zkramez Posted August 28, 2022 Share #1 Posted August 28, 2022 Advertisement (gone after registration) I have an M9 with the updated sensor from 2017 (most recent one) I tried cleaning it with my rocket blower then I used the proper swabs. it got a lot off but not everything. It really needs a professional cleaning… here is the issue… I called Leica in NYC and they won’t even touch it. They refuse to touch M9s. Pretty wild they won’t clean their own product. what should I do? Can any camera store do a good job? Or is the M9 sensor that fragile? Link to post Share on other sites More sharing options...
Advertisement Posted August 28, 2022 Posted August 28, 2022 Hi zkramez, Take a look here M9 Updated Sensor Cleaning. I'm sure you'll find what you were looking for!
Topsy Posted August 28, 2022 Share #2 Posted August 28, 2022 I've cleaned mine using wet swabs no problem just like any other camera. 1 Link to post Share on other sites More sharing options...
Robert M Poole Posted August 28, 2022 Share #3 Posted August 28, 2022 Leica store Manchester have always cleaned my m9 foc, never had an issue. Link to post Share on other sites More sharing options...
Guest Posted August 28, 2022 Share #4 Posted August 28, 2022 If the muck isn’t coming off the sensor, give it another go until it does. Use clean swabs each try. Link to post Share on other sites More sharing options...
250swb Posted August 28, 2022 Share #5 Posted August 28, 2022 (edited) It just needs either a wet clean, or a clean with sticky gel pads, and an idiot could do it......if they can read the instructions. Seriously it isn't difficult to do a wet clean or use sticky gel pads. Since the dawn of the digital age photographers have been cleaning their own sensors without having to go back to the camera shop to hold their hand simply to remove a bit of sticky dust, and the camera shop does not give those menial jobs to their brightest employees. So just to stop you searching high and low to find an answer, get an Eyelead gel pad kit which will on a maintenance basis keep your sensor clean. Every now and again you may get a very sticky dust problem or indeed a problem with oily spots shed from the shutter in the M9. For this you need the Visible Dust products of swabs and cleaning fluid made for oily spots and not just the fluid for a general sensor clean. Edited August 28, 2022 by 250swb Link to post Share on other sites More sharing options...
pedaes Posted August 28, 2022 Share #6 Posted August 28, 2022 (edited) 1 hour ago, zkramez said: professional cleaning… Do you think there is a training school somewhere for sensor cleaning handing out certificates of competence. Plenty of good YouTube videos - if you start with those from the people that make cleaning products you need go no further. You have to be prepared to invest in the best products and 250swb has given you these in previous post. Relax and learn to enjoy the task! Edited August 28, 2022 by pedaes Link to post Share on other sites More sharing options...
david strachan Posted August 29, 2022 Share #7 Posted August 29, 2022 Advertisement (gone after registration) Eyelead Sticky Gel Pads left pale circular marks on my sensor. A couple are still there, although faded somewhat after normal sensor cleaning. An expensive experiment! 1 Link to post Share on other sites More sharing options...
ianman Posted August 29, 2022 Share #8 Posted August 29, 2022 I had marks with the sticky gel things too. After getting the new sensor I used a Lenspen sensor cleaner which worked perfectly. I’ve only had to use it once since I had the sensor changed in 2016. The old sensor collected dust better than my Dyson, the new one doesn’t seem to attract any and I’ve changed lenses just about anywhere. I am just an amateur sensor cleaner. 1 Link to post Share on other sites More sharing options...
1joel1 Posted August 30, 2022 Share #9 Posted August 30, 2022 My local camera repair shop cleans my sensor. I print out the instruction for them to keep the shutter open and they always do a great job. Link to post Share on other sites More sharing options...
jaapv Posted September 1, 2022 Share #10 Posted September 1, 2022 On 8/29/2022 at 3:32 AM, david strachan said: Eyelead Sticky Gel Pads left pale circular marks on my sensor. A couple are still there, although faded somewhat after normal sensor cleaning. An expensive experiment! That means those were oil spots and you can remove them with Smear Away. Link to post Share on other sites More sharing options...
jaapv Posted September 1, 2022 Share #11 Posted September 1, 2022 Why does nobody read the M FAQ ? There is a very clear post on sensor cleaning. 1 Link to post Share on other sites More sharing options...
ianman Posted September 1, 2022 Share #12 Posted September 1, 2022 9 hours ago, jaapv said: Why does nobody read the M FAQ ? There is a very clear post on sensor cleaning. Maybe any FAQs should be given a more prominent position in the forum hierarchy. At the same level as the wiki perhaps? But even that seems to be underused. Its also probable the the answers should be revisited. Not all but some, now that we have much more experience using the products mentioned and the availability of newer products for the sensor cleaning for example. Link to post Share on other sites More sharing options...
jaapv Posted September 1, 2022 Share #13 Posted September 1, 2022 It is being checked from time to time and is pinned at the top of various M forums. It is participatory thread, member additions are welcome. PMs with corrections are also welcome. However, there is a limit to the time that moderators can invest in the forum. Link to post Share on other sites More sharing options...
ianman Posted September 1, 2022 Share #14 Posted September 1, 2022 Sure, I understand that. TBH I didn't know it is a participatory thread as it shows up as locked. I did look before my previous post and, to me, it's not that user friendly. Again, maybe put it next to the wiki in the main menu? Link to post Share on other sites More sharing options...
earleygallery Posted September 1, 2022 Share #15 Posted September 1, 2022 I worked with a guy once who took his new car back to the dealership to get them to tune is radio to BBC Radio 4. Really, some tasks really should be easy enough to DIY. Link to post Share on other sites More sharing options...
