x
Lots of fair points but, as I think somebody else pointed out... the bottom line is that you need to find a reviewer that you trust. There are a thousand ways to discount a reviewer's opinion (most obvious being that, theoretically, Leica might "cut off" a beta-reviewer who doesn't recommend their product, and said reviewer, again theoretically, might be afraid of losing either some income via YouTube views or the undeniably cool privilege of secretly getting new merch before it's released to the masses). Similarly, somebody who bought the camera with their own $ (vs. getting it for free) obviously has some confirmation bias.
I actually find negative reviews to be the most interesting to watch. One example that comes to mind is Samuel Streetlife's "watch this before you buy the q2" video (linked below). I ended up buying a Q2 anyway (😅) but this video was valuable and interesting nonetheless.
On 6/1/2023 at 9:56 AM, nick h said:
I still would like a separate 75mm version of a Q (Qt - for telephoto - or different letter) and then there is a proper combo that one can shoot with to get the job done properly. I just can't use digital zoom with losing resolution. Certainly not for a client when working.
A 28mm and a 75mm would be great. A number of pro photographers I have come across using Q or Q2s have agreed with me on this and said they would love one. Then they wouldn't have to lug around a Nikon, Canon etc. with a longer lens. (I use a Nikon with a 85mm f1.4).
Whilst two cameras is a bit of a hassle, it does mean that there is the consistency of image quality, and size and weight advantages.
Any thoughts, anyone?
Curious, for those that use any of the Q's in a "pro" (i.e. paid) setting, how much does it bother you only having one SD card slot and no internal memory? Obviously it's extremely unlikely (has never happened to me since I've had my Q2) but, theoretically, you may find after a wedding (or other "not happening again" event) that your SD card was corrupted or broken, in which case your client will be devastated. At that point it's not even about the money. Of course, having two SD card slots (like in basically all the other brands' "pro" cameras) makes the "very unlikely" situation more of a "virtually impossible" situation.
Not if they buy gear to review. There is a huge difference between actual independent reviewing (not using the patronage of manufacturers) and people who buy a camera, then post their thoughts about it.
"The only thing influencing me to buy photo stuff is this site. I guess that makes @LUF Adminan influencer…"
Websites like this are about exchanging info/opinions, etc as opposed to "influencers," who are bloggers with sites established specifically to promulgate the 'owner's" recommendations/generate income.  On websites like this one you get a variety of views on just about every subject. On a blog you get  the views of the blogger, who, in some cases, has little actual knowledge of a subject but has an opinion anyway.
I’m not a pro anymore, but when I was, there were always two bodies. With film the risk was the same: if one roll went wrong you lost that part. So, with two bodies (not necessarily another Q) and smaller cards one reduces the risk.
That said, I never had any card failing on me (use sandisk), but will also never cull down in camera.
I once had a Sandisk CF card fail on me, took a week and a few thousand $, but the work was recovered (little profit on that job) since then I shoot pro jobs with redundant media. I don’t blame Sandisk, was just a matter of time.
That would never be the case here..........
  • Haha 2
vor 6 Stunden schrieb Aram Langhans:
Does anyone know if you can export your user profiles from the Q2 and import them into a Q3 instead of remaking them all?
The Q3 has quite a different menu structure compared to the Q2. So taking over the profiles will not work.
On 6/11/2023 at 10:28 AM, Al Brown said:
The only card that hasn't failed is the one about to.
Yea I guess we all need a stable of back up cars too. How do so many people get through life with only one?
16 years of professional digital work here - the one time a card messed up for me was on an early nikon D1H when I pulled it out too soon. IE user error. Not saying one of my cards won't ever fail, but like, life has always been fine relying on one card. One card slot has never bothered me - so much so that when I have two card slots I tend to use the second as overflow.
I've never had an SD card fail either - on the other hand I have had a camera go bonkers at a wedding - all looked fine when shooting, but the camera sent about 60 corrupted DNG files to both SD cards - right in the middle of the ceremony. . . . so I wouldn't say having two SD card slots made problems 'virtually impossible'!
Best
Jono
Been shooting for about 20 years now. I’ve never once had any issues with a card. Same for all my other photography friends. Obviously, it does happen, as some users have mentioned, but I think it’s in the extreme minority.
Unfortunately…not possible.
I tried…had to redo entire setup which was very time consuming as I use all available profiles.
Best
Jono
While you’re right… the situation I’m describing is having the CARD fail. What’s “virtually impossible” is TWO cards failing independently of one another.
But point well taken! Many things can (and do) go wrong.
Always love reading your thoughts.
mine arrived Saturday and after owning the q and q2 the quirks i have with it is noticeable longer start-up time which suuuuuuucks because i use it on weddings.
That was the real power of my previous q2 it was a really fast point and shoot camera. Hopefully they can fix it an update.
To me the focus looks on par with the q2 and im really baffled bbecause it hunts almost as much as the q2 did or im am doing something wrong  so please correct me if so
iso seems a lot better. As are the evf and lvd screen. On par with my sl2s
no internal memory is such a shame as i thought this was the new way to go with the smaller bodies.
all in all a marginally update in my honest opinion 🤷‍♂️
