setuporg Posted January 31, 2022 Share #21 Posted January 31, 2022 Advertisement (gone after registration) Never take hoods along but Iceland tip is super appreciated.:) To make S kit small take 70 and 100. Perhaps 35. Or one lens, 70 or 45. Hire a sherpa. There's no other ways. S stands for NOT Small.:) 1 Link to post Share on other sites More sharing options...
Advertisement Posted January 31, 2022 Posted January 31, 2022 Hi setuporg, Take a look here Making the S+lens combo smaller...?!? . I'm sure you'll find what you were looking for!
Pieter12 Posted January 31, 2022 Share #22 Posted January 31, 2022 Size-wise, the S is about the same size as a Pro DSLR. The lenses are on the large and heavy side. 1 Link to post Share on other sites More sharing options...
setuporg Posted January 31, 2022 Share #23 Posted January 31, 2022 Or, as @Artin said in in the M11 forum, we’re walking with Coke bottles sticking out 🤣 1 Link to post Share on other sites More sharing options...
davidmknoble Posted February 24, 2022 Share #24 Posted February 24, 2022 I’ve been thinking about this topic = making the S kit smaller. Several asked about lens hoods. I store them backwards on my lenses, but for the 30, 35 and 45 lenses, I rarely use the hoods. Mostly I am using a filter system on those lenses for landscape work. However, the 70 is so small I use the hood on that one, and I also use the hood on the 24 because it is so wide. I think ultimately it is choosing only a few lenses. The 35-50-90 approach would suggest using the 45, 70 and 120 for the S. Clearly 28-50-90 is the 35, 70 and 120. If you have the 100 (which I do not), you could substitue the 120 with 100. I think the key is to limit to only a few lenses when in the field. Personally, I really like the Leica hard case of the S and fill it, but then only take the lenses I want when going out. When I shoot on the coast for a sunrise or sunset, I frequently take one lens and one only. Of course that is mostly because I don’t want to change lenses. I also recently lost an old billingham from heavy use and replaced it with a 407. That bag seems to hold an S and a few lenses and is fairly comfortable to put on my shoulder. Just a thought for a walking bag to cary 2-3 lenses. Just musing. Helps me think. 2 Link to post Share on other sites More sharing options...
Stuart Richardson Posted February 24, 2022 Share #25 Posted February 24, 2022 (edited) I honestly think that this is just a case of choosing the right camera. The S is not the right camera for something where compactness and low weight are called for. It is not really a great travel camera, unless the main purpose of the trip is photography. You can certainly do some tricks to make it less of a burdensome system, but the fact remains that the lenses and body combination is closer to a dumbbell than a feather. I think the best compact version of the S is the SL2...particularly with M or Sigma Contemporary lenses. Yes, I know it is a different camera, but the S does not give you a lot of choice...the only ones being those that were stated here. Select from one of a series of a couple compact adapted medium format lenses, or just go for the 70mm without the hood (which is still not "compact" or light by any contemporary definition). Perhaps I am more resigned to it since I shoot 8x10 and 4x5? Because no amount of wishing and hoping will get you an 8x10 kit under 5 or 6kg (with lenses, tripod and holders). Edited February 24, 2022 by Stuart Richardson 1 Link to post Share on other sites More sharing options...
John McMaster Posted February 24, 2022 Share #26 Posted February 24, 2022 Only time I use anything other than my S(007) and native lenses is if the results do not matter/flying light (hand luggage only and a few days away). Then it is M(240), original Monochrom, 35mm FLE and 50mm APO, but the results do not match up.... john Link to post Share on other sites More sharing options...
mgrayson3 Posted February 24, 2022 Share #27 Posted February 24, 2022 Advertisement (gone after registration) I carried an S(007) and S24 on a week of day hikes. It was a mistake. Got a few good shots, but it wasn't worth the pain of carrying it. An APS-C with a good range of primes or a stellar zoom would have been a better choice. If only the Leica CL had stabilization in body or just in the long zoom, it would have been the perfect travel camera. As it stands, I carry a Fuji X-H1 when size and weight matter. Link to post Share on other sites More sharing options...
setuporg Posted February 25, 2022 Share #28 Posted February 25, 2022 On 2/23/2022 at 6:02 PM, davidmknoble said: I’ve been thinking about this topic = making the S kit smaller. Several asked about lens hoods. I store them backwards on my lenses, but for the 30, 35 and 45 lenses, I rarely use the hoods. Mostly I am using a filter system on those lenses for landscape work. However, the 70 is so small I use the hood on that one, and I also use the hood on the 24 because it is so wide. I think ultimately it is choosing only a few lenses. The 35-50-90 approach would suggest using the 45, 70 and 120 for the S. Clearly 28-50-90 is the 35, 70 and 120. If you have the 100 (which I do not), you could substitue the 120 with 100. I think the key is to limit to only a few lenses when in the field. Personally, I really like the Leica hard case of the S and fill it, but then only take the lenses I want when going out. When I shoot on the coast for a sunrise or sunset, I frequently take one lens and one only. Of course that is mostly because I don’t want to change lenses. I also recently lost an old billingham from heavy use and replaced it with a 407. That bag seems to hold an S and a few lenses and is fairly comfortable to put on my shoulder. Just a thought for a walking bag to cary 2-3 lenses. Just musing. Helps me think. Very much my findings, David. I use a Billingham Hadley Pro for a 007 with two lenses, e.g. 25/70/100 (or 120). Sometimes I take the 30-90 with a 100 or 24. Overall the 70 or 100 or 35 is a good single walk-around lens, depending what you want to do -- nature or street or kids. Link to post Share on other sites More sharing options...
LeicaS2 Posted March 24, 2022 Share #29 Posted March 24, 2022 I no longer use lens hoods except sometimes on the 24mm. Certainly not needed on the 120 except for protection. Since I usually use filter systems the hoods have to be removed anyway. When I first got an S2 I didn’t feel the system was any larger than a DSLR. Now with so many mirrorless systems it is large. Link to post Share on other sites More sharing options...
