MaxGor Posted June 16, 2024 Share #1 Posted June 16, 2024 Advertisement (gone after registration) Hello All, Anyone tried using Pentax AF201FG Flash on M11? Did manual modes (1/4 and full) work as expected? I have got this flash with my Ricoh GR3, wondering if it will work on Leica M11. Link to post Share on other sites More sharing options...
Advertisement Posted June 16, 2024 Posted June 16, 2024 Hi MaxGor, Take a look here Pentax AF201FG Flash on M11. I'm sure you'll find what you were looking for!
jaapv Posted June 16, 2024 Share #2 Posted June 16, 2024 Just try it. It should work in manual and automatic mode. Link to post Share on other sites More sharing options...
MaxGor Posted June 16, 2024 Author Share #3 Posted June 16, 2024 2 minutes ago, jaapv said: Just try it. It should work in manual and automatic mode. Hmm, how it will work in automatic - it is not the same camera brand... I tried in manual and it works, but even 1/4 of full power badly overexposed(when auto iso is on with correction -1). I might work better in daylight, I tried in a dark room with not much light coming through the window. Link to post Share on other sites More sharing options...
jaapv Posted June 16, 2024 Share #4 Posted June 16, 2024 Automatic is not TTL, it uses the thyristor in the flash. On manual you must calculate the aperture and switch off auto ISO. You don’t want the camera kicking it up because it is dark. Link to post Share on other sites More sharing options...
MaxGor Posted June 16, 2024 Author Share #5 Posted June 16, 2024 Interesting, in Auto it does pretty much the same thing - I am getting back white frame... Probably something fully manual is needed here. Link to post Share on other sites More sharing options...
geotrupede Posted June 19, 2024 Share #6 Posted June 19, 2024 not familiar with this unit but, M1 or M1/4 is not a lot of a choice. Plus the auto, where is the sensor that regulates that? Maybe it does rely on the camera exposure meter? Usually flashes with the auto mode have a photocell on the front... Link to post Share on other sites More sharing options...
MaxGor Posted June 19, 2024 Author Share #7 Posted June 19, 2024 Advertisement (gone after registration) 19 minutes ago, geotrupede said: not familiar with this unit but, M1 or M1/4 is not a lot of a choice. Plus the auto, where is the sensor that regulates that? Maybe it does rely on the camera exposure meter? Usually flashes with the auto mode have a photocell on the front... Indeed. manual control here is pretty limited. That auto stuff never properly worked on GR3, I though it was sort of TTL... Will be getting FlashQ Q20 when its back to stock on UK amazon. Link to post Share on other sites More sharing options...
Anbaric Posted June 19, 2024 Share #8 Posted June 19, 2024 From the instructions, the only 'Auto' mode this particular flash has is a Pentax-specific TTL auto mode, which won't work with Leicas. Therefore you can only use the manual modes. There is another type of automatic mode found on many older flash units that is also typically called 'Auto', which is what jaapv is thinking of. This uses a sensor in the flash itself rather than TTL flash metering. The automation is much more rudimentary that what you'd get with a dedicated Leica system flash (SF 40 / SF 60), but it can still be useful. 1 1 Link to post Share on other sites More sharing options...
MaxGor Posted June 20, 2024 Author Share #9 Posted June 20, 2024 8 hours ago, Anbaric said: From the instructions, the only 'Auto' mode this particular flash has is a Pentax-specific TTL auto mode, which won't work with Leicas. Therefore you can only use the manual modes. There is another type of automatic mode found on many older flash units that is also typically called 'Auto', which is what jaapv is thinking of. This uses a sensor in the flash itself rather than TTL flash metering. The automation is much more rudimentary that what you'd get with a dedicated Leica system flash (SF 40 / SF 60), but it can still be useful. This is what I thought about AF201FG auto mode - seems manual is only an option and two power outputs are pretty limiting., but it is not like it's totally unusable. Link to post Share on other sites More sharing options...
jgeenen Posted June 20, 2024 Share #10 Posted June 20, 2024 Am 16.6.2024 um 20:36 schrieb MaxGor: Hmm, how it will work in automatic - it is not the same camera brand... I tried in manual and it works, but even 1/4 of full power badly overexposed(when auto iso is on with correction -1). I might work better in daylight, I tried in a dark room with not much light coming through the window. Auto ISO on camera will most likely result in overexposure because the camera cannot take the (unknown) flash light into consideration. Will be the same with the Q20. Agreed, The two choices 1/4 and „full“ are not exhaustive but should be suitable for normal flash photography situations 1 Link to post Share on other sites More sharing options...
