tomasis7 Posted April 3, 2024 Share #21  Posted April 3, 2024 (edited) Advertisement (gone after registration) 13 hours ago, jaapv said: It is not that simple: https://www.howtogeek.com/769888/what-is-usb-power-delivery-usb-pd/#usb-power-delivery-adds-the-volts The charge reduction algorithm is incorporated in any decent charger to protect the battery lifespan   it is simple Both devices need to have PD. If one of them doesn't have a PD, it works in the old way aka USB 2 (to ensure backward compatibility). Same for USB adapter. Edited April 3, 2024 by tomasis7 Quote Link to post Share on other sites More sharing options...
Advertisement Posted April 3, 2024 Posted April 3, 2024 Hi tomasis7, Take a look here SL3 battery charger question. I'm sure you'll find what you were looking for!
jaapv Posted April 3, 2024 Share #22  Posted April 3, 2024 I’m sure you are right regarding the specs. However I have had no issues whatsoever when mixing devices and USB types. Some are twenty years old. My main charging block has both USB A and USB C outlets and there adapters just work. 1 Quote Link to post Share on other sites More sharing options...
tomasis7 Posted April 3, 2024 Share #23 Â Posted April 3, 2024 Likely suboptimal charging. If one wants to be on the safe side, stick with 1A and accept very long charging hours Quote Link to post Share on other sites More sharing options...
jaapv Posted April 3, 2024 Share #24  Posted April 3, 2024 1 minute ago, tomasis7 said: Likely suboptimal charging. If one wants to be on the safe side, stick with 1A and accept very long charging hours Dunno. My original M8 batteries from 2006-2007 still hold plenty of charge. The only ones that needed a rebuild were my DMR ones, but they are notorious for dying. 1 Quote Link to post Share on other sites More sharing options...
tomasis7 Posted April 3, 2024 Share #25  Posted April 3, 2024 (edited) 6 hours ago, jaapv said: Dunno. My original M8 batteries from 2006-2007 still hold plenty of charge. The only ones that needed a rebuild were my DMR ones, but they are notorious for dying. I "bricked" the Garmin Inreach Mini with a 2,4A charger. The device takes in only 2 watts. I got it replaced quickly by warranty. It happened to me when I was in the middle of the sea. Bricked Garmin Inreach is very common. 2nd version got the USB-C instead. If one charges Leica batteries with the original charger, there is nothing to think of. Buying Chinese 3rd party chargers adds new headaches especially when you mix chargers like 2.4A but thankfully we got USB-C. My Epson Rd1 battery holds well. I need to remind myself to top up it sometimes. 3rd party batteries died quickly. The Leica charger offers to charge up to 80% on SLC4 which is nice. I already use the charging system between 20%-80% to ensure the longevity of the batteries. Phones, laptops, whatever. LFP is quite nice and can take abuse, unlike Li-lion. Edited April 3, 2024 by tomasis7 Quote Link to post Share on other sites More sharing options...
Kentf Posted May 4, 2024 Share #26  Posted May 4, 2024 On 4/2/2024 at 3:52 AM, la1402 said: You can use any charger, it just will take longer. But in order to charge two batteries in parallel, you need 27W on the USB port of your charger. Most multiport chargers are below that. If you are below that, it is no problem, it just will charge serially. This is the key info.  Without the higher wattage the charger runs the batteries in sequence rather than parallel.  Took me a bit to figure out. Quote Link to post Share on other sites More sharing options...
V23 Posted May 5, 2024 Share #27  Posted May 5, 2024 Advertisement (gone after registration) On 4/2/2024 at 10:48 AM, scott kirkpatrick said: Charging an SL3 battery in an older SL2 or SL charger doesn't seem to work, since those batteries had a lower capacity. ‘Charging an SL3 battery in an older SL2 or SL charger doesn't seem to work, since those batteries had a lower capacity.’ New battery delivers 18% more capacity, other then that I can not see why SL2 charge would not charge this battery. Quote Link to post Share on other sites More sharing options...
V23 Posted May 5, 2024 Share #28  Posted May 5, 2024 On 4/3/2024 at 4:47 AM, tomasis7 said: No, Usb C supports different voltages (up to 20v) meanwhile old USB sticks to 5v always. You can kill a device with a 65w USB2 charger if the device supports max 35w. But USB-C has a communication protocol and gives only the required voltage/wattage the connected device asks for. The pinout diagram of USB-C is below. USB 2 pinout is simplistic, with only 4 pins, and has no communication to a device for the required wattage delivery. See the yellow-colored CC1 and CC2. Welcome, dear visitor! As registered member you'd see an image here… Simply register for free here – We are always happy to welcome new members! Any item be it battery charger or camera that is connected to a USB C would have in its input a voltage and current regulator thus protecting the rest of the electronic circuitry. Quote Link to post Share on other sites More sharing options...
scott kirkpatrick Posted May 5, 2024 Share #29  Posted May 5, 2024 4 hours ago, V23 said:  ‘Charging an SL3 battery in an older SL2 or SL charger doesn't seem to work, since those batteries had a lower capacity.’ New battery delivers 18% more capacity, other then that I can not see why SL2 charge would not charge this battery. I tried using my old SL2 charger to charge an SL3 battery and found it wasn't working. I think it is because my SL and SL2 kits are pre-USB C Quote Link to post Share on other sites More sharing options...
