7 hours ago, Stein K S said:
Hi
I had one 49mm special Leica MATE filter in order for 8 months... until Leica quite recently informed that this filter will not be produced again.
Hence my comment about checking out the s/h Dealers, I wouldn't expect Leica or any other manufacturer to produce a filter primarily designed to fit a lens discontinued well over 10 years a go
6 hours ago, james.liam said:
Perhaps someone can illuminate me why this particular filter provides an advantage over any other slim 49?
Not sure that it does, going back to the OP he asked about a filter that fitted his MATE which didn't need modification to use with the hood. At the time we didn't know if he was referring to the mk 1 55mm or the mk2 49mm. One poster offered up an aftermarket slim fit 55mm and I offered up that Leica made a filter specifically for the 49mm version. Without bothering to go back through the thread I don't recall any claims of advantage of one brand over another or the usual snarky comments about cheap filters on expensive lens.
I suppose Leica or any other lens manufacturer would claim that their filters are specially matched to the lens but I see no claims of superiority in this thread, without really knowing what advances have been made in coating technology over the last few years it could be argued that a new filter from one of the better aftermarket manufacturers may well be superior to the one that was first marketed some years a go by Leica.
1 hour ago, james.liam said:
The last run that were 6 bit coded at assembly.
Interesting indeed. I was not aware of a 3rd version. Does it have the same code number as v2 (11625)? Just curious.
