Sandokan Posted March 24, 2024 Share #1 Posted March 24, 2024 Advertisement (gone after registration) Hi, This has bothered me for many years and that is what does the "sensitvity" mean when selecting focus peaking? It is not just a question for M users but also SL. My confusion is which has the narrower of tolerances for what is and is not in focus; "Low" or "High" sensitvity? I like to setup for B&W with red peaking. Even with an f1 lens, the peaking occurs over a range of focus. I know on the M11P, if I turn on magnification and peaking, it is most accurate, but generally for street shooting, I do not have time to magnify so I just want it to show peaking when i am focused on my subject. 2 Link to post Share on other sites More sharing options...
Advertisement Posted March 24, 2024 Posted March 24, 2024 Hi Sandokan, Take a look here Sensitivity of focus peaking. I'm sure you'll find what you were looking for!
pop Posted March 24, 2024 Share #2 Posted March 24, 2024 I presume that the sensitivity setting controls the depth of the range that's marked as sharp. You can easily visualize the effect when pointing at a gravel path or some similar structure at an angle,with the sensitivity set to different values. Depending on that setting, focus peaking might highlight just a thin line or a larger area of the gravel. When in a hurry, you can move the focus so that the subject of interest stands in the middle of the highlighted area. 2 Link to post Share on other sites More sharing options...
frame-it Posted March 24, 2024 Share #3 Posted March 24, 2024 16 minutes ago, Sandokan said: Hi, This has bothered me for many years and that is what does the "sensitvity" mean when selecting focus peaking? It is not just a question for M users but also SL. My confusion is which has the narrower of tolerances for what is and is not in focus; "Low" or "High" sensitvity? I like to setup for B&W with red peaking. Even with an f1 lens, the peaking occurs over a range of focus. I know on the M11P, if I turn on magnification and peaking, it is most accurate, but generally for street shooting, I do not have time to magnify so I just want it to show peaking when i am focused on my subject. low = ballpark range [not accurate], high = finer detail [vaguely accurate but difficult to see unless zoomed in] on the SL2S/GFX/XH1[all with manual focus lenses] - i keep the screen on mono and use peaking RED-Low, then zoom in with BBZ to check, adjust and shoot. 1 Link to post Share on other sites More sharing options...
frame-it Posted March 24, 2024 Share #4 Posted March 24, 2024 13 minutes ago, pop said: subject of interest stands in the middle of the highlighted area. that's the area of real focus 99% of the time Link to post Share on other sites More sharing options...
lct Posted March 25, 2024 Share #5 Posted March 25, 2024 3 hours ago, Sandokan said: I know on the M11P, if I turn on magnification and peaking, it is most accurate, but generally for street shooting, I do not have time to magnify so I just want it to show peaking when i am focused on my subject. You may wish to try auto zoom. Menu page 4, Capture Assistants > Focus Aid : Automatic. 2 Link to post Share on other sites More sharing options...
Sandokan Posted March 25, 2024 Author Share #6 Posted March 25, 2024 Thanks all for the tips. The problem with focus peaking is it peaks at a certain place in the photo and stays lit up as you focus by more than ten degrees, even at f1.2 (yesterday lens), which is clearly not focused anymore. I have one profile setup with autozoom, but as turning the ring requires a large movement before autozoom kicks in, I have the top plate button set for this which is faster. I wanted a view of the full screen without autozoom and focus peaking on (red colour with jpeg set to B&W) and to know which is the more accurate indicator of plane of focus setting; High or Low sensitivity. Both seem to have a similar latitude to the plane of focus. There is nothing in the manuals of the M11, M10 or SL about the difference between the two. I want to rely on this when trying street photography as it is faster than zooming in. I was hoping this would be as fast but more accurate than optical rangefinder focusing. My eyes are not as good as they once were. I will just stick to using the rangefinder for this style of photography. I guess the distance and under estimate the distance. My instinct is to turn the lens clockwise which brings the subject into focus. Slightly reversed when using a Nikon RF where the lenses focus the other way round, so I overestimate the distance. Link to post Share on other sites More sharing options...
pop Posted March 25, 2024 Share #7 Posted March 25, 2024 Advertisement (gone after registration) 30 minutes ago, Sandokan said: I was hoping this would be as fast but more accurate than optical rangefinder focusing. My eyes are not as good as they once were. I don't think FP will ever be as fast and accurate as the RF, even with poor eyesight. With a good rangefinder I have been able to focus accurately even with my reading glasses on. It's not only the coincidence of contours, but also that the image suddenly becomes very crisp. My eyesight has never been very good, as I have a somewhat pronounced coma. 1 Link to post Share on other sites More sharing options...
lct Posted March 25, 2024 Share #8 Posted March 25, 2024 I like much RF as my favorite focus aid in the film days but how i feel it, focus peaking is faster when i count the time spent by doing focus / recompose in RF mode. There is a bit of learning curve though. Link to post Share on other sites More sharing options...
pop Posted March 25, 2024 Share #9 Posted March 25, 2024 This is what the CL does. First image is with high sensitivity, second image with low sensitivity. Your camera might do it the other way 'round for all I know. As I don't have much gravel on my desk, I used a structured mat. You can clearly see that the 'high sensitivity' lowers the threshold for the contrast detection. Usually, I set the sensitivity to 'low' unless I use a lens or a subject with a smallish contrast. Welcome, dear visitor! As registered member you'd see an image here… Simply register for free here – We are always happy to welcome new members! 2 2 Link to post Share on other sites Simply register for free here – We are always happy to welcome new members! ' data-webShareUrl='https://www.l-camera-forum.com/topic/391586-sensitivity-of-focus-peaking/?do=findComment&comment=5131723'>More sharing options...
