Shameetman Posted April 23, 2020 Share #1 Posted April 23, 2020 Advertisement (gone after registration) A week ago I developed a rol of film, everything fine. Today I developed another role and many overexposed shots. I checked my camera and discovered a nasty hole. How is this possible? Leica repairs are usually not cheap, I want to make sure not to get this again. Any advice? Welcome, dear visitor! As registered member you'd see an image here… Simply register for free here – We are always happy to welcome new members! Link to post Share on other sites Simply register for free here – We are always happy to welcome new members! ' data-webShareUrl='https://www.l-camera-forum.com/topic/308818-suddenly-a-hole-in-my-m7-curtain-how-is-this-possible/?do=findComment&comment=3959651'>More sharing options...
Advertisement Posted April 23, 2020 Posted April 23, 2020 Hi Shameetman, Take a look here Suddenly a hole in my m7 curtain, how is this possible?. I'm sure you'll find what you were looking for!
marknorton Posted April 23, 2020 Share #2 Posted April 23, 2020 That's bad luck, most likely the camera has been left looking at the sun with the lens set to infinity and maybe wide open with the lens cap off. It's focussed an image of the sun onto the curtain and burned it. 1 Link to post Share on other sites More sharing options...
earleygallery Posted April 23, 2020 Share #3 Posted April 23, 2020 You have left the camera facing into direct sunlight without the lens cap on. Ever as a kid used a magnifying glass directed at sunlight to burn a hole in paper? 1 Link to post Share on other sites More sharing options...
Sailronin Posted April 23, 2020 Share #4 Posted April 23, 2020 As noted above, lens pointed to sun with lens cap off. I had this happen to my first SLR, an old Miranda back in the '70s. Link to post Share on other sites More sharing options...
marknorton Posted April 23, 2020 Share #5 Posted April 23, 2020 (edited) If we knew the diameter of the hole, we could probably work out the focal length of the lens... OK. I estimate the hole diameter to be 0.8mm which suggests a 90 mm lens... (the sun is 1.39m km in diameter and 150m km distant) Edited April 23, 2020 by marknorton 4 Link to post Share on other sites More sharing options...
earleygallery Posted April 23, 2020 Share #6 Posted April 23, 2020 You may be able to repair it without needing new shutter curtains. Either a small patch glued over the hole or filling the hole with rubberised paint - there are some threads on here with more details. Link to post Share on other sites More sharing options...
Shameetman Posted April 23, 2020 Author Share #7 Posted April 23, 2020 Advertisement (gone after registration) 3 minutes ago, earleygallery said: You may be able to repair it without needing new shutter curtains. Either a small patch glued over the hole or filling the hole with rubberised paint - there are some threads on here with more details. Thanks for your advice! Link to post Share on other sites More sharing options...
Shameetman Posted April 23, 2020 Author Share #8 Posted April 23, 2020 Thanks for your reply’s guys! From now on I will be more careful. Link to post Share on other sites More sharing options...
Shameetman Posted April 23, 2020 Author Share #9 Posted April 23, 2020 Hope this will work Welcome, dear visitor! As registered member you'd see an image here… Simply register for free here – We are always happy to welcome new members! 1 3 Link to post Share on other sites Simply register for free here – We are always happy to welcome new members! ' data-webShareUrl='https://www.l-camera-forum.com/topic/308818-suddenly-a-hole-in-my-m7-curtain-how-is-this-possible/?do=findComment&comment=3959696'>More sharing options...
a.noctilux Posted April 23, 2020 Share #10 Posted April 23, 2020 No, not so good idea. I can imagine when in use, the tape bit falls off then sticks other part inside the camera. Better use "liquid electrical tape" , have a look in this link to RFF thread https://www.rangefinderforum.com/forums/showthread.php?t=56491 1 Link to post Share on other sites More sharing options...
peterm1_Leica Posted April 23, 2020 Share #11 Posted April 23, 2020 (edited) Don't use tape. It will come unstuck and end up causing far greater problems inside the guts of your camera. If you can find an old and wrecked camera with cloth curtains it is possible to use the curtain material from that camera. Camera repair techs can often help in this regard as they always seem to have old bodies around the workshop. Also I would use a round not a square patch. Corners are always weak points where detachment starts. I will leave it to others to suggest the best glue to use. But needless to say the glue must be flexible and stay that way. As for me I have repaired cloth curtains with sun holes in them just like yours using liquid electrical tape as others have suggested. (It comes in paint on and spray on form - use the paint on type sparingly with a tiny artists brush to build up layers till the hole is closed. Less is better - you do not need big gobs of rubbery stuff on your delicate cloth curtain. I have also repaired a curtain in which the light proof rubber backing had become crazed (but the cloth itself was intact) using Pebeo marbling ink, a flexible liquid paint/ ink used for marbling fabrics. This is too thin to patch holes but quite effective in rectifying a crazed curtain for at least the few more years that I owned an used the camera with that problem. In either case leave the curtain for several days to make sure the glue is absolutely set before cycling the shutter. Edited April 23, 2020 by peterm1_Leica Link to post Share on other sites More sharing options...
charby57 Posted April 23, 2020 Share #12 Posted April 23, 2020 Have it fixed by Leica New Jersey. It’s the safest way for your M7. The souvenir of their service invoice should prevent another incident. 1 2 Link to post Share on other sites More sharing options...
ianman Posted April 24, 2020 Share #13 Posted April 24, 2020 9 hours ago, charby57 said: Have it fixed by Leica New Jersey Why New Jersey when the OP seems to be in The Hague??? 🤔 2 2 Link to post Share on other sites More sharing options...
Shameetman Posted April 24, 2020 Author Share #14 Posted April 24, 2020 43 minutes ago, ianman said: Why New Jersey when the OP seems to be in The Hague??? 🤔 Well, it used to be a Dutch colony.. But I have to admit that driving to Wetzlar would more sufficient 2 3 Link to post Share on other sites More sharing options...
Shameetman Posted April 24, 2020 Author Share #15 Posted April 24, 2020 Bought liquid rubber and works perfect again. Developed a role and the leak is gone. 🙌🏼 Link to post Share on other sites More sharing options...
Chaokhun Posted April 24, 2020 Share #16 Posted April 24, 2020 If you wanted to repair it, you can contact Will van Manen of Kamera Service in Zoetermeer. Link to post Share on other sites More sharing options...
Edgy01 Posted May 11, 2021 Share #17 Posted May 11, 2021 Hence, the reason Nikon began using titanium shutter foils on their SPs and then the F line. Link to post Share on other sites More sharing options...
Danner Posted May 11, 2021 Share #18 Posted May 11, 2021 It's an important reminder for all of us. Link to post Share on other sites More sharing options...
M9reno Posted May 11, 2021 Share #19 Posted May 11, 2021 I have never left a camera on a table facing sunlight with an uncapped lens. But simply walking around in Greece with a 21mm mounted on my IIIg and the camera hung around my neck was enough to noticeably mark the curtain at several spots, all incipient holes, but thankfully none of them complete. Any time the lens looks at the sun, even if only a short time, there is danger of burning, just like starting a fire on dry leaves with a magnifying glass does not take a long time.🙂 1 Link to post Share on other sites More sharing options...
jaapv Posted May 11, 2021 Share #20 Posted May 11, 2021 4 hours ago, Edgy01 said: Hence, the reason Nikon began using titanium shutter foils on their SPs and then the F line. Titanium can burn as well - it is just a bit more resistant than cloth. 1 Link to post Share on other sites More sharing options...
