WvE Posted January 17, 2024 Share #1 Posted January 17, 2024 Advertisement (gone after registration) My M2 refuses to rewind the film when it is halfway into rewinding. A visual inspection did not result in any issues as far as I can tell. Does anyone have a clue what might cause this, or experienced a similar issue? Thanks. Link to post Share on other sites More sharing options...
Advertisement Posted January 17, 2024 Posted January 17, 2024 Hi WvE, Take a look here Leica M2 rewind issue . I'm sure you'll find what you were looking for!
250swb Posted January 17, 2024 Share #2 Posted January 17, 2024 So you’ve opened the camera and not all the film has been rewound into the cassette? One thing that could happen is you accidentally flicked the rewind lever on the front of the camera and stopped it rewinding. There is no way to determine exactly how far you have rewound an exposed film, so ‘halfway’ must be a subjective decision, so have you maybe come to the end of rewinding and the film has been stubborn disengaging from the take up spool? And expectations about film advance or rewinding can change if you’ve accidentally loaded a 24 exposure film and thought it was a 36 exposure film. 1 Link to post Share on other sites More sharing options...
TomB_tx Posted January 17, 2024 Share #3 Posted January 17, 2024 Does your M2 have lever or button rewind release? Link to post Share on other sites More sharing options...
WvE Posted January 18, 2024 Author Share #4 Posted January 18, 2024 11 hours ago, TomB_tx said: Does your M2 have lever or button rewind release? It has the button rewind release. It's very strange, the film gets stuck rewinding halfway, or the last thirds. Could it be that when accidentally pushing the rewind release button, during rewinding, can cause this? I have lost two exposed films but will do a test with a cheap film. Link to post Share on other sites More sharing options...
colonel Posted January 18, 2024 Share #5 Posted January 18, 2024 if you open the body can you determine what is sticking it ? this is likely to be: 1. rip on film - unlikely to happen two times in a row, unless when you load it you are ripping something, or the film make is cr@p 2. you are pressing the rewind knob back in minutely by mistake - make sure it is out 3. the rewind lever is not that important. just check it is clicked to rewind when it gets stuck 4. is the rewind knob gritty or full of friction ? it could just be seizing up and need a clean 5. it is possible that one of the components of the rewind know is worn, and is moving during winding until it prohibits the mechanism I would try another film. Different make. If it does it again, then you need to take it to a technician to have a look 1 Link to post Share on other sites More sharing options...
ktmrider2 Posted January 18, 2024 Share #6 Posted January 18, 2024 Early M2's with button rewind required you to hold the button in while rewinding. Do not know if that is your problem or not but you might sacrifice a roll to the film gods and see. 1 1 Link to post Share on other sites More sharing options...
WvE Posted January 18, 2024 Author Share #7 Posted January 18, 2024 Advertisement (gone after registration) Thanks for the comments, I'll give it another go this weekend. Link to post Share on other sites More sharing options...
WvE Posted January 20, 2024 Author Share #8 Posted January 20, 2024 Ran a test film through my M2 and it seems that when the film gets stuck halfway, I just need to push the rewind release button another time. 2 Link to post Share on other sites More sharing options...
a.noctilux Posted January 20, 2024 Share #9 Posted January 20, 2024 I have two M2, one early button type and one with R lever. The button type lets rewinding only when the R button is pushed. I develop a habit to rewind this M2 button pushing R with other hand. Once the habit is there, memory muscle do the rest. 2 Link to post Share on other sites More sharing options...
Pyrogallol Posted January 20, 2024 Share #10 Posted January 20, 2024 Sounds like it is the version where you only have to push the button down once and not hold it down, but it slips back up, so maybe hold it down through all the rewinding? 3 Link to post Share on other sites More sharing options...
