Hey!
Can anyone recommend cheap compact flashes for the M6 TTL? The flash doesn't need to have TTL, it's not going to be used often just when at family gatherings and I want to snap a few memories in a point and shoot fashion (without having to buy a p&s)
I've heard conflicting stories of frying electronics so that's why I'm asking again to put my mind at ease.
Cheers!
I used to use a Metz 20BC-6, and it worked on my M6TTL, but I then I got a Leica SF20, which is a better flash, and it does TTL. It isn’t cheap. There are probably plenty of good used Metz flashes from ~20 years ago that would work well.
If you get an older Metz with an SCA TTL module for Leica, get the 3502 or 3501 Mod 1, not the original 3501, which had problems with the M6 TTL.
Edited by drew.saunders
The Leica SF20 isn't cheap indeed, but it works very well. I bought mine many years ago new, and I still use it on my M6 TTL  and the older M6, with very nice results.
There are many other, older flashes that are much cheaper. On my older M4 and M4-P is sometimes use a Metz Mecablitz 32CT3 or the Vivitar 283.
Lex
No need for anything Leica-specific unless you want the red dot. With my M9 and M240 I used to use several of the Nikon SB-28, which was readily available at a good price on ebay. Solidly built, easily managed, compact, powerful. It has both M and A modes, which are all you need.
Edited by LocalHero1953
The Fujifilm EF-X20 is a great choice (I prefer it to the Leica SF-20 which makes the whole body really unbalanced!).
I'm on the lookout for a FlashQ II by LightPix which I heard good thoughts on digitals - I'm wondering how does it perform with analog?! If it does perform at all (I dont see why not). It does function as a wireless too which is a bonus...also quite cheap.
  • 2 years later...
vor 3 Stunden schrieb Bruna:
Hey
what about a cheap flash for leica m6, no ttl ?
I have a major event to shoot next month, and need to find one asap.
Nikon SB28, Metz 32CT3. Used both with good results on the M6 and other cameras in auto-mode.
Just about any classic flash will lol do. My personal favourite unisex the Metz Mecablt 32 CR 7 as the shape matches the camera. the M6 does not have any flash contacts except sync so any SCA adapter will do. If you also have a Leica with TTL control  you need an 351 or 343
Examples:
https://www.ebay.de/p/110619621?iid=391545721567
On 5/13/2024 at 3:51 AM, Bruna said:
Hey
The Metz 36 C-2 is decent if you can find one - it doesn't have any dedicated functions, so no need for an SCA adapter. Various flagship Nikon flashes from the late film / early digital  era would be fine (a bit bigger but higher end than the 36 C-2), including the SB-28 mentioned above and the similar SB-28DX or the later SB-80DX or even the SB-800 (though the last one's compatibility with the later Nikon dSLRs generally make it more expensive for extra features you don't need on a Leica). All of these have manual mode and a non-TTL auto mode that uses a sensor on the flash itself, which is as much automation as you can use on an M6 Classic or Reissue.
8 hours ago, SanDiegoMike said:
I read somewhere that a Panasonic 360 flash was compatible with Leica cameras, but I have never owned one so I can't verify that. Does anyone have any experience with that combination?
The DMW-FL360 has a TTL mode that I think will only work with old Leica digitals that were basically rebadged Panasonics, not the M series. However, it also has an auto mode that uses the flash unit's built-in sensor, as well as a manual mode.  Both these modes will work with most cameras from most manufacturers.
