jumbalix Posted September 26, 2021 Share #1  Posted September 26, 2021 Advertisement (gone after registration) Hello everyone, in the next days I will receive my CL, I would use the lenses shared with my M8, should It be better to remove the IR filter from the lens before use or on CL or no colour cast are noticeable also keeping the same filters? I think these filters cut the same waive-lenght of the standard sensore filter of the CL, so no added effect, thank you  Link to post Share on other sites More sharing options...
Advertisement Posted September 26, 2021 Posted September 26, 2021 Hi jumbalix, Take a look here CL and UV IR M8 filters. I'm sure you'll find what you were looking for!
tommonego@gmail.com Posted September 26, 2021 Share #2 Â Posted September 26, 2021 I have a CL and an M8, frankly I haven't tried the IR/UV M8 filter on the CL. The CL is alot less IR sensitive. I would think the M8 filter wouldn't do much. I'm curious though, it is dark here now, so maybe I'll try it tomorrow. Link to post Share on other sites More sharing options...
lct Posted September 27, 2021 Share #3  Posted September 27, 2021 IR-cut filters are not required on the digital CL but i haven't noticed any color cast when using them on 15mm to 35mm M lenses. I expected some cyan shift there but i was wrong. 1 Link to post Share on other sites More sharing options...
jumbalix Posted September 27, 2021 Author Share #4  Posted September 27, 2021 Thank you so much, I will try to keep the filters so I can avoid the hassle to switch anytime IR and IR UV during the same session! Link to post Share on other sites More sharing options...
wda Posted September 27, 2021 Share #5  Posted September 27, 2021 I doubt that you will notice any difference in performance. Link to post Share on other sites More sharing options...
dfdann Posted October 2, 2021 Share #6  Posted October 2, 2021 The guys at Leica Miami say do not use the ir filters for anything  except M8. Dan 2 Link to post Share on other sites More sharing options...
jaapv Posted October 3, 2021 Share #7  Posted October 3, 2021 Advertisement (gone after registration) I use them as much as I like for any other camera and see no discernible negative effect. On the M9 and I suspect the M10 they are mandatory in very high IR conditions. You might ask the guys at the Miami store how it can be that those filters were a standard product with B+W long before the M8 existed. 1 Link to post Share on other sites More sharing options...
tommonego@gmail.com Posted October 5, 2021 Share #8  Posted October 5, 2021 Finally got around to testing this, using a 35mm Summilux pre asph. Green is where I noticed the main difference with with filter or not on the M8, so I did I quick photo of what is left in our graden late in the season. Definitely a difference with the M8, a slight one with the CL but hardly noticeable. I did not change the exposures with either camera. So it looks like it wouldn't be a problem to use the IR/UV filter onthe CL. I used a B+W IR UV filter (486). Welcome, dear visitor! As registered member you'd see an image here… Simply register for free here – We are always happy to welcome new members! 2 2 Link to post Share on other sites Simply register for free here – We are always happy to welcome new members! ' data-webShareUrl='https://www.l-camera-forum.com/topic/324891-cl-and-uv-ir-m8-filters/?do=findComment&comment=4287024'>More sharing options...
jumbalix Posted October 9, 2021 Author Share #9  Posted October 9, 2021 On 10/5/2021 at 7:02 PM, tommonego@gmail.com said: Finally got around to testing this, using a 35mm Summilux pre asph. Green is where I noticed the main difference with with filter or not on the M8, so I did I quick photo of what is left in our graden late in the season. Definitely a difference with the M8, a slight one with the CL but hardly noticeable. I did not change the exposures with either camera. So it looks like it wouldn't be a problem to use the IR/UV filter onthe CL. I used a B+W IR UV filter (486). Welcome, dear visitor! As registered member you'd see an image here… Simply register for free here – We are always happy to welcome new members! Thank you so much for this test, also interesting to see the M8 pictures appear sharper, perhaps the 24 megapixels of the CL deliver a too High frequency for a vintage lens, also causing halo effect? Also I am using '80 lenses and I have the same impression ! Link to post Share on other sites More sharing options...
jaapv Posted October 10, 2021 Share #10  Posted October 10, 2021 Because of the crop factor you have a different magnification,thus a different perceived sharpness. One of the reasons why APS-C lenses must be higher specified than full-frame ones, and full-frame higher than medium format, etc. 1 Link to post Share on other sites More sharing options...
lct Posted October 10, 2021 Share #11  Posted October 10, 2021 The M8 has a thinner sensor stack too. 0.5mm i believe. I don't know that of the CL though. 1 Link to post Share on other sites More sharing options...
jaapv Posted October 10, 2021 Share #12  Posted October 10, 2021 Yes. come to think of it, the M8 has APS-H which is not that much larger than APS-C. It is probably the CCD sensor with the ultra thin filter. The colour difference in the greens is IR contamination. 1 Link to post Share on other sites More sharing options...
