiluxAsph. could mean the real great news on 090909. Link to post Share on other sites More sharing options...
nugat Posted September 5, 2009 Author Share #143 Posted September 5, 2009 I played with the numbers for number of pixels and sensor size, M8 vs. M9, The pixel pitches appear to be virtually identical at around 6.8 microns each, give or take a few hundredths. This means that the M9 will get no high ISO or dynamic range improvement based on pixel pitch alone. This means, in turn, that any improvement in high ISO performance could be obtained only by: 1. A significant decrease in the "dead space" between the pixels. 2. Improvement in the noise performance of the sensor or camera circuitry (better shielding, use of less noisy components, etc.) 3. Better signal processing, including noise reduction. If Leica and Kodak have somehow accomplished #1 or #2, great. If they've used #3, we may be faced with the age-old issue: Which is worse, noise or loss of detail? I am *very* interested in what available light samples at 640, 1250 and 2500 look like. Time will tell. at#1 you are talking fill ratio. It was something like 30% for the 2005 CCDs, could indeed improve a lot by 2009. #3 is of course gimmickry from ISO1600. I guess we have to wait another week or so.... Link to post Share on other sites More sharing options...
adan Posted September 5, 2009 Share #144 Posted September 5, 2009 Regarding the confusion on the weight of the 35 'lux ASPH - 250g is probably an accidental holdover from the era of the pre-ASPH 35 'lux, which extended well into the 1990s. In fact, both the pre-ASPH and the ASPH were in the catalogs at the same time, for a while, until the backstock of the pre-ASPHs was sold off. Link to post Share on other sites More sharing options...
twittle Posted September 5, 2009 Share #145 Posted September 5, 2009 Where is it in S/L? Pictureline The address is 305 West 700 South, SLC. Link to post Share on other sites More sharing options...
KM-25 Posted September 5, 2009 Share #146 Posted September 5, 2009 Pictureline The address is 305 West 700 South, SLC. I'll be there first thing in the AM, what good timing..:-) Link to post Share on other sites More sharing options...
Bo_Lorentzen Posted September 5, 2009 Share #147 Posted September 5, 2009 Advertisement (gone after registration) Dynamic range. Uli pointed this out earlier... Two shots of dark skin (REALLY dark) with highlights, the second shot is running with rimlight and white foam on the water.. still there are some shadow details on the back of the guy. this would have been hard to pull off with the M8... . Link to post Share on other sites More sharing options...
ennjott Posted September 5, 2009 Share #148 Posted September 5, 2009 That's no substitute fior a proper viewfinder, IMHO. This is so nearly a camera that I might buy, but if I have to use it with my arms outstretched, I am not interested. It's a very good substitute when properly used. Live view isn't meant to be used "with outstretched arms" - if you are far-sighted, you should do something about it (e.g. get bi-focal glasses). Viewed from 15-20 cm, LCDs allow for stable and convenient shooting. Link to post Share on other sites More sharing options...
ljclark Posted September 5, 2009 Share #149 Posted September 5, 2009 What does the M9 bottom look like? (Minds out of the gutter, ladies and gentlemen!) I think I answered my own question. Looking more closely at printouts of the brochure I see the little tab on the viewfinder end. So it looks like the concept for the bottom cover is the same, if not the actual (detailed) execution. Link to post Share on other sites More sharing options...
jaapv Posted September 5, 2009 Share #150 Posted September 5, 2009 It's a very good substitute when properly used. Live view isn't meant to be used "with outstretched arms" - if you are far-sighted, you should do something about it (e.g. get bi-focal glasses). Viewed from 15-20 cm, LCDs allow for stable and convenient shooting. Personally I think it makes for wobbly shooting. There is no body stabilisation of such a camera. Link to post Share on other sites More sharing options...
egibaud Posted September 5, 2009 Share #151 Posted September 5, 2009 I found the full brochure via google. I suppose someone will lose his job at Leica... hope for him this accidental posting was not so accidental but part of the marketing strategy. Anyway, reading the specs. I see 2500 ISO as maximum. I think that although if it is clean and they acheive no noise (still to be seen), it is too low. The good thing of being able to shoot at 6400 ISO on a Canon MKII or Nikon D700 / D3 is that although there is noise, it allows to shoot at faster speed. For people like me who avoid using flash it means having a moved picture or having a frozen one. Also higher ISO can help closing the lense a bit and not always shoot wide open in available light. If 2500 is perfectly clean, this is great news, but letting the photographer decide if noiser files at 3200 or 6400 are of interest to him would be logical. Link to post Share on other sites More sharing options...
