Sign in to follow this
nugat
M9 full specs and pictures are out. Let's discuss.
Not being grumpy here, but…
One problem I have with a future purchase is the following :
adjusting all my M lenses to my M8 body for front- or backfocusing
has been pretty difficult and costly (my 75 being even not quite satisfatorily
adjusted until now).
In fact, the only lenses which did not need any adjustment were
my 50 Lux and my 28 Elmarit bought new last january and my 50 Summicron.
Otherwise, Noctilux, 75, 21, 35 Lux, 50 pre-ASPH and 90 Elmarit needed adjustment.
I fear the same problems with the M9 : re-adjust everything to that
second body specifically, meaning I could not keep the M8 a a backup.
According to DAG.
I'm curious, just how 'bad' is it without having the lenses 'coupled' to the body? I've not owned a lens, well, other than a 90 Cron that I sold because I thought I just couldn't focus properly with at that focal length, that didn't perform according to expectations - is it dumb luck or dumb me?
Share this post
Difficult lenses should be easier to focus on the new body.
http://www.l-camera-forum.com/leica-forum/1021749-post1.html
According to DAG.
Share this post
Good :
- ability to select lens manually, coding will not be necessary though still useful for added quickness.
I can't see anywhere that suggests lenses can be selected manually.
Share this post
thanks,so they couldn't do .72?
Not without one of the following:
  • dropping the 28mm framelines
  • reducing the thickness of the body to that of the film Ms
  • total redesign of the range/viewfinder.
Share this post
It doesn't say anywhere that its 16-bit. 16-bit is an assumption (probably a wrong assumption) based on the data size.
Sandy
From Brochure (under Lightroom):
At the same time, the 16-bit per channel color information captured by the image sensor is
maintained throughout the processing workflow from image import to image export, ensuring
that the most delicate tonal differentiations are preserved in maximum quality after completion of the post-processing sequence.
Share this post
I couldn't find a 50lux that would focus on my M8 body. Eventually I sent camera and lens in for service, now focuses fine - and so do most other 50lux I try. I think the problem was mostly in the cameras.
Share this post
comprendo
Share this post
Blimey, a quick Google and there's the brochure.
First thoughts, how have they managed FF in the existing body, why not chrome (tho the grey looks nice), top plate is very bare tho, needs the traditional Leica script, and .... where's the flash pc socket!!!!
Share this post
Yes, but the problem is, previously "16-bit per channel color information" is a phrase that hasn't had any meaning. In fact, for some time, the M8 was described the same way. 16 A/D converter, that would be meaningful.
The good news is that clearly however you can select full width DNGs, not only 8-bit compressed
Sandy
Share this post
That would make sense. I have a 50 Lux and it focuses nicely. Hopefully this wouldn't be an issue with M9!
Share this post
Cuba - a country whose leadership has spent the last 40 years resisting change.
Is that why Leica thought it was a good place for the brochure shoot?
Share this post
Battery is product nr. 14464 - so my pocket full of M8 batteries will work. good stuff.
Let's see...Being optimistic regarding improvements in the electronics -- shooting for the same kinds of files -- my first guess is 50% more shots per battery.
(I should start a pool.)
Share this post
...And a land where people have learned it's best to keep secrets.
Share this post
Oh and no M8 in the M line up any more. I wondered if they would rework the M8 and continue it as a less expensive option, or maybe they will launch such a product at a later stage.... but the M7 and MP continue I'm glad to see.
Share this post
I agree about the bare top plate. The people who designed the M3 put the script there for more reasons than just to show the maker's name. And providing no way to use an auxiliary viewfinder with flash shows that Leica still don't care.
Share this post
Loading...
    No registered users viewing this page.
