jaapv Posted February 27, 2024 Share #121 Posted February 27, 2024 Advertisement (gone after registration) 1 hour ago, lct said: A practice i have never used in 20+ years but if it works for others i have nothing to say against it. Edit: Except that i don't see how backup memory can be done and user profiles exported to a card if it is locked, sorry if i sound negative this way. You export FROM the card which is locked for incoming traffic, I.e. the mess that computers send back. You cannot use a locked card in the camera. I don’t see how a locked card would prevent you from seeing and downloading your images, even with the lock broken. The lock changes your card into read-only memory. Link to post Share on other sites More sharing options...
Advertisement Posted February 27, 2024 Posted February 27, 2024 Hi jaapv, Take a look here Occasional unreadable dng . I'm sure you'll find what you were looking for!
lct Posted February 27, 2024 Share #122 Posted February 27, 2024 4 minutes ago, jaapv said: You export FROM the card which is locked for incoming traffic, I.e. the mess that computers send back. You cannot use a locked card in the camera. I don’t see how a locked card would prevent you from seeing and downloading your images, even with the lock broken. The lock changes your card into read-only memory. I export from the internal memory to the SD card. Not sure how this could work if the card is locked but i'm no techie Link to post Share on other sites More sharing options...
jaapv Posted February 27, 2024 Share #123 Posted February 27, 2024 That would be impossible on a locked card. The card should be locked when inserted into the reader, not in the camera. Link to post Share on other sites More sharing options...
lct Posted February 27, 2024 Share #124 Posted February 27, 2024 (edited) 4 minutes ago, jaapv said: That should be impossible on a locked card. That's what i suspected thank you. Edited February 27, 2024 by lct Link to post Share on other sites More sharing options...