thrid Posted September 5, 2009 Share #152 Posted September 5, 2009 It's a very good substitute when properly used. Live view isn't meant to be used "with outstretched arms" - if you are far-sighted, you should do something about it (e.g. get bi-focal glasses). Viewed from 15-20 cm, LCDs allow for stable and convenient shooting. There are several very good reasons why there isn't a single pro body out there that uses an EVF or live view, as it's sole means of composition. You can't do this with an EVF / LV camera. YouTube - Garry Winogrand Photographer Too much lag and tearing, noise in low light and lousy ergonomics, unless you are taking pictures of static or semi-static subjects. To solve the first two problems the display on the X1 would have to run multiple times faster than anything else out there. We'll know more in a few days. But the M9 looks really great. The DR in those 16bit files must be amazing. Link to post Share on other sites More sharing options...
arthury Posted September 5, 2009 Share #153 Posted September 5, 2009 I have a couple of remarks about the PDF brochure: Highlights: the highlights in most of images in that brochure are burnt. Seems like either the exposure metering is broken or something is drastically wrong with the dynamic range LCD: still 2.5" ---- sad. I would expect it to be 3". Even a P&S camera these days have 3" LCD. Link to post Share on other sites More sharing options...
jaapv Posted September 5, 2009 Share #154 Posted September 5, 2009 Put mine on the balance: 310g without hood (perhaps a little bit less). So the "250g" in the data sheet must be a real rumour. P.S.: This keeps me away of some thoughts that a new 35 SummiluxAsph. could mean the real great news on 090909. I happened to note the real weights of my lenses in the Leica catalog of 1983. Back then I found discrepancies of up to 150 grams. I think that situation still exist to some extent. Link to post Share on other sites More sharing options...
patrick parker Posted September 5, 2009 Share #155 Posted September 5, 2009 What is the round thing on the top plate of the x1 not the shutter speed nor the manual focus ring but the big button on the other edge with nothing written on it? Link to post Share on other sites More sharing options...
jaapv Posted September 5, 2009 Share #156 Posted September 5, 2009 Pop-up flash? Link to post Share on other sites More sharing options...
KM-25 Posted September 5, 2009 Share #157 Posted September 5, 2009 I have a couple of remarks about the PDF brochure:[*]LCD: still 2.5" ---- sad. I would expect it to be 3". Even a P&S camera these days have 3" LCD. My opinion?.....I'm sorry but this is not a drive in movie theatre, it is an M. A good photographer just needs to get in the ballpark and then get onto making photos. I think the screens on my D3 / D700 are great, but it would just not be a deal breaker if they were smaller. You can expect more resolution, brighter LCD's, faster scrolling / zooming, but for Pete's sake, it does not need to be bigger on a Leica M. I am getting more and more excited about this camera and I am going to see it in person on Wednesday. Link to post Share on other sites More sharing options...
nugat Posted September 5, 2009 Author Share #158 Posted September 5, 2009 I have a couple of remarks about the PDF brochure: Highlights: the highlights in most of images in that brochure are burnt. Seems like either the exposure metering is broken or something is drastically wrong with the dynamic range LCD: still 2.5" ---- sad. I would expect it to be 3". Even a P&S camera these days have 3" LCD. Exposure to the right (histogram) seems to be a rule most people are afraid to break. I on the other hand like inpenetrable blacks and "burnt" lights--where they have an artistic justification. Cuba is a hot, sun-scorched place. The artist chose to depict it that way. It would be naive to think that he did not know how to expose or the meter was broken. Link to post Share on other sites More sharing options...
stunsworth Posted September 5, 2009 Share #159 Posted September 5, 2009 To get back on topic. As an unreconstructed film-only user, who reads these threads purely out of interest, can I ask the following. Is there any indication on how Leica solved the formidable technical problems associated with the highly oblique rays of the short M system back-focus distance and a full frame sensor? It appears to be a new generation of micro-lenses on the sensor. I expect there's alos some in camera processing to reduce the vignetting, but that's purely speculation on my part. Link to post Share on other sites More sharing options...
jaapv Posted September 5, 2009 Share #160 Posted September 5, 2009 You think? I have both the 35 and 50 Luxes and like I said, hardly ever at ISO 160. For me, that alone would justify the buying of the camera. I'm always shooting on the brink of a flashing 4000. Link to post Share on other sites More sharing options...
