Review: The Leica Summilux-M 35 f/1.4 ASPH. by Jonathan Slack
@jonoslack Having handled both of the close focusing M lenses, would you say the “detent” at .7m focus feels the same in both lenses? Or does one feel like a more significant bump than the other as you turn past .7m?
I wish the bump on the 35 APO were a little stronger/more firm so I had a better sense on the fly when I reach .7m and subsequently turn past it. As it is now, the bump is fairly subtle.
Thanks!
Thanks!
Well, I think they feel about the same - but you should understand that I have a prototype lens, and things may have changed for the shipping version. I must say I don't see it as a problem - if you are using the rangefinder then it just stops moving, and if you are using the EVF / Live view then of course you can see the focus.
Hi @jonoslack, many thanks for posting your overview of this lens. I received a copy of the lens the day after launch date and am very happy with its performance on the M11.
I have a question for you. Some Leica websites state that one of the features of this lens is "optimized for M11 cover glass thickness". For example, here on the Leica Manchester website:
https://www.leicastoremanchester.com/35-mm-summilux-m-mk2-asph.html
You didn't mention this in your original overview. Is it something you have received any information about from Leica?
(My own understanding, after doing a bit of research, is that such an optimization could reduce aberrations particularly when shooting wide open)
Edited by phototrope
On 9/18/2022 at 9:11 AM, Jeff S said:
Jono, the guy who created the ‘King of Bokeh’ term (Mike Johnston, now publisher of The Online Photographer…TOP) agrees with your assessment and has since written about his regret over the term. The term first appeared in a picture caption in the photo magazine he edited at the time.  But he hadn’t used the lens at wide aperture or close distance. BTW, he was also the first to spell out the term ‘bokeh’ to help readers with the pronunciation of the Japanese term ‘boke,’ from which it derived. He now dislikes that overused term, too, and prefers ‘out-of-focus-blur.’  You can read all the background in various articles he’s since written at TOP.  Despite his retraction and regret, the terms have indeed stuck.
Jeff
How about OOFA for out of focus affect (as apposed to OOFE out of focus effect), for those obsessed with the creaminess of backgrounds drawn by a lens, or the lack thereof. ;<)
Hi there
Thanks for pointing this out
I understood that the optical formula is identical, and you couldn’t do this without changing the optical formula!
If it’s true then why don’t Leica mention it in their marketing?
I’m doing some research to check up on this, I’ll get back when I know more.
All the best
Jono
Edited by jonoslack
  • Thanks 2
23 hours ago, jonoslack said:
Hi there
All the best
Jono
Hi Jono,
Many thanks for looking into this.
A quick google search brings this up in a few other web pages. One such page is this "press release":
https://newsroom.notified.com/transcontinentagroup/posts/pressreleases/new-leica-summilux-m-35mm-f14-asph-for-high-r
which says the lens has been "redesigned and optimized for the Leica M11 sensor cover glass thickness and high resolution".  So.. I don't know.
vor 20 Minuten schrieb Robert Blanko:
… which raises the question: did Leica change the thickness of the sensor cover glass from M10 to M11? 🤔
This Marketing. The lens design is the same as the older  35Lux ASPH. with or without FLE. All this lenses works with modern M digital cameras. Of cours M10-R and M11 are equipped with "high(er)" resolution sensors. So, no new lens optical design (mecanics are new).
Am 23.9.2022 um 11:24 schrieb jonoslack:
There must be a difference in quality between the Apo Summicron 35 and the Summilux 35, because otherwise Leica could not justify that the Summilux costs less. But that does not rule out the possibility that there have been minor changes to the optical calculation of the Summilux, which Leica does not propagate in order not to dilute the distance to the Apo Summicron. However, Your tests and the test of another fellow forum member I spoke to tend to indicate that nothing has changed in the main weakness of the Summilux, the colour fringing at open aperture at higher contrast.
Thanks for the testing, evaluation, images, and review. I prefer the threaded 12465 hood, and dedicated 14212 hood cap, available with the already-extant 2010 FLE, and am not so sure I need close-focusing capability in a 35mm lens. (I do not yet own a 35mm FLE, but the same general type of hood and cap is present on the Elmar-M 24mm ASPH, which I do have.) Indeed, it was your excellent article, on the line of M APO lenses, that helped convince me to acquire a pre-owned APO Summicron-M 75mm ASPH, rather than get on a waiting list for the close-focusing APO Summicron-M 35mm ASPH.
While I am not likely to buy this new, close-focusing 35mm Summilux FLE, the close-focusing 35mm APO does remain interesting, for some time in the future.
vor 19 Stunden schrieb elmars:
Certainly, The prices of some special glasses are very high. This may explain sometimes the differences. However concerning the Apo35M, I guess the mecanical construction is more complexe. It is probably very hard to adjust the lenses in ths small and complex body.
  • 4 weeks later...
The early demo photographs are not doing anything for me but this might be because they are digital photographs and the qualities of this lens may, like IMO the 28mm Summaron-M, be better demonstrated using film. I'm open minded about this new lens. The price is okay (I thought it would cost more) and the size is very appealing but it needs to do more than a bit of rainbow flare to tempt me to buy it.