Photoworks Posted May 5, 2024 Share #30  Posted May 5, 2024 21 minutes ago, scott kirkpatrick said: I tried using my old SL2 charger to charge an SL3 battery and found it wasn't working. I think it is because my SL and SL2 kits are pre-USB C I am using the old chargers just fine Quote Link to post Share on other sites More sharing options...
tomasis7 Posted May 5, 2024 Share #31  Posted May 5, 2024 6 hours ago, V23 said: Any item be it battery charger or camera that is connected to a USB C would have in its input a voltage and current regulator thus protecting the rest of the electronic circuitry. No. The regulator is used for only sending current. How does the regulator know how much to send? The output device receives the info from the input device and then charges at the proper voltage and current. The receiving end has some form of protection of the circuit. It would be overheated if the desired voltage/current is not properly communicated. Thats why it has old USB compatibility. Quote Link to post Share on other sites More sharing options...
V23 Posted May 6, 2024 Share #32  Posted May 6, 2024 16 hours ago, tomasis7 said: No. The regulator is used for only sending current. How does the regulator know how much to send? The output device receives the info from the input device and then charges at the proper voltage and current. The receiving end has some form of protection of the circuit. It would be overheated if the desired voltage/current is not properly communicated. Thats why it has old USB compatibility. I am referring here to the devise i.e. camera having voltage and currant regulator. Potentially you could have a power supply capable to deliver 1000A and 5 or 8 Volts and the internal regulator limiting it to down the lane to the rest of the circuit to say 8V and 1A. Refer to the Ohm Law for further study. Quote Link to post Share on other sites More sharing options...
tomasis7 Posted May 6, 2024 Share #33  Posted May 6, 2024 6 hours ago, V23 said: I am referring here to the devise i.e. camera having voltage and currant regulator. Potentially you could have a power supply capable to deliver 1000A and 5 or 8 Volts and the internal regulator limiting it to down the lane to the rest of the circuit to say 8V and 1A. Refer to the Ohm Law for further study. from what to what? Quote Link to post Share on other sites More sharing options...
algrove Posted May 30, 2024 Share #34  Posted May 30, 2024 (edited) On 4/1/2024 at 4:03 PM, hmarkweidman said: A new SL3 just arrived. I also purchased a USB-C Dual Charger BC-SCL6 with a second battery. I assumed the charger could simply be plugged into 120V AC, but as the name implies, the only port is for a USB-C cord. Can I simply plug the charger into one of my Apple Mac computers, using a USB-C cable? Or, does it require an adapter of some sort – the charger instruction sheet notes a USB-C AC Adapter (Leica ACA-SCL6) but does not specify use. Thanks! Sure you can use an Apple charger if it is at least outputting what 27 watts. Edited May 30, 2024 by algrove Quote Link to post Share on other sites More sharing options...
Jptsr1 Posted May 31, 2024 Share #35  Posted May 31, 2024 As some have said above you can absolutely use your apple charger. I've used a small ipad charger (the 18w one I think) and it works although slowly.  By far the worst thing about the new charger is there's no branding on it. When I'm charging at my kids events with other dad's there's no way for them to know how much better I am than them. 1 Quote Link to post Share on other sites More sharing options...
Carrot Posted May 31, 2024 Share #36  Posted May 31, 2024 I’ve found that if I put a ‘4’ and ‘6’ battery in the charger together, only the ‘6’ charges. The ‘4’ will only charge if I remove the ‘6’. 1 Quote Link to post Share on other sites More sharing options...
Jptsr1 Posted May 31, 2024 Share #37  Posted May 31, 2024 58 minutes ago, Carrot said: I’ve found that if I put a ‘4’ and ‘6’ battery in the charger together, only the ‘6’ charges. The ‘4’ will only charge if I remove the ‘6’. Interesting. I have 2 of each. They are all full but I'll try next time I charge. Quote Link to post Share on other sites More sharing options...
Photoworks Posted May 31, 2024 Share #38  Posted May 31, 2024 on-the-road setup for SL3 SL2 batteries  Welcome, dear visitor! As registered member you'd see an image here… Simply register for free here – We are always happy to welcome new members! 1 Quote Link to post Share on other sites Simply register for free here – We are always happy to welcome new members! ' data-webShareUrl='https://www.l-camera-forum.com/topic/392224-sl3-battery-charger-question/?do=findComment&comment=5315954'>More sharing options...
TeleElmar135mm Posted May 31, 2024 Share #39  Posted May 31, 2024 vor 45 Minuten schrieb Photoworks: on-the-road setup for SL3 SL2 batteries  Welcome, dear visitor! As registered member you'd see an image here… Simply register for free here – We are always happy to welcome new members! ... and here is the perfect belt  1 Quote Link to post Share on other sites More sharing options...
vhsin964 Posted May 31, 2024 Share #40  Posted May 31, 2024 1 hour ago, Photoworks said: on-the-road setup for SL3 SL2 batteries  Welcome, dear visitor! As registered member you'd see an image here… Simply register for free here – We are always happy to welcome new members! I can nor charge BP-SCL6 by Nitecore recharger. Quote Link to post Share on other sites More sharing options...
