On 12/17/2025 at 9:14 AM, Markey said:
I can appreciate that POV .
I`m new to the flip screen (Q3 43) and am slowly appreciating how useful it might be although I must admit ,for me ,I`m always forgetting its there .
As for IBS ... again I`ve had 40 years of using M`s and the lack thereof hasn`t been an issue ,but again I can see that it could be .
I didn`t mean to suggest that it was a smaller SL in every respect  just a useful Iteration of the current M style.
I can understand, if you are a long time M user, no IBIS, tilt screen etc... This may not make a lot of sense. Trust me, as schipper mentioned, it really helps with high megapixel sensors.
13 minutes ago, SrMi said:
I doubt it, but that fear is probably why many oppose M-EV1.
Must admit that I thought that (even if not articulated as the long term goal) it may in the future become an inevitability .
If the M EV has legs it will be easier to justify .
Maybe retain the RF as a limited historical model with a commensurate price tag of course.
It would probably make economic sense in todays world .
23 minutes ago, Planetwide said:
I had hoped that Leica would install a 9.44 million dot EVF into the MEV, and the SL4 hint hint... These panels are very close to an optical viewfinder.
I have cameras with 9.44Mdot EVFs, and they are miles away from OVFs. The issue with EVFs is not so much the resolution as contrast and dynamic range.
I think the biggest fear is having a $9k hole in one's bank account, just for Leica to come along in a few years and make the EV2 so much better (at least for this freelancer that's a big hole; not so much for some). Plenty of stopgap EVF camera bodies for a lot less.
23 hours ago, WvE said:
I guess, or fear, is that the M EV will be the future of the M. The OVF will disappear completely over time.
Well I don't. The concern is that Leica will do reputational damage for producing a compromised camera. On this forum there is quite a lot of interest in the M EV1, on others there is a lot of bafflement as to why it exists at all and a lot of negativity. 7k is a lot to pay for what are at best marginal improvements over other EVF camera with adapters and M lenses.
for 37 years of that 40 years ibs was not realy usefull with te leica m but since the sensor is above the 40 mp it is not only usefull but it is almost not possible to get a razor sharp picture without IBS
There's a thing called a tripod ......
The difference between 24MP and 60MP in handholding shutter speed for razor-sharp images at the pixel level is about one stop. IBIS is essential for both low- and high-resolution sensors.
If you cannot make razor-sharp images with M11, you will not be able to make them with an M10, either.
Of course, nothing beats the sharpness of an image taken on a tripod. Too often, IBIS can introduce blur in corners.
You may wish choose faster shutter speeds to avoid camera shake blur, if any. 1/(2f)s works well for me. YMMV.
1 minute ago, jjroroek said:
that dousn't work in low light situations. wher you need de maximum in shutterspeed , large aparture en the iso not over 3200
Again, one stop at pixel level and likely no difference if you shoot in lower resolution mode. In practice, four stops make a difference, but one stop not so much.
thats not true. With the m10 about 70% of my pictures were razorsharp at 1/60 . the problem started with the m10R. a perfect camera but less sharpness  at 1/60. on my q3 i can shoot razorsharp at 1/15
It seems I wasn't clear.
I wrote that with higher-resolution sensors, you need a 1-stop faster shutter speed. That means you need to shoot at 1/125 with M-EV1, whereas 1/60 would have been sufficient with a lower-resolution sensor (no stabilization). If that one-stop difference is too much for you (I argue it is not), you can shoot M-EV1 in lower resolution mode at 1/60 and get a sharper image.
For me, the Leica Q3 produces sharp images without OIS at 1/120, but with OIS at 1/15. That is a three-stop difference, and I think that three-stop difference matters, but one stop does not.