MaxGor Posted June 20, 2024 Author Share #11 Posted June 20, 2024 18 minutes ago, jgeenen said: Auto ISO on camera will most likely result in overexposure because the camera cannot take the (unknown) flash light into consideration. Will be the same with the Q20. Agreed, The two choices 1/4 and „full“ are not exhaustive but should be suitable for normal flash photography situations I am shooting with -1 exposure correction in auto iso mode. I am hoping that I could set Q20 to small output, so it will not overexpose that badly. Link to post Share on other sites More sharing options...
charlesphoto99 Posted June 20, 2024 Share #12 Posted June 20, 2024 4 minutes ago, MaxGor said: I am shooting with -1 exposure correction in auto iso mode. I am hoping that I could set Q20 to small output, so it will not overexpose that badly. You do not want to use auto iso with a manual flash (and imo you shouldn't use auto iso ever but that's another story). That's not how manual flash works. Set your fixed iso, and then set your aperture (and a shutter speed to balance out the ambient light if you want). Adjust aperture as needed, and/or the intensity of flash as needed. With manual flash, it's typically trial and error, though one can become pretty efficient at it, and it works best with a flash that has endlessly variable settings in manual, like the Profoto A10 I use so one can just leave the aperture alone and scroll the intensity of flash output on the fly depending on how close/far one is to the subject. See example below with M10M and 18mm Elmar. You can't try and marry one 'dumb' (or manual) thing with one 'smart' (or auto) thing and expect it to work. Welcome, dear visitor! As registered member you'd see an image here… Simply register for free here – We are always happy to welcome new members! Link to post Share on other sites Simply register for free here – We are always happy to welcome new members! ' data-webShareUrl='https://www.l-camera-forum.com/topic/396265-pentax-af201fg-flash-on-m11/?do=findComment&comment=5368744'>More sharing options...
MaxGor Posted June 20, 2024 Author Share #13 Posted June 20, 2024 (edited) I just need a bit of fill in effect - only to soften shadows, etc... Outside it will be pretty difficult for me to have everything on manual - I am hoping that EV correction up to -3 will do the trick. It is my plan/theory - I never tried it before, possibly I am talking rubbish. PS Great shot by the way! Edited June 20, 2024 by MaxGor Link to post Share on other sites More sharing options...
geotrupede Posted June 20, 2024 Share #14 Posted June 20, 2024 godox lux senior is quite ok, the lux master is also fun but you need the trigger and the x3L is not yet available (but soon will be). and the master does not do auto as well as the senior (unless you get another piece of kit which is a remote lux sensor). alternatively go for used leicas, the SD24 or sf58 (need firmware update by a leica shop). the most functional with auto, ttl, and hss is the sf58. but $$$. and quite big. but works great. G. Link to post Share on other sites More sharing options...
jaapv Posted June 21, 2024 Share #15 Posted June 21, 2024 It is very much easier to buy a vintage flash with traditional thyristor type Auto setting and proper output controls. Trying to use brand-dedicated flashes on other brands is bound to lead to problems. Or buy a universal flash like this one: https://th.hkyongnuo.com/products/yn560-iii Link to post Share on other sites More sharing options...
MaxGor Posted June 21, 2024 Author Share #16 Posted June 21, 2024 14 hours ago, geotrupede said: godox lux senior is quite ok, the lux master is also fun but you need the trigger and the x3L is not yet available (but soon will be). and the master does not do auto as well as the senior (unless you get another piece of kit which is a remote lux sensor). alternatively go for used leicas, the SD24 or sf58 (need firmware update by a leica shop). the most functional with auto, ttl, and hss is the sf58. but $$$. and quite big. but works great. G. 3 hours ago, jaapv said: It is very much easier to buy a vintage flash with traditional thyristor type Auto setting and proper output controls. Trying to use brand-dedicated flashes on other brands is bound to lead to problems. Or buy a universal flash like this one: https://th.hkyongnuo.com/products/yn560-iii Thanks both, I am looking for smallest and lightest option. Great thing about flashq q20 ii is not its small size and weighs, but also it is easily detachable from camera hot shoe and becoming wireless. And this all costs about $100. Link to post Share on other sites More sharing options...
jaapv Posted June 21, 2024 Share #17 Posted June 21, 2024 Yes, but it is a Pentax flash, and you need a generic or Leica one. Link to post Share on other sites More sharing options...
MaxGor Posted June 21, 2024 Author Share #18 Posted June 21, 2024 2 minutes ago, jaapv said: Yes, but it is a Pentax flash, and you need a generic or Leica one. Yeah, it actually works as generic, in generic(fully manual) it provides 1/4 of full power output - that is only the limitation. Link to post Share on other sites More sharing options...
250swb Posted June 21, 2024 Share #19 Posted June 21, 2024 I use an Olympus FL36 that was marketed for the m43 cameras but can also be set to '35mm' format in the menu. As such it's a TTL flash that defaults to 'Auto' or 'Manual' on other cameras where the TTL won't work. To use it on 'Auto' you need to set the ISO you want on the flash and on the camera, set the lens focal length on the flash, and away you go, the flash then calculates the distance to the subject and it's output. It would be very odd for a camera manufacturer such as Pentax not to have used generic circuitry such as this in a flash gun. 1 Link to post Share on other sites More sharing options...
dugby Posted June 21, 2024 Share #20 Posted June 21, 2024 1 hour ago, MaxGor said: Thanks both, I am looking for smallest and lightest option. Great thing about flashq q20 ii is not its small size and weighs, but also it is easily detachable from camera hot shoe and becoming wireless. And this all costs about $100. Quite a few smallest lightest speedlights were discussed last year in the above link Link to post Share on other sites More sharing options...