davidmknoble Posted March 25, 2024 Share #10 Posted March 25, 2024 Focus peaking is from the sensor and uses contrast. So, high contrast items can sometimes appear to be in focus using focus peaking, but not in reality (as you mentioned with f/1.2). Lower contrast items sometimes have a little trouble with focus peaking because of the lack of contrast. So, here are the rules of thumb I follow: 1. If I am shooting with a higher f/stop and larger depth of field, I use simple focus peaking and get pretty much what I want all the time. 2. If I am shooting with a narrow depth of field (50 noctilux at 0.95 - 1.4, APO 90 at 2.0-4.0) I use the zoom function and focus until the EVF shows the crisp detail I want, ignoring the focus peaking at full size. Clearly, if I am focusing on moving subjects with narrow depth of field, it isn’t so easy, but then I typically switch to a native SL or autofocus lens (if on the SL) or use the rangefinder (if on the M). 2 Link to post Share on other sites More sharing options...
jaapv Posted March 25, 2024 Share #11 Posted March 25, 2024 It wasn’t Leica but Sony using a high-contrast Apo Telyt 180 to photograph a herd of Zebra with focus peaking resulted in a complete red-out of the viewfinder, lending credence to the colloquial “a Dazzle of Zebras 😉”. I regard peaking as a practical aid as long as one walks the focus to find the middle of the DOF field but never as a precision technique. Combined with magnification it is better. I usually set it to white to create shimmering edges. 3 Link to post Share on other sites More sharing options...
Sandokan Posted March 25, 2024 Author Share #12 Posted March 25, 2024 11 hours ago, pop said: This is what the CL does. First image is with high sensitivity, second image with low sensitivity. Your camera might do it the other way 'round for all I know. As I don't have much gravel on my desk, I used a structured mat. You can clearly see that the 'high sensitivity' lowers the threshold for the contrast detection. Usually, I set the sensitivity to 'low' unless I use a lens or a subject with a smallish contrast. Thanks Philipp, that is what I thought; LOW = lower sensitivity (less likely to shimmer until focus is reached). I shall play over the weekend with it. Link to post Share on other sites More sharing options...
Sandokan Posted March 26, 2024 Author Share #13 Posted March 26, 2024 Thanks to Frame-It:- https://blog.kasson.com/the-last-word/manually-focusing-the-fujifilm-gfx-50s/ this is a pretty good explanation and tutorial. My expectations will not be met by focus peaking alone, I will need the magnified view. 1 Link to post Share on other sites More sharing options...
davidmknoble Posted March 28, 2024 Share #14 Posted March 28, 2024 (edited) On 3/25/2024 at 9:21 AM, jaapv said: Combined with magnification it is better. I usually set it to white to create shimmering edges. +1 Edited March 28, 2024 by davidmknoble 1 Link to post Share on other sites More sharing options...
Krusty Posted May 25 Share #15 Posted May 25 (edited) Low sensitivity = more reliable, which means if something is in the focus peak, then the probability that it is sharp is high and the chance that useless objects are not in the peak is also high? high sensitivity = peak happens earlier than the low sensitivity peak but the risk that here is useless information also in the peak ? Did I understand it right? Edited May 25 by Krusty Link to post Share on other sites More sharing options...
pop Posted May 25 Share #16 Posted May 25 5 minutes ago, Krusty said: Low sensitivity = more reliable, which means if something is in the focus peak, then the probability that it is sharp is high and the risk that useless objects are not in the peak is also high? high sensitivity = peak happens earlier than the low sensitivity peak but the risk that here is useless information also in the peak ? Did I understand it right? In principle, yes. You also might want to lower the sensitivity when the amount of 'peaking' overwhelms you and is too intense to be of any use. 1 Link to post Share on other sites More sharing options...
thierry40 Posted May 25 Share #17 Posted May 25 This interesting question brings another to my mind, is there a focus peaking color that seems more practical to you guys in general? I only used red thus far and I seem to see mostly red but how about other choices ? Link to post Share on other sites More sharing options...
Krusty Posted May 25 Share #18 Posted May 25 vor 2 Minuten schrieb thierry40: This interesting question brings another to my mind, is there a focus peaking color that seems more practical to you guys in general? I only used red thus far and I seem to see mostly red but how about other choices ? I shoot DNG and set the jpg setting to black and white. so the viewfinder also turns into Black and white although you shoot DNG. And then I use red focus peaking... I just switched to low sensitivity but I didn't have the chance to test it today... maybe next weekend. 1 Link to post Share on other sites More sharing options...
lct Posted May 25 Share #19 Posted May 25 35 minutes ago, thierry40 said: This interesting question brings another to my mind, is there a focus peaking color that seems more practical to you guys in general? I only used red thus far and I seem to see mostly red but how about other choices ? Matter of taste and/or eyesight i guess. For me, white is more visible. 1 Link to post Share on other sites More sharing options...
pop Posted May 26 Share #20 Posted May 26 8 hours ago, thierry40 said: This interesting question brings another to my mind, is there a focus peaking color that seems more practical to you guys in general? I only used red thus far and I seem to see mostly red but how about other choices ? I find yellow very useful, but my CL does not do that. The Sony does. 1 Link to post Share on other sites More sharing options...
